Staro 07.10.2006., 18:02   #241
gil
Member
Lokacija: Kutina
Postovi: 979
sempron 2500+@2000, evo smanjio sam, sorry svima
Zadnje izmijenjeno od: gil. 07.10.2006. u 19:22.
gil je offline   Reply With Quote
Staro 07.10.2006., 18:30   #242
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Autor gil Pregled postova
Uvijek stavljaj sliku u jpeg-u jer ovo je previše.
Evo da se i ja pohvalim
Staro 07.10.2006., 18:39   #243
gil
Member
Lokacija: Kutina
Postovi: 979
Staro 12.10.2006., 18:40   #244
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,313
Free Image Hosting at www.ImageShack.us
vex je online   Reply With Quote
Staro 14.10.2006., 19:06   #245
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Ja sam sad smanjio superpiiiiiiiiiiii(p)...*
Stavio sam Crucial Ballistix - Micron -5B G;i mogu reć da rulaaa...! )
Uglavnom,i dalje nije nešto pre,odnosno ne gre mi ispod 30 sec. ali imam Venija tak da...je to o.k.
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 15.10.2006., 15:55   #246
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Staro 18.10.2006., 01:00   #247
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Nisam od meme shot uzeo aaa
Ugl 2*1GB DC 4 4 4 12
FSB : DRAM-1:1
Ovo je ovak zasad:
http://img206.imageshack.us/img206/5065/superpi1cn8.jpg
žmnpp
Staro 18.10.2006., 23:26   #248
overlord
overlord's Avatar
Lokacija: Slavonski brod
Postovi: 73
Ja 38sec kad sam ga clocknuo za 240mhz-a
cekam sada brzi ram onda cu ga do ibera dici pa da vidim koliko onda moze
Nema zene do rakije!!
overlord je offline   Reply With Quote
Staro 20.10.2006., 00:14   #249
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Skužio sam da je problem bio u ramu u 1 keksu evo ovo je skepano za 5 min, kad stignem pozabavit ću se više i naravno čim se riješim ovog boxa..
http://img142.imageshack.us/img142/3237/3500ha1.jpg
žmnpp
Staro 21.10.2006., 00:24   #250
ivan OS
ivan OS's Avatar
Postovi: 910
ivan OS je offline   Reply With Quote
Staro 21.10.2006., 11:56   #251
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
presta sam se igrat jer mi je dosadilo šta nemam pošteno hlađenje. Sad ga lipo držim na min voltaži i kako je zahladilo ne prelazi 42
Smartguy je offline   Reply With Quote
Staro 23.10.2006., 18:48   #252
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Rješio sam se Kinga i uzeo poštenu memu (doplatio mizernih 130kn) radi se o Crucial Ballistix DDR2 1000 2*1GB.
Igrao sam se malo sa postavkama i ostao sam ugodno iznenađen.
Evo meme na 1,2GHz 5 5 5 15 2,3V omjer sam stavio asihron da vidimo do kud ide mema.
http://img305.imageshack.us/img305/3917/ddr1200uq0.jpg
Na 1250 je pucao Super Pi makar sam dao još volti i stavio latencije na 5 6 6 15, tako da sam zasad tu stao.
