Lokacija: ????
Postovi: 208
Run komande
Evo nekih run komandi,ako nekome zatreba, odmah se ispričavam ako je već postano, tražio sam ali nisam vidio,ako je bilo,slobodno izbrišite: Start-Run: Accessibility Controls - access.cpl Add Hardware Wizard - hdwwiz.cpl Add/Remove Programs - appwiz.cpl Administrative Tools - control admintools Automatic Updates - wuaucpl.cpl Bluetooth Transfer Wizard - fsquirt Calculator - calc Certificate Manager - certmgr.msc Character Map - charmap Check Disk Utility - chkdsk Clipboard Viewer - clipbrd Command Prompt - cmd Component Services - dcomcnfg Computer Management - compmgmt.msc Date and Time Properties - timedate.cpl DDE Shares - ddeshare Device Manager - devmgmt.msc Direct X Control Panel (If Installed)* - directx.cpl Direct X Troubleshooter - dxdiag Disk Cleanup Utility - cleanmgr Disk Defragment - dfrg.msc Disk Management - diskmgmt.msc Disk Partition Manager - diskpart Display Properties - control desktop Display Properties - desk.cpl Display Properties (w/Appearance Tab Preselected) - control color Dr. Watson System Troubleshooting Utility - drwtsn32 Driver Verifier Utility - verifier Event Viewer - eventvwr.msc File Signature Verification Tool - sigverif Findfast - findfast.cpl Folders Properties - control folders Fonts - control fonts Fonts Folder - fonts Free Cell Card Game - freecell Game Controllers - joy.cpl Group Policy Editor (XP Prof) - gpedit.msc Hearts Card Game - mshearts Iexpress Wizard - iexpress Indexing Service - ciadv.msc Internet Properties - inetcpl.cpl IP Configuration (Display Connection Configuration) - ipconfig /all IP Configuration (Display DNS Cache Contents) - ipconfig /displaydns IP Configuration (Delete DNS Cache Contents) - ipconfig /flushdns IP Configuration (Release All Connections) - ipconfig /release IP Configuration (Renew All Connections) - ipconfig /renew IP Configuration (Refreshes DHCP & Re-Registers DNS) - ipconfig /registerdns IP Configuration (Display DHCP Class ID) - ipconfig /showclassid IP Configuration (Modifies DHCP Class ID) - ipconfig /setclassid Java Control Panel (If Installed) - jpicpl32.cpl Java Control Panel (If Installed) - javaws Keyboard Properties - control keyboard Local Security Settings - secpol.msc Local Users and Groups - lusrmgr.msc Logs You Out Of Windows - logoff Microsoft Chat - winchat Minesweeper Game - winmine Mouse Properties - control mouse Mouse Properties - main.cpl Network Connections - control netconnections Network Connections - ncpa.cpl Network Setup Wizard - netsetup.cpl Notepad - notepad Nview Desktop Manager (If Installed) - nvtuicpl.cpl Object Packager - packager ODBC Data Source Administrator - odbccp32.cpl On Screen Keyboard - osk Opens AC3 Filter (If Installed) - ac3filter.cpl Password Properties - password.cpl Performance Monitor - perfmon.msc Performance Monitor - perfmon Phone and Modem Options - telephon.cpl Power Configuration - powercfg.cpl Printers and Faxes - control printers Printers Folder - printers Private Character Editor - eudcedit Quicktime (If Installed) - QuickTime.cpl Regional Settings - intl.cpl Registry Editor - regedit Registry Editor - regedit32 Remote Desktop - mstsc Removable Storage - ntmsmgr.msc Removable Storage Operator Requests - ntmsoprq.msc Resultant Set of Policy (XP Prof) - rsop.msc Scanners and Cameras - sticpl.cpl Scheduled Tasks - control schedtasks Security Center - wscui.cpl Services - services.msc Shared Folders - fsmgmt.msc Shuts Down Windows - shutdown Sounds and Audio - mmsys.cpl Spider Solitare Card Game - spider SQL Client Configuration - cliconfg System Configuration Editor - sysedit System Configuration Utility - msconfig System File Checker Utility (Scan Immediately) - sfc /scannow System File Checker Utility (Scan Once At Next Boot) - sfc /scanonce System File Checker Utility (Scan On Every Boot) - sfc /scanboot System File Checker Utility (Return to Default Setting) - sfc /revert System File Checker Utility (Purge File Cache) - sfc /purgecache System File Checker Utility (Set Cache Size to size x) - sfc /cachesize=x System Properties - sysdm.cpl Task Manager - taskmgr Telnet Client - telnet User Account Management - nusrmgr.cpl Utility Manager - utilman Windows Firewall - firewall.cpl Windows Magnifier - magnify Windows Management Infrastructure - wmimgmt.msc Windows System Security Tool - syskey Windows Update Launches - wupdmgr Windows XP Tour Wizard - tourstart Wordpad - write |
Ne znam šta da napišem
Postovi: 984
O super, nadam se da će poslužit nekom ovdje kom se ne da ić "dužim putem" do određenog mjesta.
Nemam ništa pametno za reć! |
Postovi: 2,222
Prva liga. Kako god da si nasao svaka cast. I mali dodatak, uz win+r shortcut moze jako ubrzati rad.... |
