Staro 14.12.2006., 17:20   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Fujitsu Siemens L22-1W, 22" LCD Widescreen
Znaci vec sam bio za kupnju Samsung 940BW (19" wide), kad vidim u novom katalogu Metroa FS 22" wide monitor za 2430kn : nuts : : nuts :
Mislim ovo je fakat veliko, a ne preskupo. Jedino kaj mi malo smeta je to kaj nema DVI. Sad jel tak velika razlika u spajanju na 15 pin D-sub i DVI?
Ako je kupit cu Samsunga, ako nije razmislit cu o ovom FS-u.
Evo i link sa speckama:
LINK
Usporedba Samsung vs. FS
LINK
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 14.12.2006., 17:39   #2
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nemoj sr** 22" LCD 2400kn? Kupuj!
Nek nema DVI, kaj ce ti to
Staro 14.12.2006., 18:17   #3
h3lld
Disturbed
h3lld's Avatar
Lokacija: Bogu Iza Nogu
Postovi: 1,420
hm, tough call po meni ... mislim da je velicina definitivno na strani Fujitsu, ali mislim da je kvaliteta samog monitora vise na strani Samsunga ( ponosni vlasnik ), DVI ce te samo pucati ako se bavis obradom fotografija i slicno, ako samo casual igras igre i tako, nema razlike izmedju DVI i D-Sub bas neke velike, sitnice... ako te puca velicina uzmi FS, ako volis igrati sigurno uzmi Samsung.... uglavnom kako god, mislim da ces biti zadovoljan... ja znam da ja jesam sa Samsungom
-potpis-
h3lld je offline   Reply With Quote
Staro 14.12.2006., 19:06   #4
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ma i ja sam zadovoljan LG-jem ali za tu lovu je 22" FS odlicna kupnja
Staro 14.12.2006., 19:13   #5
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
e sad, stari mi kaze da na tu cijenu ide jos pdv, znaci to bi bilo 3000kn... ali ne znam jer ti uzimas preko firme ili ovako... kaze stari da na cijene u katalogu ide jos +22% pdv... ne znam jer istina ili ne, ali bolje provjeri za svaki slucaj...
-potpis-
Staro 14.12.2006., 21:49   #6
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
ma bolje uzmi monitor sa DVI-jem slika je puno oštrija i kvalitetnija
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 14.12.2006., 22:27   #7
spawn
spawn's Avatar
Postovi: 8,422
Autor Lihto Pregled postova
Probao sam Benq FP91G+,Samsung 940BW,LG 1932P jedan blizu drugog po dva komada i na svaki model spojio DVI i DSUB i mogu reci da sam u ova 3 modela jako malo razlike vidio u DVI i DSUB modu u kvaliteti prikaza sto se tice osnovne namjene.
Na benq-u takoreci uopce nema razlike dok se sitna ali sitna razlika vidi u ostrini slike na LG-u i Samsungu. Nisam stigao previse prckati po njima jer mi frend nije dao
Staro 14.12.2006., 22:29   #8
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
evo sad sam testirao 940BW sa DVI i sa D-Sub i nisam ama bas nista skoro ( uzasno sitne razlikice) primjetio osim sto mi pri paljenju monitora prepozna analog a ne digital...
-potpis-
Staro 14.12.2006., 22:33   #9
Panzer
Panzer's Avatar
Postovi: 1,814
Autor h3lld Pregled postova
Samsung sam vidio na djelu, odlican je.
Nis, otiso budem u metro, vidit taj monitor.
Mislim, ipak 22" nije malo
Jedino me brine reza, uf, izvlacit cu maximum iz grafe da bi mogao igrat nove igre.
UPGRADED...
Staro 14.12.2006., 22:34   #10
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
Samo pogledaj jer na tu cijenu ide jos i pdv, da ne bi bilo 3000kn a to je ipak 600kn razlike...
-potpis-
Staro 14.12.2006., 22:47   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Nije, bez PDV-a je 1990kn
UPGRADED...
