Postovi: 8,421
TakeMS 1GB 667 ddr2 - koji chipovi?
Imam priliku uzet ovaj ram povoljno. Zanima me samo koji su chipovi gore i da li idu bar na 800 . Na 2.1V jer je u pitanju ASUS P5B ploca. Neovisno da li na cl5 ili cl4. Bitno da ide na 800 na 2.1. EDIT: Doznao sam ovo: "for anyone that is interested in value ram the PCS chips arent bad at all, my 1gb x 2 do about (dual windows memtest) 475mhz 4-4-4-12 with 2.4v and i tested up to 550ish with same voltage and 5-5-5-15......24/7 i run them at 400 4-4-4-12 2v they could probably do 3-4-4-12 at same voltage i just never bothered to test, i also never really tested their max, or their optimal settings...... I also tested Kingston 533 1gb but they werent even close to the 667 ones, might be thoug cause they had 4 different production weeks and few different batch numbers on only 2 sticks so were probably bottom of the barrel sticks Those PCS chips are also found on (that i know of) Corsair Value, and TakeMS ram (i saw on some forum that TakeMS only uses the PCS chips)" Ako je to istina ,takeMS bi mogao postati malo popularniji ne go kingmax i slicni ![]() ![]() Zadnje izmijenjeno od: spawn. 20.11.2006. u 16:42. |
