Staro 14.10.2006., 23:45   #91
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor demetrius Pregled postova
čim sa instaliro novu grafu i htio staviti driver odmah sranja,zbriso mi driver od zvuka i još neke,zašto grafa prihvaća samo 91.47 drivere kad sam pokušao staviti 71,08 i 81,85 bacio je error da se ne sviđaju 7600 gt???koje ti drivere imaš???
Ti su prestari. Stavi 91.31 ili 91.47. Ili pak neke XG-modded.
Staro 15.10.2006., 13:02   #92
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor SRV Pregled postova
stavio 91,47,piše u mom postu.
Staro 15.10.2006., 13:14   #93
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Imam 91.47.
Grafa vjerovatno ne prihvaca starije drivere jer su prestari i jos nije postojala 7600, te ne postoji ni podrska za nju.
Ovi 91.47 su ok, nikakvih problema za sada.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 15.10.2006., 21:04   #94
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
Autor Panzer Pregled postova
Imam 91.47.
sranja rade,neke bijele crte u meniju dark crusejda, u igri ne,pa slova zbrljana pa malo dobra pa opet zbrljana.
Staro 20.10.2006., 00:07   #95
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,875
sad je ok,sistem ponovo dignuo kod frenda,derne 11200 3d marka 03.
Staro 21.10.2006., 17:35   #96
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Danas stigao moj 7600gt AGP. Daje na def frekvama 5653 3Dmark05 Privitak 6661 . Jel to ok obzirom na konfu iz siga? Zbunjuje me to da kaže da je mema na 350 (700) mhz, a trebala bi biti na 700(1400)...vjerojatno je do drivera jer u odnosu na 6600gt je osjetno brža.
Zadnje izmijenjeno od: Problem. 24.11.2006. u 18:39.
Staro 21.10.2006., 22:17   #97
Kimi
Kimi's Avatar
Postovi: 652
to je ok 3Dmark rezulatat....meni isto piše u Ati toolsu da je mema na 350mhz(default)....a riva tuneru piše 700(default) kao i u driverima
Kimi je offline   Reply With Quote
Staro 22.10.2006., 12:41   #98
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
Evo, OC na 600/800
3DMark05 Privitak 6663
3DMark03 Privitak 6664
Zadnje izmijenjeno od: Problem. 16.03.2007. u 11:09.
Staro 22.10.2006., 12:58   #99
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Hm, da. Trebao bi imati nesto veci score, ali ipak je to s754 i single-channel tako da i to donekle utjece na ukupan rezultat. Uglavnom nemas brige
Staro 22.10.2006., 14:30   #100
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
ma trebal bi srušiti windowze i onda vidjeti. Na 615/810 daje 63xx nesjecam se tocno. Uglavnom ja sam zadovoljan
Staro 22.10.2006., 17:14   #101
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nista ne bi dobio i da stavis nove windoze. Vjeruj meni, ja sam to vec milijun puta radio.
No glavno je da ti igre lete
Staro 23.10.2006., 13:41   #102
Wizzard
Wizzard's Avatar
Postovi: 497
Talking
Evo i mog skromnog skora karte iz siga mada mislim da je to sasvim ok..kuler je stok..dakle tvornički..
CPU: Amd Ryzen 5 9600x cooled by Ac Freezer 36 Co
MBO: Gigabyte x870 Gaming X Wifi 7
RAM: 2x16gb ddr5 Kingston Fury Beast Rgb Expo 6000mt
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD:Kingston FURY Renegade G5 2Tb+Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB
PSU: Corsair RM 850x (Gold+)Atx 3.1 Fully Modular
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Wizzard je offline   Reply With Quote
Staro 25.10.2006., 22:03   #103
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
imaš isti score ko i ja a dual core?!?!?!
Staro 25.10.2006., 23:11   #104
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Problem Pregled postova
Nije vrtio 2006, jedino on profitira od druge jezgre.
Staro 25.10.2006., 23:51   #105
Quake2
Quake2's Avatar
Lokacija: pž
Postovi: 1,291
Profitira i 05 od dvije jezgre,samo ne toliko
Quake2 je offline   Reply With Quote
Staro 26.10.2006., 00:19   #106
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Autor Quake2 Pregled postova
Profitira skoro pa duplo...sudeći po mojim CPU rezultatima...
Opteron 144 3100Mhz 5563
E6600 3.6Gigz 12533
Staro 26.10.2006., 00:26   #107
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Eto to nisam znao...mislio sam da samo 2006 zna za DC.
Staro 26.10.2006., 11:11   #108
smoks1
smoks1's Avatar
Postovi: 343
da,ali ne mozes ti usporedjivat D820 i E6600!
to je ko da usporedjujes nebo i zemlju...
a i ima razlike, sa P4 2.26 Ghz sam imao 4500 bodova a sada imam 6391...
sto se da jos posteno dignut...
