Staro 28.02.2007., 13:26   #1
lemaan
lemaan's Avatar
Postovi: 8
toshiba ili hp
toshiba
A100-847 Zaslon15,4" WXGA LCD Toshiba TruBrite TFT display
Rezolucija 1280x800 ProcesorIntel® Core™2 Duo Processor T7200, 2.0 GHz
Front Side Bus : 667 MHz
2nd level cache : 4 MB HDDHard Disk 100 GB Optički uređajDVD Super Multi drive (Double Layer) Memorija512 MB DDR2, (533 MHz)
Nadogradivo do 4 GB GrafikaOdvojena, NVIDIA® GeForce™ Go 7600, 256 MB Fax modem56 Kbps V.92 Mrežna karticaEthernet LAN 10/100 Base- TX
Intel PRO/Wireless 3945ABG Multimedia16-bit stereo
Harman Kardon® stereo zvučnici
Toshiba Bass Enhanced Sound System with SRS® TruSurround XT™ System and SRS® WOW I/O1 x DC-in, 1 x external monitor, 1 x RJ-11, 1 x RJ-45, 1 x TV-out (S-video), 1 x i.LINK® (IEEE 1394), 1 x external microphone, 1 x headphone (stereo), 4 x USB 2.0, 5-in-1 Bridge Media slot (supports SD™ Cards, Memory Stick®, Memory Stick Pro™, MultiMedia Card™, xD-Picture Card™), PC Card slot for 1x Type II card, type : Express Card™ slot Dimenzije360 x 267 x 29.8 (front) / 36.8 (back) mm Masa2.72 kg OSMicrosoft® Windows® XP Home Edition OstaloIntegriran Bluetooth
ili hp
nx9420 (RH436EA) Zaslon17" WSXGA+ TFT
1440 x 900 rezolucija ProcesorIntel Core 2 Duo T5500 1,66GHz, 2MB L2, 667MHz HDD80 GB, 5400 rpm Optički pogonDVD+/-RW Dual Layer Memorija512MB DDRII 667MHz
Nadogradivo do 4 GB GrafikaOdvojena, ATI Mobility Radeon X1600
256 MB memorije Fax modem56K Modem Mrežna karticaBroadcom Gigabit 10/100/1000
Intel® Wireless LAN 802.11a/b/g MOW2 MultimediaSound High Definition, Audio 24 Bit Audio DAC
Integrirani stereo zvučnici I/ORJ 11, RJ 45, 4 x USB 2.0, VGA, S-Video-TV, IEEE 1394a, priključak za docking, 7-in-1 Media Reader,audio ulazi/izlazi, PCMCIA Type I/II PC Card Dimenzije393 x 275 x 33 mm Masa3.35 kg OSMicrosoft® Windows® XP Home OstaloIntegriran Bluetooth modul!
Integrated TPM Security Module
8-cell Lithium-Ion battery
Treba mi i za igre osim ostalog,da napomenem da ću ga prenositi,ne toliko često ali ipak par puta godišnje,avioni,busevi itd,i biti će dosta izložen vibracijama,ili možda imate neki bolji model do 10000kn,napominjem da bi i igrao na njemu.Hvala
lemaan je offline   Reply With Quote
Staro 28.02.2007., 23:49   #2
igx
Datum registracije: Mar 2002
Postovi: 258
ovo ti malo prelazi granicu ali kad se radi o prenošenju daleko je izdržljiviji od ova dva. može se nači i po 12000kn
http://www.mikronis.hr/shop/item.asp...=4376&catid=16
ili ovaj
http://www.mikronis.hr/shop/item.asp...=4762&catid=16
igx je offline   Reply With Quote
Staro 02.03.2007., 09:57   #3
lemaan
lemaan's Avatar
Postovi: 8
Stvarno su dobra oba 2 koja si mi ponudio,nisam uopće gledao IBM nekako su me odbijali,ali vjerojatno su najkvalitetniji,imaju dobru rezoluciju,mogao bi se malo strpiti pa vidjeti za onaj od 12000.hvala.
Staro 02.03.2007., 11:13   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Zbog harman kardona bi rekao toshiba, ali zbog ekrana HP ostalo jesve podjednako.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 02.03.2007., 11:26   #5
Mar
Suit up!
Mar's Avatar
Postovi: 5,963
Meni tošibe imaju ljepši ekran od HP-a (iako imaju onaj filter).
No HP je manje delikatan što se tiče izrade.
- Barney Stinson
Mar je online   Reply With Quote
Staro 02.03.2007., 21:54   #6
igx
Postovi: 258
toshiba ima sigurno bolji ekran ali je sjajan šta dosta smeta pogotovo kad se radi na bateriji i kad je osvjetljenje slabije.
toshiba definitvno izgleda najljepše ali jednostavno je "premekana", bar za moj ukus. poklopac je tako slab da možeš dotaknuti matricu kad malo jače pritisneš (nije ni HP puno bolji) i vidjeti dugine boje na ekranu. tako nešto se na IBM-u neče dogoditi, pogotovo ne na z61m sa titan poklopcem.
meni je izrada uvjek bila prije dizajna i nakon thinkpad-a sve mi izgleda loše.
@lemaan savjetujem ti da otiđeš negdje pogledati te laptope u živo, pogotovo z61m jer zbog tog titan poklopca izgleda odlično
Staro 02.03.2007., 22:36   #7
syss
syss's Avatar
Postovi: 10,805
ovog 17" se ne buš nanosao uokolo... kak je kolega gore rekao pogledaj ibm-a, mogao bi ti potrajati
Staro 02.03.2007., 23:02   #8
lemaan
lemaan's Avatar
Postovi: 8
Bio sam danas u vemilu baš pogledati taj IBM,bila je gužva a nisam imao vremena,ali mogu ti reći da sam se zapalio za taj ibm.Nije problem u nošenju,nosim ga svaka 2 mj onda opet miruje tih 2mj,jedino vibracije(brod),ostalo nije frka.Možda stvarno uštedjeti još malo pa na ibm,dobra je rezolucija.
Staro 03.03.2007., 08:23   #9
syss
syss's Avatar
Postovi: 10,805
ako bi išao iskeširat tolko love, onda bi mi taj ibm bio pri vrhu definitivno.
