Lokacija: zadar
Postovi: 5
HP nx6325 EY577ES vs. FUJITSU SIEMENS AMILO PA 1510 120GB
ako mozete rijesiti moju veliku dilemu izmedu ova dva laptopa..prvi dodje 5799kn u ve-mila.... Zaslon 15" XGA (1024x768) Bright View Procesor AMD Mobile Turion 64 X2 TL-52 (1.6GHz) Chipset ATI Xpress 1150 HDD80 GB (5400 okretaja)FDD- Optički pogon DVD+/-RW DL Supermulti Memorija 1GB DDR2 667MHz (2 DIMM - 2x512) Grafika Integrirana ATI Radeon Xpress 1150 Do 128-MB dijeljene memorije Fax modem 56K v.92 modem Povezivost Broadcom NetLink Gigabit Ethernet PCI Controller (10/100/1000) Wireless Broadcom 802.11 abg Integriran Bluetooth modul Multimedia PremierSound High Definition Audio w/24-bit DACI/ ORJ11, RJ45, SD 7u1 čitač kartica, 1x tipI/II PC Card, X34/54, VGA, IEE1394, 3 x USB 2.0, utor za docking, Fingerprint TPM 1.2 Disk sanitizer, hard disk protection system Baterija: 6 cell Li-Ion baterija HP Fast Charge Technology drugi je Fujitsu Siemens AMILO PA 1510 120GB i dodje 5699 kn u prosata... Procesor: AMD Turion64 X2 Mobile TL-50 (1,6GHz, 256KB L2 cache) • Ekran: 15.4” TFT / LCD WXGA (1280 x 800) display with CrystalView Technology • Memorija: 1GB (2x512MB) DDR2 533MHz • Hard disk: 120GB SATA HDD (5400rpm) • Optički uređaj: DVD+/-RW uređaj dual layer • Grafika: ATI Radeon® Xpress 1100 do 256MB shared VGA memory • Zvuk: 2 x stereo zvučnici • Mreža: 10/100/LAN • Modem: 56K V.92 • Bežična mreža: WLAN 802.11b/g • Portovi: 1x IEEE1394, 3x USB 2.0 ports, 1x S-Video 1x CRT, 1x modem, 1x LAN, 1x WLAN 1x ExpressCard slot (34/54mm) 1x line in shared with microphone in, 1x headphone out shared with 1x SPDIF 1x power supply 1x 4-in-1 card reader SD/MS/MMC/MSPRO Fingerprint TPM 1.2 Disk sanitizer, hard disk protection system Baterija: 6 cell Li-Ion baterija HP Fast Charge Technology ne razumim sta znaci ovo u FS 256Kb L2 cache tj. zasto je to tako malo kad je svagdi drugo 1Mb tj. da li mi to puno znaci u kupovini kad laptop nece biti upotrebljavan za nista teze cak ni igrice, kod HP-a taj podatak uopce ne pise pa ako netko zna koliki je. Mozete mi i preporuciti neki laptop u ovom cjenovnom rangu koji ima otprilike slicne karakteristike..Hvala svima na odgovorima i oprostite ako je nesto neuredno ali sve sam bio napisa i zabunom mi se izbrisalo, pa sam na brzinu sve morao opet. |
Postovi: 34,067
TL-52 ima 512kb cache-a, a brzina mu je jednaka kao i kod TL-50 (http://www.amd.com/gb-uk/Processors/...13911,00.html). FJ ima malo zericu slabiji cpu i sporiji ram, ali veći ekran. Grafika im je ista. U praktičnom radu, na nezahtjevnim poslovima (internet, Office,...), se ta razlika ni neće osjetiti. Osobno sam radio na HP-u, ali kratko. Ništa specijalno da se ističe. Koliko sam vidio, mnogi hvale tu HP-ovu seriju kao kvalitetnu i trajnu.
#3 | |
Lokacija: zadar
Postovi: 5
da vidio sam da dosta hvale ovu seriju hp-a i to je jedan od razloga zasto cu se vrlo vjerojatno i odluciti za njega, a to sta je manji ekran nema veze jer vidim da ce tako ujedno i trositi manje baterije a to mi je dosta bitno. Jos da je imat novaca pa uzeti jacu verziju nx 6235 : hitthewa |
Postovi: 34,067
512kb cache po jezgri. A kako ima dvije jezgre (X2), to ti je 2x512kb http://www.tomshardware.com/2006/08/...ved/page3.html