Staro 14.12.2006., 22:50   #12
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
onda u redu, pogledaj pa odluci... a na tom monitoru ces moci komotno igrati na 1440x900 bez AA i AF, tj ne na max i sve 5.... samo jedino kazem ako ces za obradu slika ili nesto onda samsung... a za ostalo FS... uostalom ustekaj pa vidi kakva je slika jer nikad nisam vidio taj monitor na dijelu pa necu nista pretjerano pro ili ne govoriti, mogu samo za samsunga pricati...
-potpis-
Staro 15.12.2006., 07:28   #13
peroW1
peroW1's Avatar
Lokacija: Croatia Čk
Postovi: 551
Uzmi 22, nemas kaj razmisljat, za tu cijenu,jer ovaj 19'' je smijesan prema 22.
A sto se DVI-a tice,razlike su minorne,tj.tesko ces ih primjetiti.
i5 2550K 4.1GHz *Gigabyte Z77-D3H, 32 GB RAM KINGSTON HYPER X FURY, ASUS GTX 1060Ti , SSD 1TB, CoolerMaster 850W, ASUS 32'' 4K
peroW1 je offline   Reply With Quote
Staro 15.12.2006., 07:57   #14
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,151
Autor Panzer Pregled postova
Vec je netko primjetio i mislim da ga je vec uzeo (nije mi rekao jel ga vec ima doma)
Izostanak DVI-a je blesava tehnikalija za manju cijenu (debelo preko 10%) jer veliki ekrani sa DVI ulaze u kategoriju digitalnih TV-a. EU Birokratske sotonarije, ali eto.
Ono sto meni nije jasno... zasto na par mjesta vidim da se spominju 2x VGA (HD-15) ulaza, dok drugdje samo spominju jedan ulaz?
S dva ulaza bi bio bagatela, s jednim bi bila steta.
Staro 15.12.2006., 14:06   #15
kezme
Lokacija: split
Postovi: 55
pa jel treba neka bolesna graficka za taj monitor. ne bi igra igrice. imam 9200 staru bezvz radeon
kezme je offline   Reply With Quote
Staro 15.12.2006., 14:26   #16
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
hm, edit opcija... nego radeon 9200 ti nece biti dovoljna da se igras na tom monitoru i mislim da je TN matrica najnovije generacije...
-potpis-
Staro 15.12.2006., 14:39   #17
kezme
Lokacija: split
Postovi: 55
e al ne bi ga uzea za igrice. video montaza...
Staro 15.12.2006., 14:45   #18
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
Za to je 9200 dovoljno sto se tice grafickog dijela...
-potpis-
Staro 15.12.2006., 15:45   #19
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
ma kupujte taj 22", za windoze i sve ostalo će biti dobar..
ja da sam znao za njega, bio bi ga uzeo... iako mi je i ovaj 19" wide sasvim dovoljan.. tek kad se naviknem na rad na LCD-u, onda ću razmišljati o većeoj dijagonali... jer LCD-i strašno "svijetle", a što veća dijagonala, veći problem....
Staro 15.12.2006., 16:32   #20
64VT
Lokacija: ZG županija
Postovi: 509
onda, jel iko ima to, sad mi je žao kaj sam potrošio novac na tvrdi disk, ali mislim da više nebih mogao živjeti sa 58gb prostora , ma sad čekam, božić, rođendan, ovo ono, skupi se, da samo kaj više nebude ova akcija, ma bude i boljih, i jeftinijih, valjda: stoopid
64VT je offline   Reply With Quote
Staro 15.12.2006., 17:26   #21
kagjes
Lokacija: Zgb
Postovi: 94
ja sam bio opet jucer u linksu i zakljucio da se kupovina monitora ispod 3k kuna uopce ne isplati. sto se tice ovih samsunga widescreen tipa 204b (ili tako nesto), taman je bio izlozen jedan lijep primjerak i mogu reci da mi je slika presmjesna. daj ajte, ako se palite na dijagonale onda nemojte pricat o kvaliteti prikaza, jer nje bas tu nema. onaj 931 bf jos uvijek izgleda ojadno, raspon boja je prestrasan, kad ga usporedis sa recimo 970p slika gubi pola informacije. to je nevjerovatno koje su razlike u prikazu. al hej, sto god ljude veseli...