Ovdje sam išao vidjet koliko ide proc sa memom, koliko sek ispada, znam da bi to moglo i bolje al imam box cooler pa trenutno nemogu više od ovoga osim toga CPU-Z je krivo očitao voltažu proca koja je bila prema biosu 1.45V
U međuvremenu sam imao problema sa Royal Vistom jer mi patch na neku foru neće radit tako da sam stavio Style XP i kad sam morao očitit cmos nisam vratio vrijeme i sve je otišlo u k****
http://img435.imageshack.us/img435/3633/900yk5.jpg
I zadnja slika je onak kak mi sada je, dakle mema na 1.9V, proc voltaža na def i neka tako zasad bude, kasnije ću probat dal se što dobiva ako memu stavim u neki drugi omjer a proc ostavim ovako. U međuvremenu sam riješio problem sa satom i nasreću Royal Vistu
http://img435.imageshack.us/img435/1518/defnq5.jpg
Sa obzirom na razliku u cijeni između Kingmaxa DDR2 800 1GB od 1023kn i Crucial Ballistix DDR 1000 1GB od 1231kn sa tim da Crucial ima HS na sebi, ima 2 god garancije više i ide jako lijepo ako se radi o E6300 ili nekom drugom procu koji treba da mema ide visoko slobodno mogu reč da se isplati dat malo više kn za njega, osim toga ima tu još Crucial Ballistix DDR2 667 1GB od 893kn koji ide slično poput ovog jačeg brata tako da se više isplati nego Kingmax..
Specijal TNX to Masni
@Masni
Si zadovoljan ili moram još tjerat : sweating
žmnpp
Staro 23.10.2006., 21:26   #253
vex
vex's Avatar
Lokacija: sl. brod
Postovi: 1,313
Staro 23.10.2006., 21:57   #254
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,910
Evo da refresham malo svoju rezu,tu je i naravno motiv više za sve vas,još čekam da mi se netko približi,pa da imam razloga i ja ići dalje
13.125
A tu je i 13.109 ali ovaj gore je mjerodavniji,vidi se checksum
Staro 23.10.2006., 23:40   #255
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Autor buljo Pregled postova
Vidim da ti isto pokazuje voltažu kao kod mene kad ga previše digneš, koja je stvarna?
Pri onih 3.9Ghz 1.625v...sada je na 3.6Ghz 1.55v...
Staro 24.10.2006., 00:34   #256
teofil
Udaram Ljude Za Pare
teofil's Avatar
Lokacija: BEHIND YOU
Postovi: 835
Evo ja to slozio i na brzinu nesto clockao!Nije lose za pocetak zapravo ovo ubija.
BTW;Koliko mu smijem dati napona?Byg Typon je gore
http://i13.tinypic.com/441sw8l.jpg
teofil je offline   Reply With Quote
Staro 24.10.2006., 03:11   #257
teofil
teofil's Avatar
Postovi: 835
Edit;13.032!!
Nema predaje
Ali mislim da je ovo procesoru kraj,da mi je neka mema sto ide na na cl3 i 866mhz to bi bilo strava.
Ajd nek mi netko DA volje da pokusam opet
Zadnje izmijenjeno od: teofil. 24.10.2006. u 03:48.
Staro 25.10.2006., 01:02   #258
vex
vex's Avatar
Lokacija: sl. brod
Postovi: 1,313
ima novi bios, idem sa njim pokušati : CoolRamb
Staro 25.10.2006., 16:22   #259
nexus-6
Pero_Snajper
nexus-6's Avatar
Postovi: 649
Autor Thoroughbred B Pregled postova
Poanta => undervolt i overvolt može nepovratno oštetiti jezgru,nisam nigdje spomenuo da je može spržiti,ako si na to mislio
Nemam pojma, ali ako polako stupnjevito spustas napon i testiras stabilnost pretpostavljam da je mogucnost takvog ishoda jako mala... Rekao bih da je overvoltanje ipak malo opasnija radnja
Evo ja svog ovak drzim, hladno i tiho a opet fino vuce:
http://img160.imageshack.us/img160/4275/sshotxb0.jpg
Sve stabilno.
