Staro 04.04.2007., 00:12   #1
Dottore
Dottore's Avatar
Postovi: 7,638
tipkovnica IBM
gdje mogu naću dotičnu tipkovnicu?? barem crnu ... po mogućnist Zagreb
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 04.04.2007., 00:37   #2
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
u mikronisu, imaju nekolko modela, a evo jos i sto nabava kaze:
http://www.nabava.net/katalog/trazil...yboard&x=0&y=0
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 06.04.2007., 02:38   #3
Mar
Suit up!
Mar's Avatar
Postovi: 5,966
Moraš imati na umu da to više nije ona legendarna IBM kvaliteta.
IBM (or, you know, Lenovo, or whoever) don't make buckling spring keyboards any more. They sell various keyboards that use cheaper, quieter keyswitches that don't last nearly as long or provide nearly as pleasant a key-feel, but there's no real difference between current IBM-branded 'boards and any number of other mainstream offerings.
These mainstream 'boards, all with one or another variant of the simple and quiet rubber dome switch idea, are perfectly OK for people who don't type much. They may drop dead with or without the assistance of a spilled beverage, but that's no big deal; if your computer's essential to your happiness, buy a spare cheap keyboard in case your main cheap keyboard dies, and use your nasty mushy input devices with my blessing.
If you do type a lot, though, you owe it to yourself to get a good keyboard of one kind or another, for the same reason that people who use the mouse a lot shouldn't settle for some ancient crusty serial-port optomechanical artifact.
Old mouses aren't nice to use, but old keyboards can be, because mouse technology's advanced a lot over the last 20 years, but keyswitch technology was quite mature in 1980. Modern keyboard tech advances have mainly had to do with wireless interfaces, snazzy looks, and making cheap crud cheaper.
If you want to buy a new, as in manufactured-this-decade, buckling spring IBM keyboard, Unicomp is the place to go. They don't make 'boards with the actual IBM logo on them, but their products are the exact same thing as the later-model IBMs made by Lexmark (which is to say, not quite as monstrous as the original IBM-made units, with integrated cables instead of the plug-in originals, but still far beefier than mortal keyboards), and reasonably priced.
Tako da... ako tražiš one "prave" IBM kliketuše, potraži po oglasima ili servisima.
Mar je online   Reply With Quote
