Staro 10.10.2006., 17:41   #1
Habu
Habu's Avatar
Postovi: 56
Grafička do 1200 kn
Daklem, koju grafulju uzeti za navedenu cifru i zašto?
Koristit će se za igranje (zrakoplovne simulacije)
Unaprijed hvala na odgovorima.
Pozdrav
Habu je offline   Reply With Quote
Staro 10.10.2006., 17:42   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Malo vise informacija nebi skodilo...
Ostatak konfe? Jel PCI-E ili AGP?
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 10.10.2006., 19:29   #3
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,316
..7600gt pci-e ili ati 1600 pro za agp
imas tu temu:
http://forum.pcekspert.com/showthread.php?t=48786
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 11.10.2006., 00:03   #4
kalixius
...carpe diem...
kalixius's Avatar
Lokacija: Zagreb - okolica
Postovi: 1,363
Point Of View GeForce 7600GT(link) 256 MB DDR3 128 bit, PCI-X, core: 560 MHz, mem.clk: 1400 MHz , DVI-I, VGA, TV-out, G73/GT, retail - 1196kn
GECUBE X1650PRO Extreme(link) 256MB DDR3, VGA+TV+DVI out, VPU: 600 MHz, mem.clock: 1,6 GHz, 128 bit, HDTV out, dual link DVI, TV out cable, DVI adaptor, HDTV cable - 1099kn
po meni dobre grafe za tu cijenu...meni više privlači ova 7600GT ali da se mene pita onda bi dodao 180kn i ubo u Linksu ASUS Extreme N7600GT/2DHTV, GeForce 7600GT, 256MB DDR3, dual DVI, TV
kalixius je offline   Reply With Quote
Staro 11.10.2006., 00:43   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Zasto dat 180kn vise za Asusicu kad je identicna PoV? Nema cak ni bolje hladjenje...
Staro 11.10.2006., 02:05   #6
kalixius
...carpe diem...
kalixius's Avatar
Postovi: 1,363
Autor SRV Pregled postova
pa ima tu i istine...
ali kak bi mnogi rekli -Asus je ipak Asus...
neki su imali problema sa PoV,ali ok je grafa.
Staro 11.10.2006., 14:38   #7
Panzer
Panzer's Avatar
Postovi: 1,814
E vidis, da kupujem grafu za PCI-E, uzeo bi Gainward ili Leadtek. Ipak su carevi za nvidia chipove.
Evo iz linksa.
http://www.links.hr/index.php?option...kl=051.803.188
UPGRADED...
Staro 11.10.2006., 15:18   #8
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Panzer Pregled postova
Evo iz linksa.
Slazem se. Ovo mi je vec bogzna koja Leadtekica i nikad problema. Samo se Leadtek ulijenio u zadnje vrijeme pa isporucuje najcesce referentne coolere. Kad se samo sjetim onih 6800GT, kila bakra Ili 6800LE, ima bar pola kile u onom cooleru.
Dok se Gainward u zadnje vrijeme jako popravio...
Uglavnom raduje bih kupio od te dvije firme neko neki tamo XFX
Staro 22.10.2006., 18:48   #9
Domek
Domek's Avatar
Lokacija: Međimurje__M.S
Postovi: 53
mem.clock:1.6 GHz to je maksimum za clock?
Domek je offline   Reply With Quote
Staro 22.10.2006., 21:26   #10
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Autor Domek Pregled postova
Da,najbolji izbor za te nofce..ali simulacije su bolesno zahtjevne hw...sa 3x više love mislim da bi tu i tamo bilo škljoc škljoc...20fps..svejedno,super kartica za tu lovu..
Staro 22.10.2006., 22:44   #11
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Pa ta kartica bas i nije isplativa kad ima Albatronka 7600GT za 1150kn.
