Staro 01.10.2003., 18:46   #1
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
LILO (Linux)
da li neko zna kako podesiti LILO?
probao sam otvoriti lilo.conf ali nemogu editirati, kaže da nemam ovlasti...
distribucija je Mandrake 9.0
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 01.10.2003., 18:50   #2
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
ne znam sta bi htio podesiti, Lilo ili brub se konfigurira prilikom instalacije. Htio bi mjenjati ono sto s eboota po defaultu?
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 01.10.2003., 19:51   #3
Xan
Xan's Avatar
Postovi: 1,001
da
skužio sam da se moram logat kao root da imam ovlasti...
Staro 01.10.2003., 20:06   #4
Xan
Xan's Avatar
Postovi: 1,001
stavio sam da je po defaultu WinXP, ali mi iz nekog razloga ne prikaže LILO sve dok ne stisnem F8, a ako ne stisnem digne se XP
da li je timeout u lilo.conf da mi se odbrojava npr. 5 sec dok mi ne pokrene default OS?
ako nije šta je?
Staro 02.10.2003., 18:11   #5
Xan
Xan's Avatar
Postovi: 1,001
složio sam...
ali imam jedan drugi problem:
kada pokušam instalirati ATi-jeve drivere za grafičku, on mi prijavi ovaj error:
There was an error during package installation:
Problems occured during installation: file /usr/X11R6/lib/lib.GL.so.1.2 from install of fglrx-glc22-4.2.0-3.2.5 conflicts with file from package XFree86-libs-4.2.1-3mdk
ovo se dešava sa verzijama za 4.2.0 i 4.3.0 XFree86
Staro 02.10.2003., 20:03   #6
horza
ono ispred konpjuktora
horza's Avatar
Datum registracije: Apr 2003
Postovi: 3,659
Originally posted by Xan
složio sam...
ajde da budem glup... da nemaš možda dignute X-e ?
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 02.10.2003., 21:46   #7
medo
#erase startup-config
medo's Avatar
Postovi: 3,685
složio sam...
1.) pređi na Debiana
2.) Brijem da si podesio lilo da ti se boota iz particije, a ne iz MBRa. Stavi ga u MBR i pokazat će se prije windowsa i F8.
3.) Probaj GRUB. super je. iako i ja imam lilo na svojim serverima i kompovima.
Staro 02.10.2003., 22:00   #8
horza
horza's Avatar
Postovi: 3,659
i meni je grub ugodniji... bolje mi zgleda
Horza (death dwarf)
birthsign: rebel
character perks
major skills
greater powers
artifacts of choice
Staro 02.10.2003., 23:23   #9
Trash
Trash's Avatar
Datum registracije: Apr 2002
Postovi: 786
Iako je Debian puno bolja distribucija, za pocetnike je ipak bolji Mandrk ili RedHat.
Sto se tice greske oko instaliranja, to prouzrocuje neinteligentni ATi paket koji ne predvidja da najvjerojantije imas libGL (u sklopu Mese ili slicnog OpenGL drivera) pa rpm prijavljuje ovakve stvari.
Ako prijavljuje conflicte za samo taj fajl, backupiraj ga i oderi instalaciju ATi-jevih drivera sa --force opcijom. Uostalom, i tako i tako ces u periodu ucenja par puta reinstaliravati Linux tako da se nemoj zabrinjavati..
Trash je offline   Reply With Quote
Staro 04.10.2003., 09:37   #10
Xan
Xan's Avatar
Postovi: 1,001
pa jesam napisao da sam to složio...
bio sam stavio na 5 da mi odbrojava prije nego što pokrene default, a nisam znao da je to u desetinkama sekunda...
necu još sad isprobavat brub, cekaj da malo proučim ostale stvari...
e da, kako mogu promijeniti da određeni folder konfigurira kernel?
Staro 04.10.2003., 16:18   #11
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
složio sam...
A ništ...probaj tu:
http://www.rage3d.com/board/forumdisplay.php?forumid=61
Staro 10.10.2003., 15:23   #12
borgy
kenova
borgy's Avatar
Lokacija: München / Dubrovnik
Postovi: 919
cudno pitanje
mislis zelis instalirati kernel source? imas ga u rpm paketu na cdovima od distribucije, ili ga skini sa kernel.org (30tak mb)
borgy je offline   Reply With Quote
Staro 10.10.2003., 17:00   #13
Xan
Xan's Avatar
Postovi: 1,001
ma nisam tako mislio...
krivo je napisano u manualu od drivera za isdn adapter...
skužio sam već i sam...
