Staro 03.03.2007., 03:01   #1
Barny
Postovi: 78
(riješeno) Virusi i bakterije
Ajd znalci pomagajte!
Nećak mi se poigrao pa natovario koječega od gamadi os xp, bitdefender, ad-aware i spyware doctor su obrambena linija no.....
Nakon velike i iscrpljujuće borbe dva su mi ostala i nemrem im niš vidi log...
C:\Documents and Settings\Barny\Local Settings\Temp\rtqygdjc.exe Detected: Adware.Vstoolbar.A
C:\Documents and Settings\Barny\Local Settings\Temp\rtqygdjc.exe Disinfection failed
C:\Documents and Settings\Barny\Local Settings\Temp\rtqygdjc.exe Moved
C:\Documents and Settings\Barny\Local Settings\Temp\swkgmvqn.dll Infected: Trojan.Juan.F
C:\Documents and Settings\Barny\Local Settings\Temp\swkgmvqn.dll Disinfection failed
C:\Documents and Settings\Barny\Local Settings\Temp\swkgmvqn.dll Moved
C:\Documents and Settings\Barny\Local Settings\Temp\yisqqbom.dll Infected: Trojan.Virtumod.DG
C:\Documents and Settings\Barny\Local Settings\Temp\yisqqbom.dll Disinfection failed
C:\Documents and Settings\Barny\Local Settings\Temp\yisqqbom.dll Moved
C:\WINDOWS\system32\mljji.dll Infected: MemScan:Trojan.Vundo.AH
C:\WINDOWS\system32\mljji.dll Disinfection failed
C:\WINDOWS\system32\mljji.dll Move failed
C:\WINDOWS\system32\nnnoonm.dll Infected: MemScan:Adware.VirtuMonde.DY
C:\WINDOWS\system32\nnnoonm.dll Disinfection failed
C:\WINDOWS\system32\nnnoonm.dll Move failed
Upomoć braćo po oružju osto sam bez metaka....
Barny je offline   Reply With Quote
Staro 03.03.2007., 03:08   #2
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,127
Probaj:
1) Safe mode
2) Izbrisat file-ove iz cistog DOS-a
2b) Hiren's Boot CD, pa pocistit nekim od antivirusa iz DOS-a
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 03.03.2007., 03:14   #3
Barny
Postovi: 78
je kad bi ja to znao trebao bih malo detaljnije il pozvat nekog na pivkana..
Staro 03.03.2007., 10:39   #4
domy_os
domy_os's Avatar
Postovi: 18,916
U safe mod ulaziš tako da odmah nakon paljenja stišćeš F8 i odabereš Safe Mod kad ti se pojavi izbornik. Kad konačno uđeš, skeniraj ponovo. Ako opet ne možeš obrisat, ručno dođi do mjesta gdje su zaražene datoteke pa od tamo obriši.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.03.2007., 09:39   #5
Barny
Postovi: 78
Probao sam no ni tako. Jedini koji ga pronalazi je bitdef.
On se nasro u nekom nnnoonm.dll i ne mogu ga obrisati jednostavno se neda van iz nnnoonm.dll a zove se MemScan:Adware.VirtuMonde.DY
ak nije tlaka nekom da mi objasni kako iz reg. da ručno probam obrisati...
Staro 05.03.2007., 10:10   #6
domy_os
domy_os's Avatar
Postovi: 18,916
Snimi negdje i isprintaj ove upute jer možeš ostat bez internet veze.
Prvo skini Vundo Fix ili VirtumundoBegone (ako prvi ne bude radio). Možeš ih staviti na desktop.
Pokreni VundoFix.exe i klikni na Scan for Vundo. Kad završi, klikni na Remove Vundo nakon čega će te pitati da li želiš maknuti te datoteke pa ti klikneš YES. Desktop će se sada zacrniti i proces uklanjanja počinje. Na kraju ćeš morati resetirati komp.
Ako je problem ostao, odi u Safe Mod i pokreni VirtumundoBegone i slijedi upute na ekranu. Kad budeš gotov, vrati se u normal mode.
Zatim skini HijackThis, ovdje imaš upute gdje, šta i kako. Postaj log pa ćemo vidjeti što još treba maknuti.
Napomena: updateaj si Javu jer je to sranje upalo vjerojatno zbog stare verzije Jave.
Staro 05.03.2007., 10:26   #7
Barny
Postovi: 78
klanjam se........
popodne slijedi izvještaj..............
EDIT: naime probao sam neki dan sa vundo fix i on ga ne kuži, pa bum sa ovim drugim.
Kažem samo ga bitdef. nalazi od svih mogućih i svako toliko javlja da ga je našao i da komp. nije zaražen ma što to značilo...al je dosadan ko proljev jer se javlja svaku minutu.
