Staro 20.01.2007., 00:43   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
NVIDIA BIOS Editor (NiBiTor) 3.2
Glantz novi:
http://fileforum.betanews.com/detail...r/1041348498/1
Main features
Detailed BIOS information output
Device ID
BIOS Version
BIOS Date
Vendor
Core/Memory Clock display
2D Core/Memory Clock
3D Core/Memory Clock
Throttling Core/Memory Clock
Core Voltage display
2D Voltage
3D Voltage
Throttling Voltage
Memory Timings display
Product Identification
Ability to modify the several BIOS Parameters
Core Clock defined within the BIOS
Memory Clock defined within the BIOS
Core Voltage defined within the BIOS
Memory Timings defined within the BIOS
Temperature Settings defined within the BIOS
Fan Speed Settings defined within the BIOS
Specific Boot Settings
Graphics Card OEM and Advanced Signon Message
Monitor Specific Parameters
Graphics Card Initiation Settings
TV Mode Selection (NTSC/PAL)
Ability to check BIOS Integrity
BIOS Checksum Checking
BIOS Structure Checking
Changes in this Version :
Added Support for GeForce Go 7950 GTX PCI-E
Added Support for Quadro FX2500M PCI-E
Added Memory Timing Support and Bootup Clock
GeForce 8800 GTS (G80)
GeForce 8800 GTX (G80)
This new version is build upon the logic of the previous version, with some minor fixes and a redesign of the Unknown devices support... As always for extra features, settings and support please provide us your Original BIOS.
Staro 20.01.2007., 00:46   #2
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
lijepo. hvala.
Ph03n1x je offline   Reply With Quote
Staro 20.01.2007., 00:56   #3
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nisam bas upoznat s tim, ali jel moguce s tim podic napon GPU-a i meme na 7300GT? Mema je 1.2ns a nece preko 1600MHz, fali joj soka
Staro 20.01.2007., 01:47   #4
nino
nino's Avatar
Postovi: 12,602
Autor SRV Pregled postova
: stoopid
Staro 20.01.2007., 11:43   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ok, glupo pitanje.
Staro 20.01.2007., 13:36   #6
Wolverine
Wolverine's Avatar
Postovi: 12,425
možeš ako kartica nema zašitu
npr na 7600/7900/7950 seriji ne možeš iz biosa mjenjat napone - mislim možeš ti postavit veći napon ali se on neće aplicirat već će ostat def
npr na 7900GT možeš ti stavit npr1,45v i takvog ga flashat ali bez obzira na to napon će ostat 1,2v
Te ćeš za stvarno povećanje napona morati posegnuti za volt-modovima (hardwareskim) za 7300 nisam siguran dal to radi ili ne ali mislim da je ista priča.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 20.01.2007., 16:18   #7
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Probao na 7300GT. Nece. Ne znam na kojem naponu je mema ali obzirom da je 1.2ns i nece preko 1600MHz bas i nije neki visok
U biti je na dodir mlaka, cak i overclockirana. To je jos jedan argument koji ide u prilog cinjenici da je ona na relativno niskom naponu.
Ma svejedno, nek ostane na 600/1600. Makar se ne grije puno.
Staro 20.01.2007., 16:23   #8
Wolverine
Wolverine's Avatar
Postovi: 12,425
def je 1,8V sad na koliko je kod tebe ne znam
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 20.01.2007., 18:47   #9
s56k
s56k's Avatar
Lokacija: Vk
Postovi: 69
kod mene ide bez problema na 1680, iz drivera ne da vise (doslovno, klizac na kraju )
no dobitak nije neki u odnosu na 1600, mozda 100 bodova u 3dmarku a to je mozda jedan fps vise po testu. visoki clock ne moze vjecno izvlaciti manjak pipeova.
s56k je offline   Reply With Quote
Staro 20.01.2007., 19:06   #10
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma da, grafa ionako ima visok takt memorije, ipak je GPU uze grlo. Ja sam svoj GPU digao na 600, cini mi se da moze jos malo al mi se ne da testirat
No ode ovo u OT.
Tema je o Nibitoru opcenito a ne o nasim nabrijanim 7300GT.
