Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 09.12.2006., 03:04   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Koja memorija (DDR400, 1GB keks) da ide do 500MHz?
Ovak, znam da je vec bilo takvih pitanja, ali eto situacija se s vremenom promijenila, pa da pitam.
Koja memorija moze ic do 500MHz+?
Dajte mi preporucite neku jeftiniju, kak bi se reklo da se kockam jel ide il ne.
I jednu skuplju koja bi recimo ziher isla.
Kakav je Corsair C2? 2x1GB kit?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 09.12.2006., 03:20   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Evo pogledaj moj sigic. Be-5 bi trebala ići do 500mhz ali meni radi sikrono sa procom. Corsair Value
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 09.12.2006., 03:25   #3
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Panzer ako nađeš A-datu ili super talenta (CL3) obe Pc3200 obe bi ziher pičile na sigurnih 500...
G0RKI je offline   Reply With Quote
Staro 09.12.2006., 13:04   #4
Wolverine
Wolverine's Avatar
Postovi: 12,431
mortal BE-5 jako rijetko ide na 250MHz (DDR500)
vidio sam svega dva tri review-a di je Cors C2 sa BE-5 išao na DDR500 i ziher sam da se radilo u nekim slučajevima o istim keksima, obične ne idu dalje od 225-230MHz na 2,5-3-3-6
uzmi radije neki UCCC
a sad to bi trebale bit A-DATA, SuperTalent C3 i Transcend iako sam čuo u zadnje vrijeme da na Transcend-u ima i drugih čipova
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.12.2006., 16:49   #5
Nasty_
Nasty_'s Avatar
Postovi: 383
Definitivno super talent CL3 ide cak na 520-560
Nasty_ je offline   Reply With Quote
Staro 10.12.2006., 22:57   #6
GLUPAN
Datum registracije: Sep 2004
Postovi: 237
nije istina da svaki supertalent cl3 ide na 500mhz,moj nije isao!
Ram vise nemam.brat mi ga razbio ali racun imam da dokazem kako je to supertalent cl3
Nazalost moj je imao heatspreder gore pa nisam vidio koji je chip ali samsung uccc nije!!!! Dakle,ne ide svaki st cl3 na 500 mhz....
Moj je isao do 460 mhz,nakon toga 480 mhz ali ne stabilno a na 500 nije htio bootat u windowse!
Ja sam dobio kasnije transcend sa hynixom d43 na njoj i ta memorija boota na 500mhz u windowse,dakle nije u pitanju procesor( 3700sd) ili maticna(DFi NF4Ultra)....
Eto,da upozorim Panzera ako vec nije kupio.... Ako kupujes probaj pitat da ti je pokazu prije nego je uzimas te ako imaju samsung uccc,buy!
Nikola
GLUPAN je offline   Reply With Quote
Staro 11.12.2006., 01:19   #7
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
Autor GLUPAN Pregled postova
..e vidis moj hynix D43 (pogledaj sig) nece preko 460 da ga je*es,dok mi je keks od 512mb-a takodjer hynix d43 isao preko 500 na 2,7v....nema pravila izgleda
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 11.12.2006., 12:27   #8
kristian_0
Postovi: 83
Mislim da je kod memorija najvažniji faktor bios MB-a. Moj supertalent (uccc) nije išao preko 220 MHz, a nakon promjene biosa bez beda ide 250.
AMD Athlon XP-M 2600+ / 9 x 250 MHz / 1.57V /SonicTower+120 mm vent.
Chieftech 410 W
DFI LanParty NF2 rev.A+ /TicTac xt
2x1 GB Samsung ST
Leadtek 6200@6600+zalman vf700-cu
kristian_0 je offline   Reply With Quote
Staro 11.12.2006., 12:31   #9
Razer
Razer's Avatar
Postovi: 11,642
Autor kristian_0 Pregled postova
Mislim da se varaš...to što je kod tebe bio takav slučaj ne znači da je to sad pravilo...najvažniji je faktor s kojim čipovima memorija dolazi...po meni...
Staro 11.12.2006., 12:34   #10
kristian_0
Postovi: 83
Ma ne tvrdim da je pravilo.Normalno da su čipsi najvažniji,samo velim da je bios vrlo vrlo bitan.
Chieftech 410 W
2x1 GB Samsung ST
Staro 11.12.2006., 15:08   #11
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
ja sam imao corsairov c2 kit i bio je dosta losh. nije isao preko 440Mhz na 2.5-3-3-6 da ga hebes.
radje lijepo naci neki uccc i to je to...decki su vec gore naveli o kojim se modelima radi
Ph03n1x je offline   Reply With Quote
Staro 11.12.2006., 16:43   #12
animATrIx
animATrIx's Avatar
Lokacija: Vukovar-Osijek
Postovi: 491
frend bas prije koji dan kupio corsair xms 3200xl sa samsung tccd cipovima, mislim da mu je granica kakvih 260mhz al brijem da fsb nemoze vise..
animATrIx je offline   Reply With Quote
Staro 11.12.2006., 17:25   #13
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor animATrIx Pregled postova
ok koje ovo veze ima sa ovom temom?
