Staro 08.10.2006., 13:33   #1
pero55
pero55's Avatar
Postovi: 158
Čemu ovi konektori??
Čemu sluze ovi konektori na zvucnoj??
Došla zvucna doma, jos ju nisam spojil pa me sad zanima cemu to sluzi??
pero55 je offline   Reply With Quote
Staro 08.10.2006., 13:39   #2
Facelessone
Facelessone's Avatar
Postovi: 4,204
ova 2 gornja su ti za uštekat cd-room a doljnji za front panel slusalice/mic
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 08.10.2006., 13:40   #3
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ova dva gore su ti da u njih uštekaš neke druge kartice kako bi sa njih dobio zvuk; npr. TV tuner, modem, CD-ROM...
A ovaj dole, neam pojma...
EDIT: Bijah preduhitren
Staro 08.10.2006., 13:48   #4
pero55
pero55's Avatar
Postovi: 158
Hvala na informaciji za gornja dva,, (front panel slusalice/mic) ak imas na kucistu naprijed prikljucke za slusalice/mikrofon,ona ih ustekas u to,, ako se ne varam ??
Staro 08.10.2006., 13:55   #5
Facelessone
Postovi: 4,204
ne varas se
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 08.10.2006., 14:02   #6
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Gornji - kak je Faceless rekao - CD in, Aux in, za CD i za neki uredaj koji treba zvucnu (TV kartica recimo)
Doljnji bi mogao bit ovo kaj je faceless rekao, ili cak utor za Gameport.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 08.10.2006., 15:57   #7
pero55
pero55's Avatar
Postovi: 158
Ali kaj ja dobim sa tim,čemu mi to služi,, ako moze malo jasnije??
Staro 08.10.2006., 16:32   #8
atha
atha's Avatar
Postovi: 9,067
Ako imas case sa front panelom...
...da dovuces zvuk na njega.
___________
Just atha
x
Zadnje izmijenjeno od: atha. 08.10.2006. u 21:51.
Staro 08.10.2006., 19:50   #9
pero55
pero55's Avatar
Postovi: 158
Aha, hvala vam,,,
