Staro 04.03.2007., 21:37   #1
Filip_15
Lokacija: hrvatska
Postovi: 161
Unhappy Spajanje led dioda
Bok. Kupio sam crvene led diode, i sad neznam kak se to spaja? S kakvom žicom? na koji način? Kamo ih spojim? Jel ima nekoga komu se da objasniti! Bio bih vam vrlo zahvalan! Hvala
Filip_15 je offline   Reply With Quote
Staro 04.03.2007., 22:39   #2
gangxxxta
hustla
gangxxxta's Avatar
Postovi: 930
pa na sto si ih mislio spajati?
I don't need to "Get a life". I'm a gamer. I have lots of lives.
gangxxxta je offline   Reply With Quote
Staro 04.03.2007., 23:10   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Šta si mislio mjenjat ledice na mišu ili kučištu?
To su ti obične dvije žice koje spojiš. Izvadiš postojeću i na to mjesto staviš novu.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 04.03.2007., 23:33   #4
Delta S4
She`s back...
Postovi: 983
Autor gangxxxta Pregled postova
A fine question!
Autor Mortal Pregled postova
Pri tome paziti na polaritet, ako smijem dodati...
Delta S4 je offline   Reply With Quote
Staro 04.03.2007., 23:54   #5
Joke
N00B
Joke's Avatar
Postovi: 3,886
Evo ja cu se samo nadovezati sta je Deltu S4 rekao http://img339.imageshack.us/my.php?i...ntitledpr8.jpg
IE6
Linux is Not Windows
Staro 05.03.2007., 05:59   #6
Filip_15
Lokacija: hrvatska
Postovi: 161
Mislio sam ih staviti malo po kučištu. Zanima me ak ih spajam na napajanje kolko ih može ići na napon od 12V?
Staro 05.03.2007., 07:47   #7
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Ako im je nazivni napon 1.5V (to je mislim standardno toliko, provjeri) mozes ih na 12V spojiti 8 u seriju. U seriju znaci da na 12v spojis + prve, na - prve + druge i tako u lanac, kad dodjes do minusa osme diode, spojis na ground (crna zica). Na 5V idu 3-4 ledice u seriju, a mozes i prikljuciti ledica koliko hoces i staviti odgovarajuci otpornik (izracunat potreban otpor i snagu)...
Staro 05.03.2007., 08:49   #8
dmd-0
dmd-0's Avatar
Lokacija: /
Postovi: 592
dmd-0 je offline   Reply With Quote
Staro 05.03.2007., 15:02   #9
Filip_15
Lokacija: hrvatska
Postovi: 161
Autor Matesonik Pregled postova
Ovak nekak?
[img=http://img261.imageshack.us/img261/8830/bezimenamv8.th.jpg]
Staro 05.03.2007., 16:32   #10
bego2
bego2's Avatar
Postovi: 2,724
Nevalja. Trebaš otpornik stavit na + (anodu).
bego2 je offline   Reply With Quote
Staro 05.03.2007., 16:39   #11
Filip_15
Lokacija: hrvatska
Postovi: 161
zašto otpornik ak ih spajam serijski?
Staro 05.03.2007., 16:48   #12
Filip_15
Lokacija: hrvatska
Postovi: 161
Ako ih spajam paralelno, onda ih stavim koliko hoću i stavim otpornik? jel tako?
Evo računice:
http://led.linear1.org/1led.wiz?VS=5;VF=2;ID=20
Jel tak dobro?
EDIT:
OVAk bi to spojio!
[img=http://img508.imageshack.us/img508/4184/bezimenakn1.th.jpg]
KAd tak spajam, mogu ih spojiti kolko hoću? samo trebam staviti otpornik?
Zadnje izmijenjeno od: Filip_15. 05.03.2007. u 17:24.
Staro 05.03.2007., 17:23   #13
bego2
bego2's Avatar
Postovi: 2,724
Ako ih spojiš par komada u seriju zgorit će (na 12V). Ako spojiš paralelno (ako je izvor struje jak) onda će svaka svijetliti isto sa otpornikom.
