Staro 11.11.2006., 11:02   #1
amerix
Lokacija: NY
Postovi: 504
prženje...
evo log od NERO-a
neki DMA driver error ????
zgazio sam 15 dvd-ova :mad:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'F:\Program Files\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2.11.2004 13:54:32
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
Recorder: <PIONEER DVD-RW DVR-111D>Version: 1.02 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PIONEER DVD-RW DVR-111D>Version: 1.02 - HA 1 TA 0 - 7.5.7.0
=== Scsi-Device-Map ===
DiskPeripheral : ST340014A nvatabus Port 0 ID 0 DMA: Off
DiskPeripheral : ST3120814A nvatabus Port 0 ID 1 DMA: Off
CdRomPeripheral : PIONEER DVD-RW DVR-111D nvatabus Port 0 ID 2 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-111D G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 294MB (301112kB)
Memory in use : 71 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.11.2006
ISO compilation
13:07:15 #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
13:07:15 #2 Text 0 File Isodoc.cpp, Line 6508
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
13:07:16 #3 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
13:07:17 #4 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
13:07:18 #5 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 300303 ( 66:44.03, 586MB)
13:07:18 #6 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
13:07:18 #7 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: PIONEER DVD-RW DVR-111D, Media type: DVD+R
Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
13:07:18 #8 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
13:07:18 #9 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 300304 (300304) = #300304/66:44.4
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 300304 blocks [Main]
13:07:18 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [PIONEER DVD-RW DVR-111D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 615022592, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 300304 | 0 | 0x00
0 | 1 | 1 | 0x41 | 300304 | 0 | 0x00
300304 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
13:07:18 #11 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
13:07:18 #12 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
13:07:18 #13 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
13:07:18 #14 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
13:07:18 #15 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 8x (11.080 KB/s)
13:07:18 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
13:07:18 #17 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Media type ID: T02
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 59 55 44 45 4E - 30 30 30 54 30 32 00 38 ...YUDEN000T02.8
23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
13:07:18 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 293
G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x08128800: Len x648
13:07:18 #19 Text 0 File DVDPlusRW.cpp, Line 662
Start write address at LBA 0
DVD high compatibility mode: No
13:07:40 #20 Text 0 File Cdrdrv.cpp, Line 1290
13:07:40.019 - G: PIONEER DVD-RW DVR-111D : Queue again later
13:08:15 #21 SPTI -1502 File SCSIPassThrough.cpp, Line 293
G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 02 C0 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0E 00 00 00 00 08 03
Buffer x07f0e000: Len x10000
0x22 00 C0 02 00 00 00 00 02 C0 00 08 00 00 00 00
0x08 00 6A 09 12 03 11 38 00 02 00 00 01 00 00 01
0x01 00 22 00 62 01 00 00 00 00 01 62 00 08 00 00
13:08:15 #22 CDR -1502 File Writer.cpp, Line 278
DMA-driver error, CRC error
13:08:38 #23 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 8x (11.080 KB/s)
13:08:38 #24 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
13:08:38 #25 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.5.2006 21:16:24
File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 25.8.2006 3:47:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
amerix je offline   Reply With Quote
Staro 11.11.2006., 11:06   #2
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Neda mi se tražit ali lako moguće da ti radi u PIO umjesto u DMA modu. Pioneer ne voli ništa manje od DMA4. Odi u device manager, nađi ide kanal na koji ti je spojena pržilica i pod properties->advanced pogledaj u kojem modu radi. Ako se neda ručno prebacit u DMA mod, deinstaliraj ide kanal i restartaj komp.
EDIT: ovo je tvoj problem:
Lako moguće da ti je DMA disejblan i u biosu (pogotovo ako si nedavno radio ccmos), pa i tamo provjeri.
Staro 11.11.2006., 12:14   #3
amerix
Lokacija: NY
Postovi: 504
nasao sam nesto u biosu vezano za DMA al je na auto ili enabled
Staro 11.11.2006., 12:17   #4
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
A kaj ti pise pod device manager?
Desni klik na my computer->properties->hardware->device manager->nađi di su ti IDE kanali i tamo pogledaj dal koji piše da je u PIO modu ili su ti svi UDMA...
U BIOS-u ostaviš na enabled (makar bi i auto trebalo raditi).
Staro 11.11.2006., 12:21   #5
nino
nino's Avatar
Postovi: 12,600
Pogledaj u Device manageru pod IDE ATA/ATAPI Controllers.
Edit: Vutzo je bio brži
Staro 11.11.2006., 12:24   #6
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Mislim da sam mu ja to sve ipak prvi napisao, ali treba znat čitat, a ne samo zadnju rečenicu...
Staro 11.11.2006., 12:28   #7
amerix
Lokacija: NY
Postovi: 504
Staro 11.11.2006., 12:32   #8
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Da, to je to, i tako bi trebalo bit. Ako te i dalje yebe, probaj NE koristit ide drivere od nvidie, deinstaliraj ih, restartaj, i pusti windbloze da stave one od microsofta, defaultne, pa vidi kako se onda ponaša.
Staro 11.11.2006., 12:49   #9
nino
nino's Avatar
Postovi: 12,600
A da stavi verziju 6.xx Nera, ova 7- mi se nikako ne svidja, malo malo neki bug, ispravite me ako grijesim.: stoopid
Staro 11.11.2006., 13:19   #10
amerix
Lokacija: NY
Postovi: 504
Autor nino5 Pregled postova
javlja isto i sa 6 i sa 7 verzijom
