Lokacija: NY
Postovi: 505
prženje...
evo log od NERO-a neki DMA driver error ???? zgazio sam 15 dvd-ova :mad: Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'F:\Program Files\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2.11.2004 13:54:32 NT-SPTI used Nero Version: 7.5.7.0 Internal Version: 7, 5, 7, 0 Recorder: <PIONEER DVD-RW DVR-111D>Version: 1.02 - HA 1 TA 0 - 7.5.7.0 Adapter driver: <IDE> HA 1 Drive buffer : 2000kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <PIONEER DVD-RW DVR-111D>Version: 1.02 - HA 1 TA 0 - 7.5.7.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : ST340014A nvatabus Port 0 ID 0 DMA: Off DiskPeripheral : ST3120814A nvatabus Port 0 ID 1 DMA: Off CdRomPeripheral : PIONEER DVD-RW DVR-111D nvatabus Port 0 ID 2 DMA: Off === CDRom-Device-Map === PIONEER DVD-RW DVR-111D G: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 294MB (301112kB) Memory in use : 71 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 3.11.2006 ISO compilation 13:07:15 #1 Text 0 File SCSIPassThrough.cpp, Line 583 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 13:07:15 #2 Text 0 File Isodoc.cpp, Line 6508 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 13:07:16 #3 ISO9660GEN -11 File Geniso.cpp, Line 3313 First writeable address = 0 (0x00000000) 13:07:17 #4 Text 0 File Burncd.cpp, Line 3435 Turn on Disc-At-Once, using DVD media 13:07:18 #5 Text 0 File DlgWaitCD.cpp, Line 301 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 300303 ( 66:44.03, 586MB) 13:07:18 #6 Text 0 File DlgWaitCD.cpp, Line 313 Write in overburning mode: NO (enabled: CD) 13:07:18 #7 Text 0 File DlgWaitCD.cpp, Line 2863 Recorder: PIONEER DVD-RW DVR-111D, Media type: DVD+R Disc Manufacturer ID: YUDEN000, Media Type ID: T02, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 13:07:18 #8 Text 0 File DlgWaitCD.cpp, Line 485 >>> Protocol of DlgWaitCD activities: <<< ========================================= 13:07:18 #9 Text 0 File ThreadedTransferInterface.cpp, Line 820 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 300304 (300304) = #300304/66:44.4 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 300304 blocks [Main] -------------------------------------------------------------- 13:07:18 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1033 Prepare recorder [PIONEER DVD-RW DVR-111D] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 615022592, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 300304 | 0 | 0x00 0 | 1 | 1 | 0x41 | 300304 | 0 | 0x00 300304 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 13:07:18 #11 Text 0 File SCSIPassThrough.cpp, Line 41 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 13:07:18 #12 Phase 24 File dlgbrnst.cpp, Line 1746 Caching of files started 13:07:18 #13 Text 0 File Burncd.cpp, Line 4262 Cache writing successful. 13:07:18 #14 Phase 25 File dlgbrnst.cpp, Line 1746 Caching of files completed 13:07:18 #15 Phase 36 File dlgbrnst.cpp, Line 1746 Burn process started at 8x (11.080 KB/s) 13:07:18 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2730 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 13:07:18 #17 Text 0 File Cdrdrv.cpp, Line 9234 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: YUDEN000 Media type ID: T02 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 03 59 55 44 45 4E - 30 30 30 54 30 32 00 38 ...YUDEN000T02.8 23 54 37 10 02 4E 72 02 - 8C 63 16 16 0B 0B 0A 0A #T7..Nr..c...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 13:07:18 #18 SPTI -1066 File SCSIPassThrough.cpp, Line 293 G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00 Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24 Buffer x08128800: Len x648 13:07:18 #19 Text 0 File DVDPlusRW.cpp, Line 662 Start write address at LBA 0 DVD high compatibility mode: No 13:07:40 #20 Text 0 File Cdrdrv.cpp, Line 1290 13:07:40.019 - G: PIONEER DVD-RW DVR-111D : Queue again later 13:08:15 #21 SPTI -1502 File SCSIPassThrough.cpp, Line 293 G: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x08 Sense Qual: 0x03 CDB Data: 0x2A 00 00 00 02 C0 00 00 20 00 00 00 Sense Area: 0x70 00 04 00 00 00 00 0E 00 00 00 00 08 03 Buffer x07f0e000: Len x10000 0x22 00 C0 02 00 00 00 00 02 C0 00 08 00 00 00 00 0x08 00 6A 09 12 03 11 38 00 02 00 00 01 00 00 01 0x01 00 22 00 62 01 00 00 00 00 01 62 00 08 00 00 13:08:15 #22 CDR -1502 File Writer.cpp, Line 278 DMA-driver error, CRC error G: PIONEER DVD-RW DVR-111D 13:08:38 #23 Phase 38 File dlgbrnst.cpp, Line 1746 Burn process failed at 8x (11.080 KB/s) 13:08:38 #24 Text 0 File Cdrdrv.cpp, Line 10459 DriveLocker: UnLockVolume completed 13:08:38 #25 Text 0 File SCSIPassThrough.cpp, Line 583 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.5.2006 21:16:24 File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 25.8.2006 3:47:00 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
#2 | ||
Laughing Man
Postovi: 3,040
Neda mi se tražit ali lako moguće da ti radi u PIO umjesto u DMA modu. Pioneer ne voli ništa manje od DMA4. Odi u device manager, nađi ide kanal na koji ti je spojena pržilica i pod properties->advanced pogledaj u kojem modu radi. Ako se neda ručno prebacit u DMA mod, deinstaliraj ide kanal i restartaj komp. EDIT: ovo je tvoj problem: Citiraj:
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
A kaj ti pise pod device manager? Desni klik na my computer->properties->hardware->device manager->nađi di su ti IDE kanali i tamo pogledaj dal koji piše da je u PIO modu ili su ti svi UDMA... U BIOS-u ostaviš na enabled (makar bi i auto trebalo raditi).
Postovi: 12,613
Pogledaj u Device manageru pod IDE ATA/ATAPI Controllers. Edit: Vutzo je bio brži ![]()
#6 | |
Laughing Man
Postovi: 3,040
Mislim da sam mu ja to sve ipak prvi napisao, ali treba znat čitat, a ne samo zadnju rečenicu...
Lokacija: NY
Postovi: 505
#8 | |
Laughing Man
Postovi: 3,040
Da, to je to, i tako bi trebalo bit. Ako te i dalje yebe, probaj NE koristit ide drivere od nvidie, deinstaliraj ih, restartaj, i pusti windbloze da stave one od microsofta, defaultne, pa vidi kako se onda ponaša.
Postovi: 12,613
A da stavi verziju 6.xx Nera, ova 7- mi se nikako ne svidja, malo malo neki bug, ispravite me ako grijesim.: stoopid
Lokacija: NY
Postovi: 505
