Staro 11.04.2007., 15:10   #31
atha
atha's Avatar
Postovi: 9,067
x1950pro bi i guees trebala gurati na 1680x1050 rezi?
___________
Just atha
x
Staro 11.04.2007., 15:44   #32
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Autor atha Pregled postova
nema šanse...
Staro 11.04.2007., 16:06   #33
atha
atha's Avatar
Postovi: 9,067
Dammit!
xPsycho je pisao kako mu i na 7800GT radi na toj rezi, sto bi znacilo da ce raditi na x1950pro. Treba ocito probati.
___________
Just atha
x
Staro 11.04.2007., 16:24   #34
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
jedno je raditi a jedno je moći i nekaj raditi tj igrati se bez cukanja
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 11.04.2007., 16:25   #35
Rain Man
Lokacija: x
Postovi: 1,447
Autor bacyc Pregled postova
ja imam 225bw i skoro da i nema probijanja osvjetljenja
Ovisi to i o primjerku kojeg dobijes. Isto tako ko i mrtvi pikseli! Nemoze se sa 100% sigurnoscu generalizirat kao sto je to theprofiler ucinio.
@theprofiler. Dosta mu je pojacan brightness, dok je konstast tu negdje. Ja sam ostavio malo jaci brightness, a snizio gamu preko drivera od grafe. Uglavnom treba se igrat da si podesis sliku jer u defaultu nije najslavnije podesena.
Inace boja nije "uzasno" losa kao sto to gorluk voli naglasavat, no nije ni najbolja. Najboljji primjer ti je taj TN uz nekog IPS-a ili boljeg CRT-a.
Rain Man je offline   Reply With Quote
Staro 11.04.2007., 16:37   #36
atha
atha's Avatar
Postovi: 9,067
Autor NJUNJO_HR Pregled postova
Ja se nadam da se to podrazumijeva i da normalna osoba kuzi o cemu se radi. Jer bas i nije cilj samo uci u igru i cackati nosi, a zakljucak je - radi.
___________
Just atha
x
Staro 11.04.2007., 17:08   #37
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
upravo donesoh 226BW doma, tek ga prikopcao. javim dojmove, za sada zakon, samo da boje postelam
Staro 11.04.2007., 17:47   #38
MaxB
Lokacija: Nigdjezemska
Postovi: 183
Autor Rain Man Pregled postova
Glede 225bw dojmovi su podijeljeni - nekima je slika OK, nekima nije. Glede 226bw - jos nisam vidio da se netko s tim monitorom sa Samsungovom matricom zalio da ima blijede boje (jer fakat ima najmanje dobre, a mozes ih jos dodatno pojacat pa su zapravo i preintenzivne), da mu probija pozadinsko osvjetljenje (u najgorem slucaju neko minimalno probijanje). Tak da se moze generalizirati da Samsung s 225bw ima problema s kontrolom kvalitete (mozda je caka u tome sto svi dolaze s AU Optronicsovim panelima?), a 226bw bas i ne.
MaxB je offline   Reply With Quote
Staro 11.04.2007., 18:38   #39
Dule
Dule's Avatar
Postovi: 684
kako nebi radilo, ja zadovoljan sa 7300gt na 1680x1050, ali nisam neki veliki gamer tho. sa ono malo igara koje znam zaigrat sam zadovoljan.
Dule je offline   Reply With Quote
Staro 11.04.2007., 18:47   #40
stiv
Postovi: 48
Ja sam ponosni vlasnik 206bw.
Moram reći da mi je veličina monitora taman i drago mi je kaj nisam uzeo 22"
226bw. Uštedio sam 450kn koje sam potrošio na malo bolju grafu.
inače, monitor je odličan! prije kupnje čito sam puno po netu o monitorima i što sam više čito sam bio neodlučniji pa bi predložio onima koji kupuju novi monitor da ne čitaju previše negu samo za par modela koji ih zanimaju
nego, kod paljenja monitora zna se čut neko zujanje iz njega na 3-5 sekundi pa me zanima jel to normalno?
stiv je offline   Reply With Quote
Staro 11.04.2007., 18:52   #41
shoki
Datum registracije: Apr 2004
Lokacija: STUBIČKE TOPLICE
Postovi: 609
i još jedno pitanje: ako ja recimo na takvom monitoru zaigram neku staru igru na 4:3 rezi, jel se slika razvuče ili je moguće podesiti da mi bude sa strane crno, a slika u pavilnom omjeru?
shoki je offline   Reply With Quote
Staro 11.04.2007., 19:45   #42
Dule
Dule's Avatar
Postovi: 684
Autor stiv Pregled postova
moj 205bw zuji stalno, iza panela. cujem ga samo po noci kad je sve tiho..