Staro 05.03.2007., 21:24   #14
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Autor bego2 Pregled postova
Apsolutno je svejedno dal će spojiti na + ili - pol diode!
The šuma...
Staro 05.03.2007., 21:26   #15
Filip_15
Lokacija: hrvatska
Postovi: 161
Znaći dobro je ako stavim otpornik samo na ovu žicu odmah ispred molexa, netreba za svaki vent zasebno? i možete li mi reči koji otprnik mi točno treba?
Neki od 150 ohma! ima ih u chipoteci više, možete li mi pokazati točnoga?
Zadnje izmijenjeno od: Filip_15. 05.03.2007. u 21:39.
Staro 05.03.2007., 22:01   #16
jerba
Cro Fire member
jerba's Avatar
Lokacija: Zg/Jarun
Postovi: 76
ako mene pitas bilo bi ti ok da si kupis potenciometar, spojis 2 konektora i imas reostat (djelitelje struje) i mozes si lagano stimat jacinu svjetle u kucistu!! ako krivo spoji polaritet diode ti nece svjetlit! i izracunaj prije (nadi kaakteristike diode, najvaznije probojni napon Umax) sve nego kaj spajas da ne skuris!!
jerba je offline   Reply With Quote
Staro 06.03.2007., 12:44   #17
bego2
bego2's Avatar
Postovi: 2,724
Autor ćiber_manija Pregled postova
Hmm yebe mi se jeli svejedno, mene su učili da se stavlja na +.
Staro 06.03.2007., 14:56   #18
Filip_15
Lokacija: hrvatska
Postovi: 161
Znaći ovak, ovo di je kvadrat, to je otpornik,
[img=http://img84.imageshack.us/img84/1346/cm9lk2.th.jpg]
Ako ledica ima 2V, koliko otpronki mi treba??
Staro 06.03.2007., 21:12   #19
bego2
bego2's Avatar
Postovi: 2,724
Na 12V dosta je od 470 ohma 1w za jednu diodu i više njih u paralelu.
Staro 07.03.2007., 05:58   #20
Filip_15
Lokacija: hrvatska
Postovi: 161
Netrebam stavljati otponik ispred svake diode, nego samo na žicu ispred molexa?
Staro 07.03.2007., 06:20   #21
SPLiFF
SPLiFF's Avatar
Postovi: 2,077
treba ti za svaku diodu po 1 otpornik Ako ih spajas u paralelu.
boli me zub jbni nisam oka sklopio
Staro 07.03.2007., 09:25   #22
rib@
rib@'s Avatar
Postovi: 1,194
Autor SPLiFF Pregled postova
Mislim da nije potrebno.
Pri proracunu je samo bitno da stavi snagu u miliamp. onoliko dioda koliko misli staviti u jedan strujni krug.
Ako to napravi trebat ce samo jedan otpornik istog otpora, samo nesto vece snage (u Watima).
Ako sam u krivu, molim vas razuvjerite me.
cpu e4300/sonictower+nexus120; mbo gigabyte p35-ds3-l; ram kingmax1024/667x2; vga hd3850; psu corsair hx 520w; dvd benq 1655; hdd wd1200jd&samsung hd321kj&ST3160021A; ZM-MFC1; lg22ws; btc6300; mx 518 i sve u chiefu s nekoliko nexusa
rib@ je offline   Reply With Quote
Staro 07.03.2007., 15:04   #23
bego2
bego2's Avatar
Postovi: 2,724
Autor Filip_15 Pregled postova
Tako je.
Staro 07.03.2007., 15:18   #24
Filip_15
Lokacija: hrvatska
Postovi: 161
Ovakav otpornik?
http://led.linear1.org/1led.wiz?VS=12;VF=2;ID=20
Takav stavim samo ispred napajanja?
EDIT:
Nije bitno koliko ih spojim, ak ih spajam paralelno?
Zadnje izmijenjeno od: Filip_15. 07.03.2007. u 15:29.
