#91 |
Lokacija: Lille, France
Postovi: 44
Just a small post to keep you guys updated ![]() OCCT PT is right now at 1.1.0.b09 , and will soon be released as... 1.0.3. I've delayed 1.1.0, and want to release an intermediate version, because the changes needed for 1.1.0 would take too long. This version brings many new features : *New, more effective Error detection algorithm *Multi-CPU temperature support *Custom temperature and voltages support *Modified graphic design *Maximum CPU Temperature *Hyperthreading as Dual-core Option ( i.e. treat a P4 HT as if it was a Dual-Core Pentium 4 ==> launch 2 threads ) It corrects some bugs, including the "Allendale" => "Conroe" one ![]() I've sent a mail to domy_os with the new translation to do (language files to update can be found in the latest beta zipfile, in the locale subdir). About 15 new strings ![]() Just feel free to tell me if you found any bugs ![]() http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b09.zip |
#92 |
Torrent freek
Postovi: 3,947
Downloading: boxers :
#93 |
Postovi: 44
Let me know how things are going for you ![]() |
#94 | ||
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Samo da napišem što je Tetedeiench napisao na XS-u ![]() Citiraj:
![]() @ Tetedeiench The 30 minute (auto)test isn`t best at generating errors because of instability, can you improve it somehow? Or is it just simpy made for getting those nice graphs under load ![]() EDIT: Can you make a plug-in for Core Temp, as it is the best programme for temperature measuring of K8 and C2D? Nice job on Everest plug-in ![]()
"Everything with a heartbeat can knock you down" Zadnje izmijenjeno od: Vuco. 04.01.2007. u 05:22. |
#95 |
Postovi: 18,862
Tetedeiench, you've got a mail... ![]() Za ostale: promijenio sam "prava brzina" u "originalni takt" i još neke sitnice...
#96 |
Torrent freek
Postovi: 3,947
#97 |
Postovi: 9,505
Ja ga nisam probao ![]() Samo sa vidio da je tamo... Ali bilo je riječi o tome što ne? Čini mi se kao da sam vidio taj error već negdje?
#98 | |
Postovi: 44
![]() ![]() The Auto test will be revamped soon (in 1.1.0). It'll include 1 hour of CPU&RAM, as well as 2 or 3 passes of the new memory checking algorithm. As for Core temp, i'll look into it, but there isn't any Shared memory or any way to get the readings out of the program... i can't promise you anything. i'll check ! 1.1.0 should bring :[*]New memory checking algorithm ( memtest-like, probably less effective though )[*]Revamped graphs ( especially the scales, probably unified )[*]New auto-test (at least one hour + memory checking algorithm) and more on the way... I'll try to look into Vista compatibility... as soon as i get my hands on a copy of Vista ![]() |
#100 |
Torrent freek
Postovi: 3,947
#101 |
Postovi: 9,505
#102 |
Torrent freek
Postovi: 3,947
#103 |
Postovi: 44
I don't quite understand what you guys are saying, but only Everest Ultimate 3.50 and above is supported ![]() |
#104 |
Torrent freek
Postovi: 3,947
#105 | |
Postovi: 9,505
Now we know ![]()
#106 |
Postovi: 44
Unfortunatly, i haven't found any way of detecting Everest's version before trying to enable Shared memory in it :/ I'm looking for a way to minimize Everest's window as well ![]() ![]() |
#107 |
to te ja pitam
Postovi: 572
OCCT ne raspoznaje točno C2D jezgre
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy 2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W ![]() |
#108 |
Postovi: 11,642
Allendale je zapravo Conroe sa 2mb cachea...zato ga cpu-z tako prepoznaje (starije verzije su ga prije prepoznavale kao allendale)...znači occt zapravo i najtočnije prepoznaje c2d ![]() |
#109 |
Lokacija: pž
Postovi: 1,291
#110 |
Postovi: 44
This bug was fixed in the latest beta (1.1.0). In 1.0.2, every Conroe will be reported as Allendale... |
#111 |
Postovi: 44
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b11.zip Beta 11, almost there for 1.0.3 stable ![]() Including the new translations (thanks domy_os ![]() Soon 1.0.3 ![]() |
#112 |
Premium moderator
Postovi: 4,600
Cool! Finally, Croatian translation, not quite that english bothers me, but it is always nice to see a program in your native language (thanx to domy for that) ![]() Time to update my prehistoric version of OCCT with this new one. I bet there will be no major problems in detecting my poor little old Northwood ![]() Hmmm but there is sth. that confuses me. At the Custom test Options it has a "hook"(I don't actually know how to say this in english, in Croatian it is called kvačica. Help guys ![]() Its not quite of an error, but it looks kind of strange when you don't have a HT processor ![]()
__________________ |
#113 |
Postovi: 9,505
Meni je to zasivljeno (ali je isto kvačica). Tako da, ne obazirem se na to. To je valjda po defoltu uključeno za procesore sa HT-om.
#114 |
Premium moderator
Postovi: 4,600
Yap zasivljeno je, ne smeta mi uopće nego eto, to mi je prvo palo u oko dok sam kopao po opšnsima programa ![]()
#115 | |
Postovi: 44
![]() It is enabled by default on HT CPUs because it gives better results... i could uncheck it if the CPU isn't HT-capable... i'll look into that ![]() |
#116 |
Premium moderator
Postovi: 4,600
Don't bother about that, I was looking around the options and that just cought my eye ![]() As I said, it's not an error or sth. like that ![]()
#117 |
Postovi: 44
#118 |
Premium moderator
Postovi: 4,600
Wow, that was really fast ![]() I'm impressed ![]()
#119 |
Postovi: 44
I have that reputation of being aware of my user's request ![]() I actually read someone, in France, asking for the "VCore, 3.3V,..." again in the GUI. I ended up revamping the GUI, even if i thought b11 was a RC... it is definitly not now ![]() Look at that screen shot : ![]() Now they're asking me to remove, in the Monitoring part, the blank space on the left where "CPU", etc, is, and extend every cell to full extent of the width... That's going to be a few hours... but mind you, i'll photoshop it first ![]() |
#120 | |
Postovi: 7,568
![]() I'm a bit late with the answer and seeing this thread, but better late than never. Regarding the thread and the effort put into OCCT all I can say is: goood : Keep up with the good work, both Tetedeiench and PcE members that are helping him. |