Zadnje izmijenjeno od: domy_os. 05.03.2007. u 10:48.
Staro 05.03.2007., 18:21   #8
Barny
Postovi: 78
Exclamation
Evo ovako,
Vundo fix je našao, doista nije se zacrnio ekran već su samo nestale ikone i restartao je komp.
E sad
nakon toga sam pokrenuo bitdefender te ih je opet našao ali sada sa ovim uspjehom:
Summary:
C:\VundoFix Backups\nnnoonm.dll.bad Infected: MemScan:Adware.VirtuMonde.DY
C:\VundoFix Backups\nnnoonm.dll.bad Disinfection failed
C:\VundoFix Backups\nnnoonm.dll.bad Moved
Dali trebam još kaj radit ili je ovo gotovo.
Napravio sam Logfile od HijackThis ak je potrebno no velik je pa neznam dali da ga postam il je dovoljno samo nešto iz njega?
Zadnje izmijenjeno od: Barny. 05.03.2007. u 20:49.
Staro 05.03.2007., 23:04   #9
domy_os
domy_os's Avatar
Postovi: 18,916
Vidiš da to što je BD našao pripada VundoFixovom backupu, bitno da ga nema tamo gdje je prije bio. Slobodno stavi log...
Staro 05.03.2007., 23:30   #10
Barny
Postovi: 78
Dali ono što brišem označim u Hijack-u i stisnem fix checked il moram u reg.ručno?
ježit ga toliko je velik log da mi ga neda postat.......kaj sad bum u dva posta...
Logfile of HijackThis v1.99.1
Scan saved at 17:08:26, on 5.3.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\COMMON~1\Stardock\SDMCP.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\Logitech\SetPoint\SetPoint.exe
C:\Program Files\Common Files\Logitech\KHAL\KHALMNPR.EXE
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
C:\Program Files\CyberLink\Shared files\RichVideo.exe
C:\Program Files\Spyware Doctor\sdhelp.exe
C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
C:\Program Files\Common Files\Softwin\BitDefender Communicator\xcommsvr.exe
C:\Program Files\Common Files\Softwin\BitDefender Update Service\livesrv.exe
C:\Program Files\Common Files\Softwin\BitDefender Scan Server\bdss.exe
C:\Program Files\Canon\CAL\CALMAIN.exe
C:\Program Files\Softwin\BitDefender10\vsserv.exe
C:\WINDOWS\System32\alg.exe
C:\Program Files\Softwin\BitDefender10\bdmcon.exe
C:\totalcmd\TOTALCMD.EXE
C:\WINDOWS\system32\notepad.exe
H:\sigurnosni\HijackThis.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {0F01FF26-18F5-4613-BFD6-14DE2FBA24C3} - C:\WINDOWS\system32\nnnoonm.dll (file missing)
O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - C:\PROGRA~1\SPYWAR~1\tools\iesdsg.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_09\bin\ssv.dll
O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll
O2 - BHO: (no name) - {D38439EC-4A7F-42b4-90C2-D810D7778FDD} - C:\WINDOWS\system32\wqjxpftn.dll (file missing)
O2 - BHO: (no name) - {E8658363-94EA-4A98-B794-A1C0833970D0} - C:\WINDOWS\system32\mljji.dll (file missing)
O2 - BHO: WeeklyExecuter Class - {f015f320-ab08-11db-abbd-0800200c9a66} - (no file)
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [BDMCon] "C:\Program Files\Softwin\BitDefender10\bdmcon.exe" /reg
O4 - HKLM\..\Run: [Logitech Hardware Abstraction Layer] KHALMNPR.EXE
O4 - HKLM\..\Run: [Kernel and Hardware Abstraction Layer] KHALMNPR.EXE
O4 - Global Startup: Logitech SetPoint.lnk = C:\Program Files\Logitech\SetPoint\SetPoint.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
O18 - Protocol: bw+0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw+0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw-0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw-0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw00 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw00s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw10 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw10s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw20 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw20s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw30 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw30s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw40 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw40s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw50 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw50s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw60 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw60s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw70 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw70s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw80 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw80s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw90 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw90s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwa0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwa0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwb0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwb0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwc0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwc0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwd0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwd0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwe0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
Staro 05.03.2007., 23:31   #11
Barny
Postovi: 78
O18 - Protocol: bwe0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwf0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwf0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
