Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 26.12.2006., 02:59   #1
Razer
Razer's Avatar
Postovi: 11,642
Asus Commando
Evo na Asusovoj stranici je napokon osvanula i vijest da je ova zvijer puštena u prodaju...sa OC rezama u rangu ponajboljih 965 ploča, hrpetinom điđa-miđa...čini se da je ova ploča uz svoju cijenu nešto posebno
Staro 26.12.2006., 03:23   #2
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
a di vidis cijenu? :?
Staro 26.12.2006., 03:25   #3
Razer
Razer's Avatar
Postovi: 11,642
Ne vidim cijenu (čitao sam nešto, ali neću davati krive informacije)...ali normalno da će cijena biti paprena...to je već postalo uobičajeno...
Staro 26.12.2006., 03:43   #4
mat
Postovi: 2,105
asus da proizvede govno bilo bi dobro
mat je offline   Reply With Quote
Staro 26.12.2006., 03:52   #5
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Evo par stvari koje me zanimaju kako rade..
SupremeFX - That Sounds Great!
The SupremeFX audio card is designed to provide you the best game sound experience. With 24bit/192kHz full sampling in all surround channels, no matter if you're hearing your game through headphones or 7.1 surround speakers, we'll deliver the effects loud and clear!
LCD Poster - Debug with translation
When system malfunction occurs, LCD Notice Board automatically detects for device failure and posts physical system errors on the LCD during POST. No more reading "gibberish to find out what's wrong.
Onboard Switch - No more shorting pins or moving jumpers
With an easy press during overclock, this exclusive onboard switch allows gamer to effortlessly fine-tune the performance without having to short the pins or moving jumpers!
žmnpp
Staro 26.12.2006., 03:54   #6
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Autor mat Pregled postova
a pisac je htio ovime reci da.... ?!?
Staro 26.12.2006., 13:38   #7
Conroe
Power Abuser
Conroe's Avatar
Postovi: 388
Conroe je offline   Reply With Quote
Staro 26.12.2006., 15:13   #8
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
Sta je tako specijalno oko ove ploce?
LCD na back panelu? Hmm.. baš korisno :/
- Barney Stinson
Mar je online   Reply With Quote
Staro 26.12.2006., 15:15   #9
Razer
Razer's Avatar
Postovi: 11,642
Staro 26.12.2006., 15:41   #10
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
u hebote
570 fsb-a
Staro 26.12.2006., 16:15   #11
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
dobra ploca za oc...al vec sam vidio i ds3 i ds4 i p5b deluxe na fsb 600
Ph03n1x je offline   Reply With Quote
Staro 26.12.2006., 17:05   #12
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
Autor Conroe Pregled postova
ovo je prema do sada [NE]viđenom moja sljedeća ploča, kupujem!!:clap:
Autor Razer Pregled postova
genijalno!!, to se već dugo čeka
Autor Ph03n1x Pregled postova
teško bez moddova...
bobe je offline   Reply With Quote
Staro 26.12.2006., 17:11   #13
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Znaci računaj u HR oko 2600kn.
Bas slatko
Staro 26.12.2006., 17:17   #14
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Autor Fleks Pregled postova
Bas slatko
P5B DL i P5W DL su prije koštale oko 1900kn tako da je realno bilo čekivat takvu cijenu, možda malo nižu.
žmnpp
Staro 26.12.2006., 17:20   #15
nicko
Postovi: 4,190
Bas slatko
Prije bi rekao oko 2000-2100kn...
Al svejedno preskupo....
Uopce mi nije jasno sto ce nekome tako veliki fsb???
Da naclocka proc 1 put za super pi....
nicko je offline   Reply With Quote
Staro 26.12.2006., 17:21   #16
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
Bas slatko
nebi se složio s ovim, jer cijene p5b deluxe se vanka kreću od 200-270$, a kod nas je 1700, tako da mislim da nema šanse da ova bude preko 2000, a ako i bude to će biti jako malo
edit:evo i nicko slično razmišlja
Staro 26.12.2006., 17:33   #17
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
Autor nicko Pregled postova
upravo tako. kakve koristi od toga?
Staro 26.12.2006., 17:36   #18
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Eventualno za visoki OC E6300..
žmnpp
Staro 26.12.2006., 17:37   #19
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
Autor buljo Pregled postova
eventualno. ali mora biti jako dobar primjerak i jako dobro hladenje da bar priblizno toliki FSB moze postici
Staro 26.12.2006., 17:45   #20
Razer
Razer's Avatar
Postovi: 11,642
Znaš i sam da nekim frikovima hlađenje nikad nije predstavljalo problem ...
Staro 26.12.2006., 18:16   #21
nicko
Postovi: 4,190
Pa radje za tu razliku od 600kn uzmes jaci proc i slabiju plocu....
Staro 26.12.2006., 18:26   #22
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
tak je...onda radje kombiniras e6600 s nekom solidnom plocom tipa ds4 i slicno...inace najbolje ga je kombinirat s necim tipa bx2, aw9d...ali ni one nisu bas jeftine
Staro 26.12.2006., 18:31   #23
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
ja već dugo tražim ploču koja bi dostojno zamijenila moju p5b, i još je nisam našao, zasada mi se ova ćini Ok, no daleko od toga da bih je odma kupio, treba pričekati prve testove pa da vidimo, no ipak se radi "samo" o 965 ćipsetu pa mislim da nikakva čuda ne treba očekivat
Staro 26.12.2006., 18:35   #24
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
Autor bobe Pregled postova
imas e6400...onda si uzmi neku dobru i975X plocu kao bx2 ili eventualno aw9d ako bas hoces mijenjat a nije ti od zivotne vaznosti postici sto veci fsb...
Staro 26.12.2006., 18:42   #25
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
upravo sam se dvoumio između ove dvije.....
....no u tome je problem...:clap:, ništa ćekam novi ćipset, za sada će i ova radit, ali ovo je već OT
