Staro 16.01.2007., 17:36   #1
kelson18
jakšimaš
kelson18's Avatar
Postovi: 180
Arrow Jel dobra konfa??
MATIČNA
MB ECS C51GM-M, sAM2, GeForce 6100, VGA SATA II, ATX 406,81KN
ModelNFORCE4M-A
Podržani procesoriSocket AM2 za AMD Athlon™ 64 FX / Athlon™ 64 X2 Dual-Core / Athlon™ 64 / Sempron™ processor
ChipsetNVIDIA nForce4 single chip
Memorija4 × DDR2 DIMM (Podržano do 32 GB memorije)
Dual channel DDR2 800/667/533/400 DIMMs
Utori1 PCI Express x 16 slot
2 PCI Express x 1 slot
3 PCI slots
I/O interni konektori1 x 24-pin ATX Power Supply connector
1 x 4-pin ATX 12V connector
1 x FDD connector
2 x IDE connectors
4 x Serial ATA connectors
1 x IrDA for SIR header
3 x USB 2.0 headers support additional 6 USB ports
1 x Front panel switch/LED header
1 x Front panel audio header
1 x CD in header
CPUFAN/NB_FAN/CASFAN connectors
I/O eksterni konektori1 x PS/2 keyboard & PS/2 mouse connectors
4 x USB ports
1 x RJ45 LAN connector
1 x Serial port (COM1)
1 x SPDIF out connector (optional)
1 x Audio port (Line-in, Line-out, Mic-in)
1 x Parallel port (LPT)
NapajanjeATX, ATX12V
DimenzijeATX 30.5cm x 24.4cm
OstaloRealtek RTL8201CL 10/100 Mbps Fast Ethernet PHY
Realtek ALC655 6-Channel audio CODEC
RAID0, RAID1& RAID 0+1 configuration
PROCESOR
CPU AMD Athlon64 3500+ BOX, Sck AM2 773,20KN
RAM
DDR2 512MB PC5300 (667MHz) Kingmax 410,29KN
GRAFIČKA
Gigabyte GF 7600GS PCIE, 256MB, TV out, DVI 828,93KN
TO je max cjena koju mogu platit... znači, ako želite nešto sugerirati... ne ići preko ove cijene...
hvala
: goood :
cijene su iz ve-mila... tamo ću najvjerovatnije kupovat
kelson18 je offline   Reply With Quote
Staro 16.01.2007., 18:12   #2
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
ok je ALI ja bi umjesto te graficke stavil gainward 7600 s DDR3 memorijom, dodje te 40kn vise a dobijes puno bolje performanse, zapravo dobijes 7600GT
none
Staro 16.01.2007., 18:20   #3
kelson18
jakšimaš
kelson18's Avatar
Postovi: 180
ma nije problem tih 40kn, ako će biti bolja grafa...
znači, to je ova:
Gainward BLISS 7600GS "G.Sample"
Gotovina / kartice: 868,09 kn
GPU GeForce 7600GS
Sučelje PCI-E 16x
Memorija 256MB DDR3 1,4ns
Radni taktovi GPU/RAM = 500/1200 Mhz
Konektori TV-out, DVI
Hlađenje Aktivno na GPU
Staro 16.01.2007., 19:32   #4
FERRYS
FERRYS's Avatar
Postovi: 2,159
Autor kelson18 Pregled postova
znači, to je ova:
GPU GeForce 7600GS
Sučelje PCI-E 16x
upravo ta
none
Staro 23.01.2007., 20:03   #5
Big Guy
RPG player
Postovi: 1,574
da ne otvaram novu temu
konfu je kupio moj frend za 8500 kn i naravno za igranje je
što mislite ovome:
e6600
asus p5n-e
7900gs
2x1024 super talent cl4
codegen 400W (s kučištem)
koja bi bila razlika u brzini ako se stavi još jedna 7900gs ili jača u sli?
nagovarao sam ga na bolje napajanje ali nije htio
napajanje radi i za sada nema problema, ali me brine stabilnost i pouzdanost, što mislite?
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 24.01.2007., 01:41   #6
kelson18
jakšimaš
kelson18's Avatar
Postovi: 180
prijatelju, mogao si si otvorit svoju temu. no HF...
jel još ko ima kakih primjedbi za konfu? kupit ću slijedeći tjedan
Staro 24.01.2007., 02:07   #7
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Konfa ok, kolko para tolko muzike
Autor Big Guy Pregled postova
što mislite ovome:
e6600
asus p5n-e
7900gs
Stabilnost i pouzdanost s ovim napajanjem? : nono :
Šaltaj to brzo... Forton, Čuftek(450W oko 380kn), iako bi uzeo najradje osbono uzeo Seasonica od 380W(cijene oko 400kn)
EDIT: Evo favorita http://www.links.hr/index.php?naziv=...kl=052.746.001
Matth€w je offline   Reply With Quote
Staro 24.01.2007., 12:51   #8
Big Guy
RPG player
Postovi: 1,574
@kelson18
sorry što pišem o frendovoj konfi u tvojj temi ali mislim da tema ionako neće postići jako puno postova kao npr tema Call of duty 2, pa mi se čini onda bezveze da otvaram temu za dva ili tri posta
@Matth€w
znam da je napajanje jadno i govorim to frendu već neko vijeme ali on misli da ga nagovaram na neku marku koja samo puno košta
treba mu dokazati da napajanje nije nešt posebno, pa ako ti ili netko drugi može pronaći ili zna gdje se može naći neki test codegena 400W da prijatelju dam usporedbu sa seasonicom 380W
prema njemu codegen 400 je dobro napajanje i jače je od seasonica 380W (još se i čudi zašto seasonic ima tako "glupu" snagu napajanja 380W, zašto ne 400W)
još sam mu rekao da je to stvarna snaga i da su odstupanja u seasonicu minimalna ali me ne sluša jer kao trgovac bolje zna
thnx
Staro 24.01.2007., 13:07   #9
Postovi: 33,978
@kelson
Uzmi Gigabyte M55plus-S3G. O njoj imaš više ovdje http://forum.pcekspert.com/showthread.php?t=51690
Staro 24.01.2007., 17:13   #10
Tovar Muš2
istrijan
Tovar Muš2's Avatar
Lokacija: Novigrad
Postovi: 141
Codegen... (dovoljne su samo ove tri točkice)
@ Big Guy testovi nisu potrebni da bi se shvatilo da to napajanje ne valja apsolutno ništa. Ja ga imam u mojoj kutiji i skoro da mi jednog dana sve izgori jer je ventilator jednostavno stao...nije bilo ulja, majku mu. Ma nikad više...Codegen, Medegen i slična s*anja.
Ciao.
Tovar Muš2 je offline   Reply With Quote
Staro 25.01.2007., 01:23   #11
kelson18
jakšimaš
kelson18's Avatar
Postovi: 180
Autor coconut Pregled postova
@kelson
ma knap sam sa lovom, nemam baš puno izbora... uzeo bih ja al, pare...
