Strichek Moderator
Postovi: 9,344
Uđeš u BIOS i kad te pita da uneseš pass uneseš, i onda kad traži novi samo stisneš Enter. I onda nećeš imat pass. ![]()
žmnpp |
Lokacija: Zagreb/Križevci
Postovi: 346
Postovi: 33,944
Lokacija: 127.0.0.1
Postovi: 226
Postovi: 2,217
Postoje sranja za forceanje i slicno al to je sve tak uzalud... Inace kakve logike u passu ako se moze maknuti a da ga neznas! Clear CMOS, vratis settingse na default i bok bok rijesen problem u 10 sec. |
Brum brum...
Postovi: 584
a sta ne postoji ona fora .... uzmes knjizicu od maticne i tamo pise koje pinove kratko spojis i resetiras (obrises promjene) bios ? ![]() |
Postovi: 355
Problem je što neka računala zapisuju šifru u posebnu memoriju pa niti vađenje baterije ne pomaže, kako to riješiti, eh sad... pročitaj pass iz eeproma ![]() |
Administrator
Lokacija: Sesvete
Postovi: 15,963
Hm, a da probas nesto od ovoga, ako je neka od brand masina: Backdoor Passwords WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords. Award BIOS backdoor passwords: ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward AMI BIOS Backdoor Passwords: AMI BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER CONDO Phoenix BIOS Backdoor Passwords: phoenix PHOENIX CMOS BIOS Misc. Common Passwords ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj Other BIOS Passwords by Manufacturer Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba Toshiba BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot IBM Aptiva BIOS Press both mouse buttons repeatedly during the boot Ili, ako ti je stvarno stalo uvijek mozes forsirtati invalid checksum i prisiliti BIOS da se restarta na tvornicke postavke> @echo off echo o 70 2e >d.scf echo o 71 ff >>d.scf echo q >>d.scf debug d.scf echo q >>d.scf debug bios.txt Ili, ubaci DOS odnekud, bootaj u njega i onda ovako> C:\windows\command directory pa onda> DEBUG Enter. Nakon toga se pojavi crtica (-) u DEBUG promptu. Onda: o 70 2e [to izgleda ovako: -o 70 2e u DEBUG promptu. Nakon toga Enter pa: o 71 ff pa Enter. I na kraju: Q Enter da quitas DEBUG, nazad u C:\> prompt pa restart PC. Sve ovo radis na vlastitu odgovornost. ![]() |
80286
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Tor je moj uzor ![]()
