Staro 09.02.2007., 12:41   #1
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
(riješeno) IE6 problem
Ovako, frend je nešto zeznuo sa Internet Explorerom. Instalirao je software sa onog Vip cd-a koji se dobije kad kupiš mobitel u Vip paketu. Uglavnom sad kad otvori IE piše mu "Microsoft Internet Explorer provided by Vip onlione". Kak se to makne???
Zadnje izmijenjeno od: Lud76. 09.02.2007. u 20:27. Razlog: ...
Lud76 je offline   Reply With Quote
Staro 09.02.2007., 12:54   #2
domy_os
domy_os's Avatar
Postovi: 18,931
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 09.02.2007., 15:22   #3
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Hvala ti. Jel se može to sredit sa demo verzijom programa??? Ak se deinstalira program jel se postavke vraćaju na default???
Staro 09.02.2007., 16:32   #4
Postovi: 23,595
Changing the IE and Outlook Title Bars
To change the IE Title Bar:
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE\Software\microsoft\Internet Explorer\Main
  3. Add or edit the string value Window Title (there is a space between the words)
  4. Add the text you want to appear
To Change the Outlook Title Bar
  1. Start Regedit
  2. Go to HKEY_CURRENT_USER\Software\Microsoft\Outlook Express
  3. Add or edit the string value WindowTitle (there is no space)
Removing a Branded Logo from IE
If a vendor has replaced the normal Internet Explorer spinning logo with their own,
it is very easy to set it back to the default without editing the registry directly.
  1. Go to Start / Run
  2. Enter in rundll32 iedkcs32.dll,Clear
  3. Now start up your browser and the spinning logo will be back to the default.
Staro 09.02.2007., 20:25   #5
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Hvala i tebi Nikky, problem je rješen