@ problem,a ti si i svoju clocknuo,a moja je na orginal postavkama...
smoks1 je offline   Reply With Quote
Staro 28.10.2006., 04:25   #109
DoDo
DoDo's Avatar
Postovi: 372
Hm da ija pridodam nesto ovoj temi.
Evo nakon sto je rikla Le-ica ubo sam si danas albatron 7600GT
3 god garancije njam njam.
Fine je plave boje pase mi uz asrock 1150 kn mislim da je best buy .
Javim vam update klokova zasad preko nvidi-inog panela sam je dignu pomocu
testa na 660 core i 800 i nesto sitno mema budem iztestiro.
Btw. vent je prokleto bucan morat cu piknut gore neki drugi.
: nono :
P35-DS3 rev. 2.0
E8200 @457x8=3655 1.35V
2x1Gb kingmax 667 @ 915 5 5 5 2V
1x2Gb transcedent @ 915 5 5 5 2V
GTX460 768MB @ 830/1050
Fortron 350W
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
- Bill Watkins- CEO Seagate Technology
DoDo je offline   Reply With Quote
Staro 28.10.2006., 09:44   #110
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor smoks1 Pregled postova
Netko nešto uspoređuje?Ne...Ako se odnosi na moj post,pročitaj ga još jednom,imam DC i moj post je imao svrhu informirat neinformirane da 3DMark05 ima koristi od DC procesora i da se u krajnjem slučaju od njega ima koristi u konačnom rezultatu,DC se prepoznaje u rezultatu...
& tko je spominjao D820?
Ja sam nabacio 2 rezultata,od 144 3100Mhz i E6600 3.6Ghz,čisto usporedbe radi prikazat razliku između 1 i 2 jezgre,bez obzira na nadmoć C2C-a koja ipak nije tolika u 3D-u pogotovo u usporedbi s Opteronom na 3.1Ghz
Za 7600GT-aše,evo vam moja reza pa hvatajte ako možete
http://service.futuremark.com/compare?3dm06=425792
Staro 28.10.2006., 10:22   #111
smoks1
smoks1's Avatar
Postovi: 343
4799?
fora
ispricavam se na gornjem postu
pozdrav!
Staro 28.10.2006., 10:51   #112
Thoroughbred B
Lokacija: RI
Postovi: 4,918
4799?
fora
pozdrav!
Nisam tražio ispriku,no ajde,kako god
Staro 28.10.2006., 11:23   #113
smoks1
smoks1's Avatar
Postovi: 343
Samo jedno pitanje,ako mozda znas, kupio plocu iz siga,pisalo da podrzava C2D i 1066 FSB,kupio ju,slucajno kasnije naletio na netu da je FSB samo 800 Mhz ali da podrzava C2D.
Kako ce C2D radit ko je maticna samo 800 mhz?
Staro 28.10.2006., 20:22   #114
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,692
@ smoks1
Ali tvoji origigi taktovi su skoro isti ko i moji ocani.
Staro 28.10.2006., 22:53   #115
nevenx
nevenx's Avatar
Lokacija: Koprivnica
Postovi: 92
3dMark05 -default clock 5900
Zanima me kakva vam je temp. GPU, kod mene je čim upalim komp. 60 C, kasnije ako ostavim otvoreno kučište 65 C, sa zatvorenim preko 70 C jel to OK temp. za ovu karticu, tek sam ju kupio pa me zanima?
nevenx je offline   Reply With Quote
Staro 29.10.2006., 01:04   #116
b166
Lokacija: ns
Postovi: 35
malo glupo pitanje ali :
nije mi jasno kako ati tool pokazuje default clock memorije 350 mhz , a riva mi pokazuje 700 mhz
kako onda svi vi imate clockove preko 1400 mhz?
imam leadtek px7600 gt i 91.47 driver
b166 je offline   Reply With Quote
Staro 29.10.2006., 01:24   #117
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor nevenx Pregled postova
Stavi druge drivere. Tak sam i ja imao problema sa driverima koji su dosli uz grafu. Dignuo druge onda je normalna temp.
@B166: Pomnozi sa dva. U principu dobro pokazuje, ali mi se sada neda objasnjavat
Staro 29.10.2006., 12:18   #118
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
Autor b166 Pregled postova
kod ati toola mnozi s 4...kod rive s 2...u oba slucaja = 1400.
Ph03n1x je offline   Reply With Quote
Staro 29.10.2006., 13:58   #119
Bimbrlok
Bimbrlok's Avatar
Datum registracije: Dec 2003
Lokacija: Sarajevo
Postovi: 62
Evo kod mene evge 7600gt 560/700 u 3d marku 03 rezultat je oko 12500
nisam nista dizao frekfencije neznam smijem li temperaturu gpu-a bez opterecenja pokazuje 50 stepeni
Bimbrlok je offline   Reply With Quote
Staro 29.10.2006., 14:40   #120
Bimbrlok
Bimbrlok's Avatar
Lokacija: Sarajevo
Postovi: 62
evo sa dignutim gpu-om na 600mhz a memoriju nisam dirao nista ostala je na 700mhz
