Staro 06.10.2006., 17:23   #1
LUKA MX
Rakija
LUKA MX's Avatar
Postovi: 484
Dizanje Windoza
evo mog problema kada upalim komp i prije nego se pojavi boot screen javi se poruka:
Scanning IDE drives...
No drive attached to Fasttrack Kontroller.THE BIOS IS NOT INSTALLED.
ali bios radi normalno.Sve to mene nebi smetalo da mi se windowsi ne dizu 1 minutu,
sto mislim da je previse a gase se nekih 30 sec.
To mi se desava otkad imam kompjuter i s novim windowsima i driverima...
Evo moje konfiguracije:AMD Athlon 64 3200+,Asus K8V SE DELUX,2*512 MB memorije,
HDD segate Barracuda 40 GB MB Cache,Ge Cube Radeon 9600XT.
Hvala
LUKA MX je offline   Reply With Quote
Staro 06.10.2006., 18:03   #2
alimilano
alimilano's Avatar
Lokacija: Split Hrvatska
Postovi: 936
da pogledaš u bios-u možeš li isključit taj kontroler
alimilano je offline   Reply With Quote
Staro 06.10.2006., 21:29   #3
LUKA MX
Rakija
LUKA MX's Avatar
Postovi: 484
trazio sam ali nemogu naci,
jel ima tko kakav prijedlog sta da napravim????
Staro 06.10.2006., 23:00   #4
domy_os
domy_os's Avatar
Postovi: 18,846
Još kad bi netko pogledao FAQ na stranici proizvođača...
Question:
I've got an error message for K8V SE Deluxe - "No drive attached to FastTrak controller, the BIOS is not installed." during boot up. What should I do?
Answer:
You can find FastTrack controller as "Promise R20378 RAID controller" from the specification. The message reports that there is no hard drive attached on Promise controller. It is just informing you when you have not connect any hard drive on Promise controller. Hence, if you didn't connect hard drive on Promise controller, you can ignore this message.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 07.10.2006., 19:25   #5
LUKA MX
Rakija
LUKA MX's Avatar
Postovi: 484
kako da ga ignoriram kad mi se windowsi dizu 1minutu,jel moguce da se dizu sporo zbog 2mb cachea hdd
Staro 07.10.2006., 19:38   #6
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
U biosu treba isključit ak ti smeta.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 08.10.2006., 10:52   #7
LUKA MX
Rakija
LUKA MX's Avatar
Postovi: 484
evo napokon sam nasao i iskljucio ali mislim da bi mi se windowsi trebali brze dizati,
