Staro 15.03.2007., 17:00   #1
m0rtusss
m0rtusss's Avatar
Lokacija: Crazy Hill
Postovi: 8
hp nx7400 problem
Ahoi!
Kupih prekjucer gore navedeni laptop i imam problem da mi winbloze (xp) ne prepoznaju mikrofon. Mislim, mikrofon radi i mogu snimat sa njega, ali ne mogu ga unmute-at kad ga nema u volume controlu ( i nemogu ga ukljucit pod advanced ).
Molim pomoc, jer mi je to jako bitno posto vježbam bass preko kompa.
Također mislim da bi mi neki microphone monitoring program pomogao ako ne uspijem popravit ovo. Zna li tko kakav dobar?
Hvala unaprijed...
m0rtusss je offline   Reply With Quote
Staro 15.03.2007., 18:50   #2
sick_boy
sick_boy's Avatar
Postovi: 680
Koji zvučni chip je na laptopu? Možda da instaliraš generičke drivere (npr. Realtek-ove, ako se radi o Realtek chipu)?
Edit: sad vidim da se radi o ADI1981HD codec chip-u. Potraži malo generičke drivere, možda pomogne.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 16.03.2007., 15:22   #3
m0rtusss
m0rtusss's Avatar
Postovi: 8
Evo.
Skinuo sam desetke razlicitih drivera i nijedan mi nije pomogao. Spojio sam se na hp user chat i ni hp-ofci mi nisu mogli pomoci. Zvao sam melcomp, oni su rekli da im donesem komp na servis...
Pošto nemogu dva-tri ili nedaj Bože tjedan dana biti bez kompjutora odlucio sam nekako složit i uspio sam izvest monitoring preko Cubase programa. Program radi oke ( doduše sa 3-4 ms latencije ) i sve je u redu za sad...
pozdraf, i hvala svejedno na pomoci...
.....jeste li vidjeli moga sinka janka.....
