Staro 26.01.2007., 02:50   #1
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Test/Usporedba: Logitech Z-2300 ...VS... Z-5500
Prije nego počnem moram napomenut da ne bi bilo neželjenih postova u obliku spama i slično.
Oba zvučnika nemaju veze sa Hi-Fiom ovo su zvučnici za komp pa ćemo to gledat sa te strane.
Testna konfa iz siga sa tim da moram napomenut, zvučna kartica je X-Fi Extreme Music, integriranu nisam koristio jer osim što nema smisla spajat takve zvučnike na integrirano smetje ne vidim neku potrebu za korištenjem iste.
Zašto sam se odlučio za ovaj test:
Z-2300 su dosta isplativi i ujedno jedni od najjačih 2.1 sistema za komp, a Z-5500 su jedni od opčenito najjačih sistema za komp i ujedno i vrlo kvalitetni.
Pošto prelazim sa Z-2300 na Z-5500 odlučio sam usporedit jedan do drugog kvalitetu, mogučnosti, jačinu i na kraju krajeva isplativost.
Ajmo redom:
SPECIFIKACIJE:
Z-2300
Total FTC power: 200 watts RMS
Sub-woofer: 120 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD)
Satellites:
Left/Right: 40 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)
Total Peak power: 400 watts
Frequency response: 35Hz - 20kHz
Amplifier: Ultra-linear, high capacity analog
Drivers:
Satellites: 2.5" polished aluminum phase plug driver
Subwoofer: 8" long-throw ported driver with 6th order bass reflex enclosure
Z-5500
Total FTC power: 505 watts RMS
Sub-woofer: 188 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD)
Satellites:
Left/Right: 62 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)
Center: 69 watts RMS (into 8 ohms, @ 1kHz, @ 10% THD)
Rear Left & Right: 62 watts RMS x 2 (into 8 ohms, @ 1kHz, @ 10% THD)
Total Peak power: 1010 watts
Maximum SPL: >115 dB
Frequency response: 33 Hz — 20 kHz
Amplifier: Ultra-linear, high-capacity analog
Signal to noise ratio: >93.5 dB, typical 100
Input impedance: 8,000 ohms
Drivers:
Satellites: 3” polished aluminum phase plug drivers
Subwoofer: 10” high-excursion ported driver with 6th order bass reflex enclosure
Ovo je C/P sa Logitechove službene stranice.
PAKIRANJE:
Z-2300
Kutija je sa obzirom što ima unutra dosta velika, i podosta teška cca 16kg.
Sve je puno stiropora, zvučnici su jako dobro zaštičeni, tako da i neki "jači transport" ne bi smetao.
Sadržaj: Kabel za napajanje, daljinac, 2 satelita, sub, nastavak ženski 3,5mm jack na 2 muška cincha i upute.
Z-5500
Ogromno, teško i veliko. Te tri riječi najbolje opisuju kutiju najboljeg Logitechovog modela.
Zaštita je ista kao kod slabijeg brata a i sadržaj je vrlo sličan.
Sadržaj: Kabel za napajanje, control centar, 5 satelita, sub, 3 x 3,5m kabla, 2 x 7,5m kabla, 3 x 3,5mm jacka, daljinski i baterije.
SATELITI:
Z-2300
Pristojne težine, dosta oštrih rubova (nisu zaobljeni što im daje elegantni izgled), zaštitna mrežica. Kad se ta mrežica skine ne gubi se elegantni izgled.
Na sub se spajaju preko cincha, zadovoljavajuče dužine kablova pošto se ovdje radi o 2.1 sustavu.
Kad se sistem spoji na računalo poznato je da večini satelita sa samo 1 driverom fali srednjih tonova, u ovom slučaju je obrnuto, fali visokih tonova dok srednjih ima dosta, to se bez problema sredi sa podešavanjem Equalizera.
Zvuk je čist ali kad se dosta pojača membrana od satelita se jako miče i to rezultira lošijom kvalitetom zvuka (ovo je bila granica tih zvučnika kad se počne gubit kvaliteta, ništa pretjerano al se čuje).
Z-5500
Teži i jači od Z-2300 satelita, malo zaobljeni i izgledaju pomalo debelo, bolje izgledaju bez mrežice.
Odlična stvar kod ovog modela su ne baš najidealnije rješenje a to su clip hvataljke, kabel koji dolazi sa zvučnicima je aluminijski al se po potrebi kasnije lagano zamjeni sa bakrenim.