O18 - Protocol: bwg0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwg0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwh0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwh0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwi0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwi0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwj0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwj0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwk0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwk0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwl0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwl0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwm0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwm0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwn0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwn0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwo0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwo0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwp0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwp0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwq0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwq0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwr0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwr0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bws0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bws0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwt0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwt0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwu0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwu0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwv0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwv0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bww0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bww0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwx0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwx0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwy0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwy0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwz0 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwz0s - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: offline-8876480 - {0448EEA0-2BC3-4099-8D45-4680A69A29BD} - C:\Program Files\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~1\COMMON~1\Skype\SKYPE4~1.DLL
O20 - Winlogon Notify: MCPClient - C:\PROGRA~1\COMMON~1\Stardock\mcpstub.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: AVG E-mail Scanner (AVGEMS) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgemc.exe
O23 - Service: BitDefender Scan Server (bdss) - Unknown owner - C:\Program Files\Common Files\Softwin\BitDefender Scan Server\bdss.exe" /service (file missing)
O23 - Service: Canon Camera Access Library 8 (CCALib8) - Canon Inc. - C:\Program Files\Canon\CAL\CALMAIN.exe
O23 - Service: BitDefender Desktop Update Service (LIVESRV) - Unknown owner - C:\Program Files\Common Files\Softwin\BitDefender Update Service\livesrv.exe" /service (file missing)
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared files\RichVideo.exe
O23 - Service: PC Tools Spyware Doctor (SDhelper) - PC Tools Research Pty Ltd - C:\Program Files\Spyware Doctor\sdhelp.exe
O23 - Service: Ulead Burning Helper (UleadBurningHelper) - Ulead Systems, Inc. - C:\Program Files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
O23 - Service: BitDefender Virus Shield (VSSERV) - Unknown owner - C:\Program Files\Softwin\BitDefender10\vsserv.exe" /service (file missing)
O23 - Service: BitDefender Communicator (XCOMM) - Unknown owner - C:\Program Files\Common Files\Softwin\BitDefender Communicator\xcommsvr.exe" /service (file missing)
Staro 06.03.2007., 09:51   #12
domy_os
domy_os's Avatar
Postovi: 18,916
Očekivao sam da si pročitao onu temu o HijackThisu, sad bi sve znao. Ukratko: skeniraš, staviš log (OK, stavio si) i opet skeniraš, ali bez loga te označiš ovo za uklanjanje:
Imaš milijun unosa (Extra protocols and protocol hijackers) od Logitech Desktop Messengera kojeg nisi morao ni instalirati, ako ga ne koristiš.
Zašto imaš dva antivirusa? BitDefender i AVG? Nije ti nijedan firewall aktivan...
Staro 06.03.2007., 18:03   #13
Barny
Postovi: 78
Ma pročito sam ja al nisam skužio to o označavanju i popravljanju.
Imam dva antivirusna nakon pokušaja da očistim komp od gamadi. No nije bar po meni loše imati različite samo kaj drugog uključujem po potrebi, mislim ak jedan omane jel...
a firewall imam kroz BD i uvjek je upaljen jedino možda kad sam log radio BD je mogao ostat iskopčan jer sam prije toga vrtio drugi antivirus.
E sad od svega mi je ostalo i neda se izbrisati ovo:
O17 - HKLM\System\CCS\Services\Tcpip\..\{E1621B89-6EB6-43C9-A459-BE19B61B8EB6}: NameServer = 213.191.128.8 213.191.128.9
Nemrem obrisat ovo od BD.
Ajd još to pa si samnom gotov
Staro 06.03.2007., 18:11   #14
domy_os
domy_os's Avatar
Postovi: 18,916
Pa tko ti je rekao da to brišeš? Pogledaj dobro gore...
Staro 06.03.2007., 18:18   #15
Barny
Postovi: 78
Pa to si napisao al neide
Da budem jasniji svi od BD sa file missing neidu van ostalo je otišlo.
Staro 06.03.2007., 18:40   #16
domy_os
domy_os's Avatar
Postovi: 18,916
Onda OK, to i tako nije bitno. Mislio sam da si htio to sve obrisat...
Staro 06.03.2007., 18:42   #17
Barny
Postovi: 78
je ovca jesam al baš tolika... ha nikad se nezna...
Ok hvala ovo ostavim i za sad sam čist... moj naklon!
Staro 06.03.2007., 18:54   #18
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Hm, ipak mala napomena. Nikako, ali apsolutno nikako ne valja imati više od 1 antivirus programa. Iste komponente sistema trebaju dva anti virus programa i što misliš što se desi kada ne mogu doći do nečega jer ga onaj drugi AV svojata? Kuršlus, kratki spoj, ršum, sranje. Dobiješ totalno suprotan učinak od očekivanog; imam dva antivirusa; ne radi nijedan kako spada.
Jedan antivirus, pametno podešen, nešto protiv spay-a i obavezno, možda i važnije engo AV firewall. Comodo npr. poprilično dobar u zadnje vrijeme.
tor je online   Reply With Quote
