Mutant Year Zero
Postovi: 509
Konfiguracija za 7500-8000 kn
Dakle konfiguracija za pravnicu sa naglaskom na office, povremeno neka bezazlena igra i da bude tiha i hladna. U tu cjenu mora biti ubačen i monitor i printer, sve iz jedne trgovine. |
Postovi: 718
Monitor 17'' LCD Samsung SM 740N, 8ms, 300 cd/m2, 600:1 1.601,26 KN 1.499,05 KN Kućište THERMALTAKE Mambo VC2000BNS, MIDI, crno, bez PS 384,36 KN 359,82 KN Napajanje CHIEFTEC 350W, Delta GPS-350BB-101A, 12cm fan, ATX2 272,77 KN 255,36 KN DVD±RW LG GSA-H10, 16x, crni, Dual layer, DVD+-R/RW/R9/RAM 307,33 KN 287,72 KN VGA PCI-E SAPPHIRE ATI RADEON X1300 256MB DDR2, DVI, TV 605,91 KN 567,23 KN CPU INTEL Core 2 Duo E6300 1860MHz BOX, socket 775, 2Mb c., FSB 1066MHz, 64 bit, DualCore 1.574,55 KN 1.474,04 KN RAM PC-4200, 1024MB, DDR2, PQI, 533 MHz 1.032,36 KN 966,47 KN HDD 200.0 GB SAMSUNG SpinPoint SP2004C, Serial ATA II, 8 MB cache, 7200 okr/min 602,93 KN 564,44 KN MBO ASUS P5B, i965, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775 1.347,11 KN 1.261,13 KN ukupno: 7.728,58 KN 7.235,26 KN treba jos printer ubaciti, konfa iz linksa...ima jos i za mis/tipkovnicu i ako sam nesto izostavio ![]()
Suit up!
Postovi: 5,962
A da zaboravis na core2duo i uzmes athlon 3200-3500+ i neku gigabyte plocu s integ. grafikom? To je vec oko 2000kn manje. I ubodes neki laserski printer za 600-800 kn (Xerox phaser).
Postovi: 718
Postovi: 2,458
Links: 1. prijedlog mbo+cpu+memorija -MBO ASROCK 775XFire-eSATA2, i945PL, DDR2, zvuk, eS-ATA II, LAN, PCI-E, s. 775 537 Kn -CPU INTEL Core 2 Duo E6300 1860MHz BOX, socket 775, 2Mb c., FSB 1066MHz, 64 bit, DualCore 1474 Kn -RAM PC-5300, 1024MB, DDR2, CRUCIAL, 667 MHz 893 Kn 2. prijedlog mbo+cpu+memorija: -MBO ASROCK 939Dual-VSTA, ULi 1695, DDR, zvuk, S-ATA, LAN, AGP i PCI-E, s. 939 477 Kn -CPU AMD Athlon64 3000+ BOX, socket 939, Venice, 1800MHz, 512kb c., HTT 1000MHz 602 Kn -RAM PC-3200, 1024MB, DDR, CRUCIAL, 400 MHz 829 Kn Ostale ("zajednicke") komponente: -HDD 200.0 GB SAMSUNG SpinPoint SP2004C, Serial ATA II, 8 MB cache, 7200 okr/min 564 Kn -VGA PCI-E SAPPHIRE ATI RADEON X1300 256MB DDR2, DVI, TV 567 Kn -DVD±RW NEC ND-3570A, 16x, crni, Dual layer ± recording, bulk 259 Kn -DVD ROM LG 16x 52x, GDR-8164B, crni, bulk 128 Kn -Kućište COOLERMASTER Centurion 5, srebrno, CAC T05, MIDI, bez PS 464 Kn -Napajanje ENERMAX 300W, EG301AX-VE(G)(W), CoolerGiant, dual fan, ATX2 165 Kn UK Intel=4825 Kn UK AMD=4055Kn Periferija: -Monitor 20'' LCD SAMSUNG SM 203B, srebrni, 8ms, DVI, 300cd/m2, 600:1, TCO'03 2699 Kn -Tipkovnica Logitech Office Pro Keyboard, crna 98 Kn -Miš Logitech G1 185 Kn -Zvučnici LOGITECH 2.0 S-100 sea grey 57 Kn -Multifunkcijski uređaj CANON MP 150, printer, scanner, copy 590 Kn ili ako printa puno teksta: -Printer laser Samsung ML-2010, A4, 600 dpi, 8MB, USB 579 Kn Ne znam ima li potrebe (nevjerujem) za core duo procesorom ali kako je razlika u cijeni nekih 800Kn stavio sam i jedno i drugo...Slagao sam ovako jer je cijena 8K Kn, makar mislim da bi se office konfiguracija dala sloziti za 6K Kn sa periferijom... |
Mutant Year Zero
Postovi: 509
Hvala svima. |
