Staro 14.12.2006., 21:28   #1
AMDhammer
AMDhammer's Avatar
Lokacija: VT
Postovi: 367
Vantec NexStar3 2.5" USB 2.0 & ICY BOX IB-250StU & Samsung SpinPoint 5K100 100GB SATA
Vantec NexStar 2.5" External Case SATA to USB 2.0
Part Number: NST-260SU-BL
Features:
Aluminum Casing Cools Down Your Hard Drive
Transfer Rates upto 3Gbps w/ eSATA
Transfer Rates upto 480Mbps w/ USB 2.0 (12Mbps w/ USB1.1)
Easily Add Storage to Any System with SATA or USB
Hot-Swappable: Plug And Play without Rebooting
Attractive Blue LED Indicates Power/HDD Activity
Currently support upto 160GB hard drives
Interface: SATA to eSATA & USB 2.0
Color: Blue
System Requirements:
Intel Pentium II 350 MHz-compatible or Mac G3 processor & greater
Microsoft Windows 98SE/ ME/ 2000/ XP or Mac OS 8.6 & greater
USB or SATA-equipped system
For USB 2.0 speeds, the system must support USB 2.0 specifications CD-ROM drive (if drivers are needed)
Package Includes: Driver Disc, User Manual, 2.5" SATA HDD Enclosure, Power Cable, eSATA Cable, USB Cable, SATA to eSATA Bracket, Screws, Carrying Bag
Dimension: 132 x 80 x 15 mm
Samsung SpinPoint M60 SATA Series HM100JI
Features
GMR/TuMR head with wireless suspension design
Serial ATA 1.5Gbps Interface Support
SATA Native Command Queuing Feature set
Device Initiated SATA Power Management
Fluid Dymamic Bearing Spindle Motor Technology
Load/Unload Head Technology
ATA Security Mode Feature Set
ATA SMART Feature Set
ATA Automatic Acoustic Management Feature Set
Multi-Burst On-The-Fly Error Correction
SilentSeek™
Hybrid Latch System for Reliability and Quietness
Specifications
S-ATA 150GB/s NCQ
S-ATA 100.0GB disk size
5400 rpm/min
8MB buffer
Max. UDMA transfer mode UDMA-6 (133MB/s)
Max. PIO trensfer mode PIO 4
slike diska...
slike eksternog kucista...
cijena diska oko 700kn
cijena eksterne ladice oko 150kn
evo review kako napraviti mali, lagani, jednostavan za koristenje prijenosni disk s kojim necete morati nositi dodatna napajanje jer je dovoljno napajanje sto dobije iz USBa za njegov rad a iako nije dovoljno skoro s svakim eksternim kucistem ide i dodatno USB napajanje kao sto se vidi na slici
Zadnje izmijenjeno od: AMDhammer. 26.12.2006. u 00:21.
AMDhammer je offline   Reply With Quote
Staro 15.12.2006., 17:09   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ladica je pljunuta ista kao moja canyon samo druge boje. Isto tako i kablovi su isti.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 21.12.2006., 16:10   #3
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
Mislim da cu istu kombinaciju uzeti i ja, samo mozda ladicu uzmem Icy Box. Daj reci zasto si se odlucio za Nexstar (pretpostavljam da si malo proucavao ladice prije kupnje)?
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 23.12.2006., 12:32   #4
AMDhammer
AMDhammer's Avatar
Lokacija: VT
Postovi: 367
budem stavio slike i od icy box on ti je bolji od vanteca, vantec ti je malo jeftiniji ali nije bolji. razlog velicina, tj. debljina ladice je 3-4mm razlike izmedu vanteca i icy boxa, icy ima koznu futrolu i nekako je jednostavnije no budem ga jos opisao detaljnije. razlog kupovine vanteca je sto nisam naso icy box kada sam kupovao disk i ladicu. nabavio sam ga i staviti cu slike cim stignem - biti ce prije bozica pa budete vidjeli i icy box iz prve ruke
Staro 23.12.2006., 13:21   #5
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Evo ja sam baš jučer kupio zynet-a u Diska.
Cijena: 86kn - najjeftinija ladica kod njih.
Napravljen je od aluminja, dok su prednja i zadnja stranica napravljene od plastike, no obojane u srebreno tako da se niti ne primjeti.
Ladica je dosta čvrsta pod prstima jer je iz jednog komada (izuzev tih plastičnih "pokopaca").
Dobiješ "Y" kabel sa mini usb utorom (za ladicu), a najbolja stvar mi je dosta kvalitetna futrola u kojoj možeš držati ladicu prikopčanu.
Ladica je vrlo lagana, i iako icy box vjerojatno ima bolju čvrstoću, dosta je veći i teži, te ujedno s tim šteti funkcionalnosti 2.5" diska (malen & lagan).
Evo slika:
(kabel je crni - ovo je od fotoaparata)
P.S. E, da ovo je PATA a ne SATA ladica.
- Barney Stinson
Zadnje izmijenjeno od: Mar. 23.12.2006. u 13:44.
Mar je online   Reply With Quote
Staro 24.12.2006., 17:21   #6
AMDhammer
AMDhammer's Avatar
Lokacija: VT
Postovi: 367
evo i slika icy boxa - nadam se da ce biti dovoljne, ipak sam na netu modemom pa mi slike i nisu bas zabava za uploadati na net ali sto ces....
evo ih dajte mi neki program da iztestiram razlike u prijenosu da stavim i te slike ovdje.
Staro 24.12.2006., 19:48   #7
^SuperUnknown^
Prečupavi mod
Postovi: 9,107
Zgodno Daj reci jel bi mozda prodavao Nexstara?
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 24.12.2006., 20:24   #8
tutix
tutix's Avatar
Postovi: 4,069
Ja mislim da možda i bi
http://forum.pcekspert.com/showthread.php?t=55012
Staro 24.12.2006., 20:41   #9
AMDhammer
AMDhammer's Avatar
Lokacija: VT
Postovi: 367
e nebi vise, ladica je prodana ***ga... pa iz zga si ja sam vanteca uzeo u linksu a icy box u hgspotu. u hgspotu ju vode kao ICY BOX IB-251StU. IDE je IB-250 a SATA IB-251
Staro 24.12.2006., 20:43   #10
^SuperUnknown^
Prečupavi mod
Postovi: 9,107
A bas sam ti mislil ic nashtrikat PM Ma ljepse mi je prosetat se do poste po ladicu, nego gubit zivce po ducanima, al nema veze, zaletit cu se poslije nove god. odma i po disk i po ladicu
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 24.12.2006., 20:59   #11
AMDhammer
AMDhammer's Avatar
Lokacija: VT
Postovi: 367
ja sam narucio IDE ladicu vantec i IDE disk, ovaj samsungov, iz linksa a ovi meni posalji IDE ladicu i SATA disk, kazu mi zeznuli se meni bila hica reko ja disk mogu spojit na komp ali mi morate zamjeniti ladicu, kazu decki nema beda, posaljem im ja meni dode druga nazad, reko OK. tako da sam super prosao i dobio vantec SATA ladicu ali mi se nije svidala pa sam se vanteca rjesio i nabavio icy box sada uzivam jednio sto ICYju fali je Y USB kabal, ovako moras koristiti dva umjesto s Y jedan USB konektor ali radi super.
@ tutix
sretan rodendan
Zadnje izmijenjeno od: AMDhammer. 24.12.2006. u 21:20.