Staro 07.03.2007., 15:33   #25
bego2
bego2's Avatar
Postovi: 2,724
Eo pogle. Jel su to diode koje (ćeš) si kupio kod mene?
ak da eo ja sam stavio 7 dioda u paralelu i na njih otpornik od 800 ohma 1 w na napajanje od kompa (12V) jedna svijetli isto kao i sve ove u paraleli
nevidi se baš dobro al...
edit: bitno je kako ih spajaš, svaka ima + i - znači paralelno spajaj pluseve (zajedno) i minuse (zajedno) i onda otpornik od 800 ohma ako je napon 12V
Staro 07.03.2007., 17:58   #26
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
bolje uvijek spajati ledice u seriju. ako je moguće..
pošto nikad nisu apsolutno jednake i onda u paraleli ako su spojene na 1 otpornik, neka ima manji unutarnji otpor i povuce jacu struju pa izgori... posljedicno i druge vrisnu zbog toga sto onda otpornik uopce ne odgovara preostalom broju ledica...
a otpornik ofkors ide u obje kombinacije spajanja (serija ili paralela), a vrijednost racunas u ovisnosti o naponu na koji ih spajas.
Ledica tako moze raditi na maloj bateriji od 4 V ali ista ta radi bez problema i na 220V gradske mreze, kvaka je u otporu koji ogranicava struju!
ako baš mora paralela, onda stavi jaci otpornik (malo ce slabije svijetliti sve skupa) ali ce barem raditi dugo
inace: ne vidim cemu upotreba tih mutnih LEDica kad vec dulji niz godina su na trzistu prisutne prozirne LEDice,
svijetle mnogo mnogo jace i upravo zato se vise upotrebljavaju.
skuplje su od ovih (cca 10kn vs ove mutne od par lipa) ali se isplati
(neki ih lazno zovu LASER LED da bi lakse prodali), a najveca prednost nad 'mutnima' im je bijela boja, koju je prije bilo nemoguce dobiti
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
Zadnje izmijenjeno od: TomRi. 07.03.2007. u 18:33.
TomRi je offline   Reply With Quote
Staro 07.03.2007., 19:36   #27
Filip_15
Lokacija: hrvatska
Postovi: 161
Ja bih svakako paralelu, jer ih moram puno puno spajati! Znaći ak spajam paralelno, mogu staviti otpornik ispred svake diode, na +? jel ovisi jačina otpornika o broju dioda spojenih paralelno? ja bi njih 20 spojio paralelno, dal bi to ovak išlo:
ili nekak drugačije?
Ako nije dobro, može li netko popraviti? http://led.linear1.org/led.wiz
Hvala
Staro 07.03.2007., 21:54   #28
Delta S4
She`s back...
Postovi: 983
Hvala
Nisam siguran što točno planiraš, ali obavezno postaj slike sa policijskog očevida.
Staro 08.03.2007., 00:20   #29
Damarko
Damarko's Avatar
Postovi: 447
Hvala
tako ih spajaj . . super je taj linkic. . dakle spoji ih po toj shemi i nees imat frke. . bar koliko se ja kuzim u to
Damarko je offline   Reply With Quote
Staro 08.03.2007., 00:25   #30
TomRi
TomRi's Avatar
Postovi: 2,073
Hvala
gle, APSOLUTNO je svejedno s koje strane LEDice stavis otpornik,
dok je polaritet LEDice (+ i -) vrlo bitan, inace ne bu radilo. (ali nece nis izgorit ako krivo spojis, pa nemoj panicarit)
drugo,
kako si sam napisao da bi napravio, u paralelu spojio i ISPRED SVAKE stavio OTPORNIK, to je dakako OK.
ali u tom slucaju NEMA nikakve veze koliko takvih kombinacija spojis u paralelu... mozes i 1000 komada, kuzis.
ako svaka ima svoj otpornik...
evo to bi ti onda ovako izgledalo... sada u glavi samo nastavis niz u desno... dokle zelis, tj dokle imas ledica i otpornika
Water cooled PC
Moj najveci MOD
