Staro 28.03.2007., 19:52   #1
Mailman
Mailman's Avatar
Postovi: 1,606
ATI Catalyst 7.3
Mailman je offline   Reply With Quote
Staro 28.03.2007., 20:17   #2
domy_os
domy_os's Avatar
Postovi: 18,877
Pizde jedne, još nisu izbacili WDM drivere za Vistu...
Staro 28.03.2007., 20:44   #3
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
ATI's Folding@Home
Folding@Home is a distributed computing project designed by the Stanford University. The application performs intensive simulations of protein folding. This simulation will help researchers uncover how certain diseases develop. Folding@Home uses distributed computing to simulate protein folding, the workload is broken up into small work units and distributed across hundreds of thousands of computers over the internet. You can help find the cure to many different diseases! To join Folding@Home, follow these steps:
1. Download ATI's Catalyst™ software suite
2. Download the Folding@Home GUP client application
Note: If you do not have an ATI Radeon™ X1600 or higher, then download the CPU client. If you have an ATI Radeon™ X1600 or higher, download the GPU client (either console or GUI version) not to be confused with the CPU "Graphical client".
3. Enter the ATI team number 51394 and start folding!
For more information on Folding@Home visit: http://ati.amd.com/technology/stream...g/folding.html
Jel to nesto novo od ove revizije drivera ili to ima od prije?
Jel netko isprobao kako ovo radi i koliko je brzo?
Staro 28.03.2007., 21:44   #4
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor JC Denton Pregled postova
To je stara stvar.
Ta spika hoda i sa PS3....
Sa ATI-jem je radilo prvo samo sa X19xx serijom, mislim da su poslje dodali i za X18xx ali je na njima sporije.
Više:
http://folding.stanford.edu/FAQ-ATI.html
Staro 29.03.2007., 21:22   #5
Filip_15
Lokacija: hrvatska
Postovi: 161
Jel su 7.3 puno bolji od 7.2?
Filip_15 je offline   Reply With Quote
Staro 30.03.2007., 08:46   #6
JC Denton
JC Denton's Avatar
Postovi: 3,164
Nemam pojma, jos nisu instalirani Ali znam da su 7.2 puno brzi od 7.1
Staro 30.03.2007., 10:24   #7
atha
atha's Avatar
Postovi: 9,067
DLao sam, navecer probam doma, sad sam ih digao na x550xt, ali tu mi ionako nema nekog znacaja.
___________
Just atha
x
Staro 30.03.2007., 12:14   #8
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Meni se sviđa i to što su iz verzije u verziju sve manji
Staro 30.03.2007., 13:18   #9
Jelc
Super Moderators
Postovi: 17,485
Je, sa Endiviom je druga priča...neki dan instaliram jednu novu GTS-icu i samo driveri sa njihove stranice su teški 60-tak megi.
Idem pogledat temperaturu GPU-a kad ono kita, moraš skinuti i funjavi nTune (još 40 megi)
Sve skupa 100
Staro 30.03.2007., 13:44   #10
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Jal ima poboljšanja u COD2,ako nema onda ih nema smisla stavljati
Staro 30.03.2007., 14:13   #11
JC Denton
JC Denton's Avatar
Postovi: 3,164
Da, ne svidja mi se što se počelo događati sa nV driverima... navodno više ni OpenGL podrška za profi aplikacije nije na razini kao prije (bar za ove "mainstream gamer" grafe).
Ma ATi me oraspoložio i ugodno iznenadio sa prošlom revizijom drivera... grafa mi je postala 15-20% brža!
Staro 04.04.2007., 23:39   #12
Jelc
Super Moderators
Postovi: 17,485
ATI Catalyst 7.3 Performance Analysis (Windows XP)
Staro 06.04.2007., 10:41   #13
Jelc
Super Moderators
Postovi: 17,485
ATI Catalyst 7.3 Hotfix
Za one kojima se rušila Vista sa zadnjim driverima:
http://support.ati.com/ics/support/d...estionID=26900
Staro 06.04.2007., 11:05   #14
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Ma ne isplati se to uopće stavljati na X800 serijama..i 7.2 je odličan..to je ionako za X19XX serije prvenstveno...
Staro 06.04.2007., 13:27   #15
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
r6 vegas radi brže i malo bolje izgleda ono kad vas pogode pa vam se muti...
x1950pro
Staro 06.04.2007., 14:20   #16
JC Denton
JC Denton's Avatar
Postovi: 3,164
Ja nisam primjetio značajna ubrzanja sa 7.3 verzijom... iako sam imao neka ubrzanja, ali mislim da je za to zasluzan C2D
Staro 16.04.2007., 20:38   #17
triple_9
triple_9's Avatar
Postovi: 76
instalirao sam ove drivere ali mi u everestu jos uvijek pise ovo:
Installed Drivers ati2dvag (6.14.10.6677)
to su stari ili?
triple_9 je offline   Reply With Quote
Staro 16.04.2007., 21:17   #18
Fera_os
Ne znam šta da napišem
Fera_os's Avatar
Postovi: 984
Obrisati te stare drivere u Add/remove programs, počistiti ih driver cleanerom u safe modu i onda tek stavit nove.
Ako nešto ne kužiš slobodno postaj...
Nemam ništa pametno za reć!
Fera_os je offline   Reply With Quote
Staro 16.04.2007., 21:46   #19
triple_9
triple_9's Avatar
Postovi: 76
hm,napravio sam tako , u everestu ista situacija, a u device manageru
driver date: 2.3.2007
driver version :8.351.0.0
sta je sada to?
Staro 16.04.2007., 21:56   #20
domy_os
domy_os's Avatar
Postovi: 18,877
Prabaj obrisati i Catalyst Uninstallerom, Driver Cleaner ti kod ATI-ja uopće ne treba...