Staro 12.04.2007., 01:58   #43
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Autor shoki Pregled postova
mozes je i razvuci a mozes staviti da ti crno bude sastrane
.i.
Razer Blade 15
Staro 12.04.2007., 09:32   #44
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Kako stavit je da sa strane crno tako da nebude razvučena?
žmnpp
Staro 12.04.2007., 10:39   #45
kolapz
Lokacija: CRO
Postovi: 56
S kojim panelom dolazi sm226bw u nas, Samsung TN Film (LTM220M1) ili AU Optronics TN Film (M220EW01)?
kolapz je offline   Reply With Quote
Staro 12.04.2007., 11:29   #46
MaxB
Postovi: 183
Autor kolapz Pregled postova
Svi koji su se dosad javili na ovaj forum rekli su da imaju Samsungov panel. To ukljucuje M SAN i njihove dilere (ja sam svoj kupio u Optimum Racunala) te Metro.
Prije same kupovine trazi da ti pokazu monitor (na straznjoj strani ti uz model pise S za Samsungov ili A za AU Optronicsov model) - ja monitor nisam htio kupiti prije nego ga izvadi iz kutije i pokaze.
Staro 12.04.2007., 12:51   #47
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Autor buljo Pregled postova
Ne znam za ATI, ali NV ima tu opciju u driverima (jel tako codiac? )
Staro 12.04.2007., 14:12   #48
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor CatKiller Pregled postova
Use centered timings (za ATI)
bdw-sa zadnjim driverima ta opcija NIJE radila (Endivia 8800 GTS)
Osim toga-sam monitor mora podržavati hardware interpolaciju, to se u pravilu dobije na skupljim modelima.
Pa onda možeš igrati na npr. 1024x i imati ćeš sa svih strana crne rubove.
Ovi Zamzunzi mogu raditi prihvatljivu interpolaciju na 1440x, sve ostalo je šljuka....
Staro 13.04.2007., 09:43   #49
shoki
Postovi: 609
Autor Gabre Pregled postova
nema šanse...
čekaj, ozbiljno?
Ja imam 7600GS i razmišljam o velikom monitoru, da počnem razmišljati i o novoj grafici?
Q: sta ce ti mis sa "kuglicom" kad vec pa cijeni od 50-ak kuna mozes kupiti opticki mis koji je duplo prakticniji i bolje radi od tog tvog sa "kuglicom"...
A: Treba mi miš sa kuglicom jer troši manje struje. I za navigaciju po windozama je odličan tj. neizrecivo bolji od dirke.
Staro 13.04.2007., 16:37   #50
Rain Man
Lokacija: x
Postovi: 1,447
Sto se tice panela, vidio sam par entry modela monitora s sukladnim low quality TN panelima i ova 2x6 serija stvarno odskace od onog ustaljenog vjerovanja kako su svi TN paneli losi.
No nije ni vrhunski no kao i ja i barem 95% korisnika ne bi se previse bunilo na sliku.
Sto se tice igranja, ja se previse ne igram (uopce). No bas sam jucer za potrebe isprobavanja hamachi-ja instalirao stari Unreal Tournament i "novi" HL2 te se zacudio sto UT ima podrsku za wide format. Izgleda odlicno sto se tice wide formata. Interpolacija radi skoro pa zadovoljavajuce, no kod novih igara (koje vjerujem podrzavaju wide) dolazi samo nativna rezolucija u obzir jer se gubi eye candy. No isto kao i UT uspio sam tjerat i HL2 u nativnoj rezi no kako mi je grafa turbo moderna GF4 ti4200 mozete si mislit kako je to islo (uz sve na low bilo cak nekih 30 FPS-a).