TCCD se uopće ne može nać na 1GB modulima jer takvi ne postoje a ovdje se priča baš o 1GB modulima
inače TCCD ide debelo preko 260 samo ovisi o ploči, mem kontroleru, postavkama u biosu itd.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 11.12.2006., 18:54   #14
animATrIx
animATrIx's Avatar
Postovi: 491
aaa, sorry
Staro 11.12.2006., 20:20   #15
M4rk0
DragonBall Z Fan
M4rk0's Avatar
Postovi: 1,245
evo jedan OT
mozete mi reci kaj je bolje ?
SuperTalent
PC3200 C3 - Samsung UCCC
A-Data
A-Data PC3200 - Samsung UCCC
Transcend
PC3200 - Samsung UCCC + Original PCB
( je ovo isto DDR 1GB TRANSCEND, PC-3200/400 MHz, Samsung chip2 ??? )
M4rk0 je offline   Reply With Quote
Staro 11.12.2006., 22:25   #16
Wolverine
Wolverine's Avatar
Postovi: 12,431
pa ako svi imaju UCCC onda su svi isti ovisi jedino o tome kakve si sreće pa kakav UCCC potrefiš
i da ako piše Transcend, Samsung chip to znači da je gore UCCC
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 17.12.2006., 02:38   #17
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,197
Moj Corsair 4000 PT ide do 280 =>560Mhz 3- 4- 4- 8
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 20.12.2006., 16:48   #18
feelgood
I'm DEAD sexy!!!
feelgood's Avatar
Datum registracije: Sep 2002
Postovi: 349
Gdje ima najjeftinije za kupit A-data i jel one dolaze u paketu 2x1 Gb il se ubadaju na komad?
ASUS Crosshair V Formula
Processor AMD FX-8320E
Corsair Vengance Pro DDR3 2133 2x4 GB
NVIDIA GeForce GTX 1060 6GB
feelgood je offline   Reply With Quote
Staro 20.12.2006., 16:59   #19
Razer
Razer's Avatar
Postovi: 11,642
Autor feelgood Pregled postova
Imaš ju u Magazinu RS...i da, nemaš za kupiti 2x1gb kit...
Staro 24.03.2007., 22:54   #20
Gen1us
Gen1us's Avatar
Postovi: 300
Znam da dizem temu 16 godina staru........
Kako provjerit jesu li gore uccc cipovi ako ima heathspreader?nikak ?
Gen1us je offline   Reply With Quote
Staro 25.03.2007., 01:05   #21
Fera_os
Ne znam šta da napišem
Fera_os's Avatar
Postovi: 984
Misliš na ovaj Twinmos iz siga?? Ne bi baš reko...
Nemam ništa pametno za reć!
Fera_os je offline   Reply With Quote
Staro 25.03.2007., 01:11   #22
Gen1us
Gen1us's Avatar
Postovi: 300
Ne neg na supertalent 1gb cl3
Staro 25.03.2007., 04:39   #23
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
OC-anjem...
Staro 25.03.2007., 06:18   #24
Fera_os
Fera_os's Avatar
Postovi: 984
Točno, OC-anjem. Klokaj pa vidi kolko ide?? A možeš se mal raspitat tu na forumu na kolko ide taj super talent pa ak ide dosta onda je lako moguće UCCC. A možeš polako i po tom heatspreaderu zaključit da se dobro kloka. Nisu ga oni bezveze stavili i nabili cijenu...
Staro 12.04.2007., 14:44   #25
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Zna li itko kakva je ona A-Data 1GB DDR400 iz Ve-mila? Pitao sam tipa koji su čipovi gore, kaže da su BGA i da piše A-Data na njima. Šta mislite, bi li išlo to do 500 MHz?
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 12.04.2007., 14:57   #26
Fera_os
Fera_os's Avatar
Postovi: 984
BGA je reko zato što je to za DDR2 meme a TSOP il kak već za DDR1. Mislim, nazivi, uobičajeno.
Staro 12.04.2007., 15:04   #27
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Ajd, onda je tip vrlo genijalan, jer sam mu lijepo rekao da trebam DDR400 memoriju A-Data od 1 GB
I5 3350P
XFX XTR 650W
Silencio 650
Staro 12.04.2007., 15:05   #28
domy_os
domy_os's Avatar
Postovi: 18,929
Zašto bi bio DDR2, ako piše BGA? Davno su se proizvodili zlatni DDR BGA Kingmaxi... BGA i TSOP je samo pakiranje čipa odnosno oblik kućišta.
Staro 12.04.2007., 15:08   #29
Panzer
Panzer's Avatar
Postovi: 1,814
Evo, da se i ja javim, posto jos nisam kupio memu.
Najvjerovatnije ovaj mjesec uljece 2x1GB, gledao sam u ADM-u 1GB STT CL3 za nekih 510kn. Ako ih imaju na lageru to cu kupit, samo da placa sjedne.
UPGRADED...
Staro 12.04.2007., 15:12   #30
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
c-c-c, još nisi nabavio 2 gige
BTW obavezno postaj reze, moraš barem 4 GHz sa tim Northwoodom potegnuti