Staro 23.10.2006., 02:30   #12
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor Habu Pregled postova
Pozdrav
Za te novce možeš dobiti novu X800Xl (ako se ne pališ na sm3 i slične điđe)
X1650 Pro imaš već od 880 na gore...
X1800GTO je oko 1350, to bi ti kaj se tiče ATI-ja bila najbolja solucija (ako bi navukao još 150 kunića)
Staro 23.10.2006., 14:53   #13
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
ATI Radeon X800XT Platinum Edition 256 MB VIVO AGP
Ovakvu sam imao-rastura(samo naravno nema shader 3.0)
1100 kn, fiksno, ZG only.
Ne zanimaju me zamjene.
091/738-1588
P.S. nemam ništa sa čovjekom,ja sam iz Dj -samo sam ugledao oglas i sjetio se
MSI B450M pro-m2 max-ryzen 7 5800xt-nvidia 5060 ti - Asus rog swift PG278Q
damir1 je offline   Reply With Quote
Staro 23.10.2006., 15:02   #14
atha
atha's Avatar
Postovi: 9,067
Predlozio bih ti isto kao Jeltz, znaci x1800GTO, ako si u mogucnosti malo se rastegnuti za tu razliku.
Inace - x1600xt, odnosno x1650pro koja je vec sada nabavljiva.
Na X8XX seriju osobno nebih sada isao, jer se lagano palim na SM3.0 djidje. : nuts :
___________
Just atha
x
Staro 23.10.2006., 16:04   #15
thedream
thedream's Avatar
Postovi: 5,458
Autor atha Pregled postova
Ma pusti to chief..to su ti newbie spike..kad dođe dx10,opet ćemo svi skupa kukati..bolja je x800xl od svih tih x1600tki i 7600tki..još uvijek...
Staro 23.10.2006., 16:13   #16
atha
atha's Avatar
Postovi: 9,067
Ma samo malo Jeltza zekim.
Inace - imam x850pro, koju ne razmisljam mijenjati prije dx10 serije grafickih kartica. Koliko igram - i ovo mi je previse.
(jos samo da mi novi NFS zavrti na 1280x1024 i ja sretan )
___________
Just atha
x
Staro 23.10.2006., 16:17   #17
thedream
thedream's Avatar
Postovi: 5,458
Da,i ja,presretan : cheers2 ...ma ja bi neki novi Test Drive..još na ormaru 4rka čami..i skuplja prašinu..to je meni prejako kad se sa 250 u zid zaletiš i nastaviš vozit ko baja : roller : ...strašno...da,trebao bi taj NFS doć, postalo dosadno malo igrat ovaj WoW...a od Obliviona ništa dobroga da izađe..ha Jelc?
OT: Nisam mogao odolit a da ga ne stavim u avatar..prvi album,lolčina do poda
Staro 23.10.2006., 16:26   #18
Jelc
Super Moderators
Postovi: 17,485
Gothic3 je ok, samo malo bugovit...NW2 je gold i trebao bi izaći za desetak dana (navodno)
Dakle-ima igara....
Staro 23.10.2006., 16:30   #19
thedream
thedream's Avatar
Postovi: 5,458
Autor Jelc Pregled postova
Dakle-ima igara....
Scarface ? Izgleda dobro...kao GTA..za chillanje...neću spamat više..samo da pitam..probao?
Staro 23.10.2006., 20:45   #20
Domek
Domek's Avatar
Postovi: 53
x1800gto ima sm3.0, 256bit-a?
gdje ima za kupit (agp)
Staro 04.11.2006., 05:06   #21
spawn
spawn's Avatar
Postovi: 8,476
X1800GTO ili 7600GT ? Znam da je prva brza od druge kad se ukljuce AA i AF radi 256-bitne sabirnice ali opcenito me zanima koja grafa je bolja. Ima li X1800GTO SM3.0??
Staro 04.11.2006., 08:57   #22
Postovi: 34,057
Ima. Sve X1xxx imaju SM3.0.