Kad se spoje vidljiv je manjak srednjih tonova, dok su visoki čistiji od Z-2300, rješenje za srednje isto -> Equalizer.
Kod veće glasnoće manjak srednjih više dolazi do izražaja ma da kad se normalno sluša sve je ok.
Sa zaštitnom mrežicom (lijevi je Z-2300 desni Z-5500)
Bez zaštitne mrežice
SUB:
Z-2300
Velik i težak, sa pasivcem na stražnjoj strani, membrana od 20cm jačine 120W uredno obavlja svoj posao i trese kad mora, nakon pola sata intenzivnog glasnog slušanja pasivac je vruč.
Bas je klasnično hladan i tvrd što je odlika bass reflex zvučnika.
Z-5500
Prevelik i pretežak, pasivac duplo veči od onog na Z-2300, membrana od 25cm i 188W trese i grmi, nema onog efekta da kod slušanja muzike bruji što sam imao slučaj doživjet kod jednog 5.1 sistema zbog prevelikog raspona frekvencije suba.
Još nisam imao priliku dugo i jako slušat da vidim kak se grije pasivnjak jer ipak ne živim sam
Brat do brata:
Odostraga:
CONTROL CENTRI:
Z-2300 Daljinski
Ima 2 kotača, jedan za master volume i drugi za bass, spaja se preko 3,5mm jacka u zvučnu, i ispred ima također 3,5mm jack za slušalice, sa doljnje strane imaju gumice tako da se ne skliže po stolu.
Z-5500 Control Centar
Jako velik sa dekoderom, displayjem, par gumbi i jako zgodnim potenciometrom, na stražnjoj strani ima 3 ulaza, 3 x 3,5mm jackove, Coaxialni i Optički.
Daljinski je ok, gumbi taman za sve potrebno, isto to se može na CCu podesit ali mi jako smeta što je neprecizan i potrebno je ravno usmjerit daljinski da bi radio, šteta.
Muzika:
Bilo je svakakve muzike na testu, neke prevelike razlike u sistemima i nije bilo (sa tim da su Z-5500 bili spojeni analogno isto kao i Z-2300) najviše što se osjetilo je to da Z-5500 imaju čišće visoke.
Mali problem kod testiranja je bio zbog razlike u satelitima jer jednima fali visokih a drugima srednjih.
Za nekog tko ima malo prostora na stolu gdje se nalazi PC i treba samo stereo zvučnike malo veće snage Z-2300 su pravi izbor, naravno malo podešavanja EQ je obavezno al to se podrazumijeva.
Filmove i to nisam baš testirao jer nema smisla pošto se radi o 2.1 i 5.1 sustavima ali na tom polju zbog dekodera i nakraju samog surrounda pobjedu odnosi Z-5500.
Prednosti (pišem i za jedne i za druge)
* kvalitetan zvuk, glasnoća
* veličina i izgled
* control centar (Z-5500)
Mane (pišem i za jedne i za druge)
* makar nije tako strašno puno bi se više profitiralo sa 2 drivera u satelitima
* manjak srednjih kod Z-5500 kod glasnijeg slušanja
Mišljenje:
Ova dva sustava su me jako ugodno iznenadila, ako se ide na kvalitetu onda se neće gledat PC zvučnici nego Hi-Fi ali usudio bi se reći-> Hi-Fi PC zvučnici.
Cijena je opravdana u oba slučaja jer oba sistema nude dosta.
Za one koji žele da mogu po potrebi pojačat malo više a ne treba im 5.1 sustav preporuka za Z-2300 (cijena oko 1100kn) dok ostali neka kod nekog poslušaju Z-5500 jer osim spajanja na komp imaju mogučnost spajanja na PS2, Xbox, DVD player, reciver..
Nisam išao previše u tehničke detalje jer osim što je bio review oba sistema mislim da nije bilo potrebe.
žmnpp
buljo je online   Reply With Quote
Staro 26.01.2007., 02:57   #2
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Dobar review
Lijepo je vidjet usporedbu ta dva sustava, bok uz bok
Staro 26.01.2007., 10:41   #3
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
Svaka čast. Napokon da je netko to napravio.
Member of [SW]' CoD2 clan. Join us!
Moji DIY projekti i sl.: http://vidosprojects.freei.me/
Vido je offline   Reply With Quote
Staro 26.01.2007., 10:56   #4
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
a je ti jaki review, kakav amaterizam, pih....