Windows: AMD FX8320 @ 4.2 / GA-990XA-UD3 /16 GB DDR3 / R9 285 / Vertex 4 128 / SS-600HM / 3D Aurora
Android: Galaxy Tab S, Galaxy S3, ATV400 x 2
nexus-6 je offline   Reply With Quote
Staro 25.10.2006., 17:38   #260
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Tak ga vozim sad
Ja moram riješit cooler pa onda idem iznad 3600, idem lovit one likove sa 6600
žmnpp
Staro 25.10.2006., 22:53   #261
Wolverine
Wolverine's Avatar
Postovi: 12,423
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 26.10.2006., 15:45   #262
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
evo overclockani celer 2.53ghz u akciji
edit: samo kliknite na sliku, nece preview pokazati
Staro 31.10.2006., 18:43   #263
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Došo freezer došle nove reze
Imam problem a to je što mi matična undervolta pa nemogu do 4GHz, dakle max u biosu je 1.7V koje padne na 1.64V
Ovo je max koji sam izvukao al nije stabilno.
E6400 max OC by Buljo 3936MHz.
Evo ovako radi stabilno, nisam još vrtio 32MB jer ne stignem više, kasnije ću i to.
OC 3925MHz
To je 85% overclock, jako lijepo za jedan dvoglavi proc.
Matičnu sam prije išao provjerit dal ide na 500MHz i ide, kasnije ću vidjet koliko iznad toga ide.
Sve u svemu sam zadovoljan al žao mi je što nema više volti u biosu da dam procu da ga nafrljim na 4GHz al ok.
OVERKILL: sweating
žmnpp
Staro 04.11.2006., 00:29   #264
teofil
teofil's Avatar
Postovi: 835
EDIT;12.922
Da lijepo se vidi razlika u caceu.
Evo da se odužimo masnom za spam jedan ispod 12sec
Ići će ovo i na 4gige dok se malo razradi
Staro 04.11.2006., 01:05   #265
teofil
teofil's Avatar
Postovi: 835
Ploča-1.75V
Cpu-1.69V-Zaladilo je ovih dana pa ću kad uhvatim vremena stavit 1.75v i probati 4.0 sad mi se neda smrzavati
Rami-2.2V
Gledam po stranim forumima skoro svi idu na 4.ghz,nama na balkanu su uvalili "smeća" koja ne idu na 4 a za "europu" šalju ove bolje primjerke
Ma navući ćemo i mi kad uđemo u europu
EDIT;zaboravio sam napomenuti da mi je temperatura procesora na toj voltaži bila 23C i nikad nije prelazila 29C,hladnjak iz siga kućište i prozor otvoreni
A kućište je odmah ispod prozora.
Temp ploče 23-27.
Staro 05.11.2006., 15:04   #266
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
nažalost nemam shoot od 3840 mhz od prije mjesec dana (upalio sam mem test i odma se srušio sistem:clap: ) no i ovo je dobro, sa ovom memom i 2,1V teško će ić bolje, kolkio-tolko stabilno
proc je na 1,55, mema na 5-5-5-1@2,1V, omjer 1:1, mislim da bi mema išla i na preko 480 uz još 100-200mV, al matična ne da više,, zasada
bobe je offline   Reply With Quote
Staro 05.11.2006., 18:16   #267
eN-Ge sila
me too isto
eN-Ge sila's Avatar
Lokacija: kastela
Postovi: 169
sve je na slici. veci fsb nisan ni pokusava
eN-Ge sila je offline   Reply With Quote
Staro 07.11.2006., 14:24   #268
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Žao mi je što nemam niti jedan stari SS, a i ovaj je slab...
http://valid.x86-secret.com/show_oc?id=136231
edit:
Ne znam zašto je na validation linku drukčija freqva nego meni na kompu:confused:
Nemam više lema!!!
Staro 07.11.2006., 15:34   #269
atha
atha's Avatar
Postovi: 9,067
Sachu sve da vas pokorim. (btw, nadam se da je sve ok, nisam jos do sada radio validaciju, valjda je ok)
Work Rig (@default):
SuperPi 1M: 46,127s
Validation: http://valid.x86-secret.com/show_oc?id=136248
___________
Just atha
x
Staro 07.11.2006., 17:16   #270
DocZg
DocZg's Avatar
Postovi: 170
DocZg je offline   Reply With Quote