kagjes je offline   Reply With Quote
Staro 15.12.2006., 17:45   #22
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
Po tom principu mozes usporedjivati opel corsa i wolswagen phaeton.... mislim ono... ne mogu si svi priustiti phaetona, tj monitore koji kostaju kao cijele prosjecne konfiguracije... i za jednog prosjecnog korisnika ovakav 22" je sasvim dovoljan, nismo mi sad neki teski profici da nam treba nesto uuuuber super mega turbo giga kvalitetan display....
-potpis-
Staro 15.12.2006., 17:52   #23
Rijecanin
Rijecanin's Avatar
Postovi: 289
Autor kagjes Pregled postova
Ne prduckaj... lijepo ti je čovjek rekao, ne uspoređuj neusporedivo... Imam doma 930tku i slika je odlična, ja sam s njime prezadovoljan.... I onda odem do linksa (kao i ti), bacim oko na 971P i ostanem paf... slika jeste fenomenalna, ali to samo po sebi ne retardira 930tku do "jadne i prestrašne" razine.... [jer riječ je o čisto solidnom monitoru]
Koliko para toliko muzike....s time da je jadni LCD 481 puta bolja opcija od jadnog CRT-a...
Rijecanin je offline   Reply With Quote
Staro 15.12.2006., 22:15   #24
Seafreak
Mali od soli...
Seafreak's Avatar
Postovi: 72
Ja sam se isto dvoumio izmedju Samsunga 225BW i tog Fujitsu Siemensa L22-1W i danas sam prelomio i rezervirao Siemensa priko veze. Sutra ga iden kupit u Metroa (ako bude radio i ne bude imao dead pixela) pa vam napisem u nedjelju detaljan review. Imam dosta obaveza ovih dana, ali cu nastojat sta prije...
Samo mi drzite fige da monitor bude dobar i bez mrtvih pixela jer budem li opet morao traziti novi ispalit cu! : hitthewa
***iga ipak se radi o mrcini od 22" za 2500kn (PDV uracunat) a ako je istina da je razlika izmedju dvi i D-sub-a zanemariva mislim da ne mogu falit. Ionako bi mi sluzio pretezito za gledanje TV-a, rad u windowsima i nesto malo igranja te amaterske obrade grafike i videa. : bonker2
Siemens mi ipak lipse figura od Samsunga. E da, ako se ne varam Fujitsu Siemens koristi AU-Optronics panele, sto je vrlo pozitivno s obzirom da su jedni od najjacih na trzistu. Mislim odmah iza Samsunga... : goood :
Seafreak je offline   Reply With Quote
Staro 15.12.2006., 22:57   #25
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
22" za 2500kn
: nuts : : nuts : : nuts :
Staro 16.12.2006., 09:20   #26
kezme
Lokacija: split
Postovi: 55
mislim da je ovaj monitor fantasticna prilika. ako netko zna nesto lose o istom, nek napise...
Staro 16.12.2006., 20:12   #27
h3lld
Disturbed
h3lld's Avatar
Postovi: 1,420
i onda, Panzer / Seafreak ... neko kupio i isprobao?
-potpis-
Staro 16.12.2006., 21:21   #28
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
bilo bi nice kada bi 960bg pao malo sa cjenom
inace 22" za 2500kn mislim da bolje nemoze...
.i.
Razer Blade 15
Staro 16.12.2006., 21:46   #29
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
cini mi se da ce cijene jos vise past...ali samo cijene TN+film monitora
MVA/PVA i S-IPS jos dobro drze cijene...
Staro 16.12.2006., 22:39   #30
kezme
Lokacija: split
Postovi: 55
al taj monitor dode 2000 ako imate nekog ko ima metro karticu!