P.S. ma aj, nije tako loše. : cheers2
Staro 26.01.2007., 15:09   #5
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Autor Gabre Pregled postova
Nije neš extra al eto ipak je neka usporedba.
žmnpp
Staro 26.01.2007., 15:49   #6
g-25
Postovi: 19
Autor buljo Pregled postova
svaka cast dobar review...bolje bi bilo da su bili z5400 vs z5500
g-25 je offline   Reply With Quote
Staro 26.01.2007., 16:04   #7
spawn
spawn's Avatar
Postovi: 8,483
Autor g-25 Pregled postova
E ovo bi bilo jako dobro. A ovaj review je dobrodosao. Taliko su se ljudi pitali,pa eto sad iz prve ruke.
Staro 26.01.2007., 16:13   #8
joga bonito
joga bonito's Avatar
Lokacija: Vukovar
Postovi: 436
Super usporedba lijepo si opiso i obradio!
bilo bi super kad bi netko Z-5400 vs. Z-5500
Mene zanima kako zvuce Z-5500 bas bi ih volio cuti ali kad niko od frendova nema a zanima me kakav je zvuk uzivo sta nude za tu skupu cijenu od 2500kn ali sam siguran da vrijede toliko!!
Kad bi prodo nekom svoje Genius 5.1 5000 i kad bi mi stara jos nadodala novaca i ja bi si uzeo Z-5500 mada su mi i ovi predobri!!! Z-5500 samo ono razmisljam da bi ih kupio ali nevjerujem samo cu si kupit audigy 4 i ovi moji zvucnici su mi s tom zvucnom predobri nista mi vise ne treba: cheers2
joga bonito je offline   Reply With Quote
Staro 26.01.2007., 16:13   #9
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Koliko sam ja čitao po netu Z-5500 imaju bolje satelite i puno su jači, ostale razlike su dosta male.
žmnpp
Staro 26.01.2007., 18:43   #10
amd freak
Lokacija: Zabok
Postovi: 543
Ewo ja imam Z-5400.....i danas sam stavio philipsove zvučnike od linije umjesto ona prednja 2....eeeeeeeeee...koji zvuk..koja razlika....majka!!!!Budem to ovaj vikend poslikao....snimio video....pa čemo malo prodiskutirat.....s time da sam stavio samo 2 jača i veča zvučnika....a kamoli da sam stavio još 3 takva....aaaaaa...ludnica...
amd freak je offline   Reply With Quote
Staro 26.01.2007., 18:56   #11
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Pa treba racunat da je pojacalo ugradjeno u sub dosta jako.
Staro 26.01.2007., 19:02   #12
amd freak
Lokacija: Zabok
Postovi: 543
AL fakat sam se iznenadio....e sad samo ovisi da staviš neke bolje zvučnike i od tih..tipa za hi-fi kako bi se to ponašalo....
Staro 26.01.2007., 19:06   #13
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma nema smisla kupit Z-5500 pa stavljat neke druge zvucnike. Mada nije nemoguce.
Dobar receiver je 2000kn, sto je jeftinije od jednog Z-5500. Istina, sa Z-5500 dobijes dobar sub. Znaci ako imas volje ubacis bar sprijeda dva iole bolja zvucnike i itekako moze bit bolje.
Imas pravo.
Staro 26.01.2007., 19:46   #14
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
nema smisla ni logike.
jer je onda jednostavnije i kvalitetnije odmah kupiti 2 bookshelfa za 100kn, i još sub k njima u par za 1500kn, i ta kombinacia pojede te logiteche kako god pogledaš....
Staro 26.01.2007., 20:07   #15
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Buljo svaka čast na rewiewu, ja se baš interesiral za ta 2 sistema, i nigdi na netu nisam baš našo slike sa stražnje strane subova, tak da mi to puno znači da vidim kak se spaja, također sad sa mkonačno videl razliku u njihovoj veličini, jer na slici izgledaju jednaki
Bilo bi još fino 5500 usporedit tak sa 5400 ili 5450
Konfa: Intel Core 2 Duo E 6400, 2.72GHz || Asus P5B Deluxe || 8800 EVGA GTS 320 mb || Super Talent 2x1 gb 800MHz CL5 || Seagate Barracuda 7200.10 320 GB 16 mb || Samsung Spinpoint F1 750 GB 32mb || Seasonic S 12 430W || A+ X-Blade || Logitech Z 5500 || CL X-Fi Xtreme Game || Logitech G500 || Logitech UltraX Flat Desktop || Canon Pixma iP4300 || Samsung ML-2510 || Toshiba Regza 32XV733G
Poggiali je offline   Reply With Quote
Staro 26.01.2007., 20:51   #16
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ima smisla. Ako vec imas recimo dva solidna bookshelfa, nista te ne kosta isprobat ih kako zvuce na Z-5500. A kad kupis Z-5500 vec dobijes vrlo dobar sub+5.1 pojacalo(da ne kazem receiver, jer ne prenosi i sliku).