Staro 17.04.2007., 14:22   #51
shoki
Postovi: 609
ponavljam pitanje: ako kupim 20+ inčni ekran, da razmislim i o jačpj grafici?
hvala
Staro 17.04.2007., 14:36   #52
Postovi: 7,568
hvala
Ako se igraš onda razmisli o kakvoj 7900GT/7950GT, X1900XT, X1950GT/Pro/XT, 8800GTS 320/640 ili nekom (kad stigne) Radeonu HD 2600Pro/XT. Ovisi kolko para imaš na raspolaganju. U suprotnome za filmove, serije, net, muziku i tome slično dosta ti je i ta kartica koju sad imaš.
Zadnje izmijenjeno od: McG. 17.04.2007. u 14:51. Razlog: Par slova viška:)
Staro 17.04.2007., 15:20   #53
Jelc
Super Moderators
Postovi: 17,485
Ako si igrač-onda pucaj na modele sa 640MB (Endivia) ili 512MB (ATI)
Ja sam isprobao jednu GTS 320MB na 20" wide Zamzungu i kad nafrljiš AA i ANISO (ili nedajbože large texture) siroče se lagano pridavi
Staro 17.04.2007., 15:29   #54
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Kaj mislite bi li moja 7900GS sa 256Mb mogla ok vrtiti igre na 20" WS?
Bartuc je offline   Reply With Quote
Staro 17.04.2007., 15:39   #55
Jelc
Super Moderators
Postovi: 17,485
Ako ne pretjeruješ sa AA i malo je clockneš-da.
Ovisi i koliko ti je jak proc.
Ako misliš igrati Oblivion 4xAA+HDR i 16xANISO u 1680x rezi-to ne bi išlo...
Staro 17.04.2007., 15:48   #56
MaxB
Postovi: 183
hvala
Ja trenutno 226bw imam upogonjen na Athlonu XP 1800+ s gigom RAM-a i Radeonom 9500. Gledanje TV-a (DVB-T), filmica, surfanje, Winamp... Sve to ide glatko. Jednostavnije igre takodjer, starije tipa Painkiller, MOHAA ili UT2004, sve bez AA (eventualno i bez AF-a), takodjer idu bez problema na radnoj rezoluciji. Igrice za SuperNintendo (preko ZSNES-a) takodjer se lijepo vrte...
Staro 17.04.2007., 15:56   #57
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Autor Jelc Pregled postova
Onda nebi smjelo biti frke! OC-nem grafu i proc na "gaming" vrijednost i deri Tak i onak ne patim na AA i ANISO...
Staro 17.04.2007., 17:33   #58
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Eo ja sam danas dobio dotični monitor i mogu reći da sam se iznenadio koliko je dobar, već sam se privikao na veličinu i sva sreća da nije bilo mrtvih pixela
Evo recimo netko je pitao za igre: recimo UT2004 je starija igra i na 1680x1050 leti glatko, 100+ FPS Dok recimo COD2 na 1280x1024 sa svim **anjima ide na 35 FPS Sad procijenite koliko jaku grafu trebate za neke igre
Ako treba kasnije mogu probati Carbon, Doom3, ili ako treba Oblivion i Stalker, samo te dvije bi mogle biti u petak
Di sam stao?
Staro 17.04.2007., 17:57   #59
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ček, vrtio si COD2 u 1280x1024 na 22" lcd?
stavi to u nativnu rezu pa probaj. jer je nebitno koja je reza monitora, ako si ti u igri stavio manju rezu, ona će na većem monitoru biti samo razvučenija....
a što ste se prepali da će vam kartice biti slabe, dajte malo optimizma...
kupio mi prijatelj neodavno dell 24", reza 1920x120, ima Leadtek 7600GT,
i zamisli, STALKER, u HIGH detaljima, sa isključenim Dynamic Lightning radi TEČNO bez trzanja, u nekih 50fps, možda i više...
tako da nemojte se bojati reze, sve se da poštimati da radi pristojno. Možda bez kojeg detalja, ali će raditi brzo i lijepo.
Mene ovi LCD-i u igrama ubijajau jer su bljijedi za popizdit, crnu nikako dobit, jadno.... CRT.. ŠMRC
Staro 17.04.2007., 18:17   #60
Jelc
Super Moderators
Postovi: 17,485
Bulšit
Kad odeš drugi put kod njega provjeri u izborniku kakvi su ti "high detalji" i za koju je rezu igra naštimana.
Pa da ne pričaš onda drugi put o Stalkeru na 1920x rezi sa high detaljima a sve to vrti 7600GT (na 50 ako ne i više fps-a)
