Staro 26.10.2006., 02:04   #1
Barbas
Lokacija: hrvatska
Postovi: 3
Question problemi sa modemom
: stoopid Imam problem naci driver za modem.
SmartBox internal modem
Chipset:PCTEL PIM-511P
PCTEL HS688 511P
Modem je plug&play ali kod instalacije trazi driver .
Dali mi netko moze kazati na kojim stranicama ga mogu
pronaci. jer ja ocito ne mogu.....
Zadnje izmijenjeno od: Barbas. 26.10.2006. u 02:19. Razlog: greska
Barbas je offline   Reply With Quote
Staro 26.10.2006., 10:14   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pokušaj sa univerzalnim HSP56 driverima
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 26.10.2006., 10:32   #3
Postovi: 33,958
Kvark prodaje SmartBox uređaje. Skoči do njih i zamoli ih da ti ga daju. Imaš i alternativu: registriraj se besplatno na www.driverguide.com i tamo ga potraži.
Staro 26.10.2006., 11:26   #4
-ELF
-ELF's Avatar
Lokacija: eire
Postovi: 366
otidji na driverguide.com, registruj se i trazi drivere za svoj modem
-ELF je offline   Reply With Quote
Staro 28.10.2006., 01:14   #5
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
ja imam u svojem pc-u neki kineski škart još iz '99 ali radi bez problema na win 98 i xp. na 98 sam imao drivere koji su došli s njim ali sam ih zagubio pa sam na xp-u instalirao kao IBM data fax modem i kod većine ljudi koji imaju interni modem je instaliran kao IBM-ov i radi bez problema.
ali svakako prije pronjuškaj na netu drivere za tvoj modem ako ih ima (google is your best friend
potemkin.hr je offline   Reply With Quote
Staro 28.10.2006., 02:10   #6
Postovi: 23,524
Pogledaj ovdje:
http://www.modemsite.com/56k/pctel.asp
Također nebi bilo loše da prepišeš tačnu oznaku na čipu i po njoj pokušaš naći odgovarajući driver. Svakako izbjegavaj "nepotpisane" drivere za XP.