Staro 26.01.2007., 21:39   #17
Rain Man
Lokacija: x
Postovi: 1,447
z5500 su vrh ponude za racunalne zvucnike pa i sire. Svakome preporuka. Iako moje trenutno zamjenile philips slusalice radujem se kad cu kupit vece dijagonale LCD i spojit pa preko njih slusat 5.1 DD. Iako je za mene i vrstu glazbe koju slusam bas dosta "izrazen". No to treba slusat i vidjet kolika je to razlika od "obicnih" 5.1 sistema.
Rain Man je offline   Reply With Quote
Staro 27.01.2007., 15:32   #18
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Evo jedna pjesma koja mi je jedna od obaveznih kod testiranja
Darude- Touch Me Feel Me
Što kvalitetnije to bolje
Skinite si da skužite od ćemu pričam, nije neki techno nego baš raspon frekvencija od najviših do najnižih.
žmnpp
Staro 27.01.2007., 17:02   #19
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
Je'l zna netko koji je pravi proizvođač drivera za Z-2300. Zanima me pogotovo sub. Htio bih vidjeti kako izgleda straga (driver). Malo glupo ali me zanima.
Zadnje izmijenjeno od: Vido. 27.01.2007. u 20:41.
Staro 27.01.2007., 20:32   #20
spawn
spawn's Avatar
Postovi: 8,483
Danas sam spojio sony mp3 player od T-com-a na Z2300. Zvuk je odlican ,10 puta bolji od moje AC97 zvucne.
Staro 28.01.2007., 18:35   #21
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Di su u Zg-u najjeftiniji z 5500?
U diskontu 24 ili ima di jeftinije ?
Staro 28.01.2007., 18:36   #22
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
žmnpp
Staro 28.01.2007., 18:47   #23
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Pa u diskontu su 2390kn
Staro 28.01.2007., 19:14   #24
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Onda je valjda nova cijena, mislim da ih ispod 2390kn nema.
žmnpp
Staro 29.01.2007., 10:40   #25
syss
syss's Avatar
Postovi: 10,805
Autor Vido Pregled postova
nekak mi na ove smrdi: http://www.tb-speaker.com/detail/1208_03/w8-670n.htm
Staro 29.01.2007., 12:02   #26
Vido
[SW]'V^idO
Vido's Avatar
Postovi: 424
To bi mogao biti sub po izgledu, ali zar nije nekako preslab:
RATED POWER INPUT 70 W
MAXIMUM POWER INPUT 140 W
Z2300 RMS: 120W
PMPO: 240W
Ovo prvo bi bilo RMS, a ovo drugo PMPO ili ja to krivo čitam. Ako je tako onda je ovaj sub morao biti pojačan mnogo...
Malo mi to sve nije jasno. Može objašnjenje?
Staro 30.01.2007., 15:30   #27
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Ne znam koju glazbu je autor slušao, ali i na 2300 se jako osjeti loš mid-range. ali i dalje su zvučnici predobri, definitivni best buy.
mrga je offline   Reply With Quote
Staro 31.01.2007., 00:57   #28
syss
syss's Avatar
Postovi: 10,805
@vido... ima tu teža problematika... kako je testiran driver, kako je testiran logi sistem etc.
Staro 19.02.2007., 18:56   #29
Poggiali
Rocker
Poggiali's Avatar
Lokacija: Zagorje
Postovi: 2,032
Ma slože se od MDF-a druge kutije, i dobi se na midlovima, jer driveri imaju potencijala, samo kaj su premale kutije i plastične
Staro 01.03.2007., 00:37   #30
legendarni
Spaljeni
legendarni's Avatar
Postovi: 288
jel ovakav port za priključivanje zvučnika ili ???
http://www.laaudiofile.com/images/z5500b.jpg
Jel možda postoje dvije vrste Z-5500 zvučnika?
legendarni je offline   Reply With Quote
