Staro 30.09.2006., 12:38   #1
xPsycho
xPsycho's Avatar
Postovi: 957
Nova Kanta
što mislite
što izbaciti
a što dodati
ima li koja bolja graficka od ove a da je cijena približno ista
Intel Core 2 Duo E6600 BOX, 2×2.4GHz, 1066MHz,775-pin,4MB
Thermaltake Big Typhoon AlCu Cooler, scK 478/775/939/754/A 1300 rpm,
MB Gigabyte 965P-DQ6, s775, i965, DDR II, SATA II, FW, GLAN
*Point Of View GF 7900 GT, 256MB, PCI-E, TV-out, 2 x DVI
RAM PC-6400, DDR2, CRUCIAL, KIT, Ballistix, DDR 800 MHz, 2x1024MB
DVD±RW PLEXTOR PX-760A, 18x, Dual layer ± recording,+ crna maska kućišta
DVD ROM PLEXTOR PX-130A, 16x 50x, crni, bulk
HDD WD Caviar 320 GB, serial ATA II-300, 7200 o/min., 16 MB cache, Raid Edition
Zvučnici LOGITECH, Z2300 (Subwoofer + 2 satellites)
Monitor Samsung SM 204B, 20" TFT, 5 ms, DVI, srebrni (Pivot)
Logitech UltraX Flat Keyboard HR OEM, USB/PS2
Miš LOGITECH, MX Revolution Cordless Laser Mouse, USB
Chieftec gamer tower GX-01B, bez PS, crno
Napajanje OCZ 520W, ModStream, ATX2 ver 2.0
Creative Labs AUDIGY2 ZS
Zadnje izmijenjeno od: xPsycho. 30.09.2006. u 17:19.
xPsycho je offline   Reply With Quote
Staro 30.09.2006., 13:50   #2
Mr. M
Postovi: 718
moze pitanje, zasto Raid Edition hdd? Nije li on osjetno skuplji od obicnog, a istih performansi?
Mr. M je offline   Reply With Quote
Staro 30.09.2006., 13:54   #3
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Raid edition koliko se meni čini ima NCQ,a WD-i bez te oznake ga nemaju.
Autor xPsycho Pregled postova
evo u Hg-spotu tj disk dođe 820kn........ tak da nije velika razlika između raid editon i običnog....... a što točno znači raid edition
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 30.09.2006., 13:54   #4
xPsycho
xPsycho's Avatar
Postovi: 957
Staro 30.09.2006., 14:05   #5
Mr. M
Postovi: 718
sad za wd-e neznam da li ostali imaju NCQ, ali onda seagate ovaj od 320 GB, ~770 kn, mozda bi ti on bio bolji izbor...
i cemu GIGA TOWER?
Staro 30.09.2006., 14:05   #6
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
A zasto uopce uzimas komp,sta fali ovome u sigu??
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 30.09.2006., 14:31   #7
xPsycho
xPsycho's Avatar
Postovi: 957
Autor BladeRunner Pregled postova
vec sam prije jednom prilikom rekao........
taj komp kojeg vidiš u sigu ostavljam u hrvatskoj.......a pošto idem u italiju radit (vec od ovog utorka) tam mi treba neki komp...... pa stoga kupujem drugi....
Staro 30.09.2006., 14:55   #8
Hrconja
Hrconja's Avatar
Postovi: 1,615
someone is gonna be rich
sviđa mi se konfa, pogotovo dio sa zvukom ^^
Hrconja je offline   Reply With Quote
Staro 30.09.2006., 15:47   #9
nicko
Postovi: 4,190
Ne tu Gigabyteovu maticnu...uzmi Asus P5B Deluxe....
Ostalo je ok...eventualno da uzmes X1900XT....
HDD je ok, a to sto je RE znaci samo kada ga stavis u raid polje, ima neke dodatne funkcije, da kazem tako, neda mi se objasnjavat dalje...
nicko je offline   Reply With Quote
Staro 30.09.2006., 15:53   #10
nino
nino's Avatar
Postovi: 12,600
Kupi tamo (IT), jeftinije ces proc
Staro 30.09.2006., 17:10   #11
xPsycho
xPsycho's Avatar
Postovi: 957
to cu najprije vidjeti gdje cu kupovati......trebam vidjeti kak se tam kreću cijene a kak tu.........
nicko : zašto nebi uzeo tu Gigabyteovu matičnu.....koliko sam cuo dost je dobra
a šta se tiče grafičke prvo sam i ja mislil uzeti tu X1900XT koju valjda i bum uzel
Staro 30.09.2006., 17:13   #12
xPsycho
xPsycho's Avatar
Postovi: 957
Autor Mr. M Pregled postova
i cemu GIGA TOWER?
tek sad vidio krivo sam napisao
mislim uzet ovo kučište
Chieftec gamer tower GX-01B, bez PS, crno, USB, Fire wire, audio, 1×8cm blue led fan, 1×12cm fan
Staro 30.09.2006., 17:33   #13
nicko
Postovi: 4,190
Jer Gigabyte ima velikih problema s memorijom i biosima, previse zahebancije, a zasto?? Takve stvari se ne bi smjele dogadjat na high-end plocama...
Uzmi lijepo P5B Deluxe ili P5W DH Deluxe i miran si...
Staro 30.09.2006., 18:34   #14
Mr. M
Postovi: 718
nice onda nemam prigovora
Staro 30.09.2006., 18:38   #15
Postovi: 7,568
Autor nicko Pregled postova
Sve Gigabyte ploče sa svim memorijama ili...? Ja sam kod frenda imal prilike sprobati DQ6 (tvornički BIOS) i E6600 u kombinaciji s 2x1GB Corsair TwinX memorije...ploča i memorija su se čist fino slagale (na defaultu i kod overclocka. Ali dobro, to je samo moj dojam. Čovek nije napomenul kaj misli delati sa tom konfiguracijom. Ako ne misli clockati, onda mu je IMHO dosta i neka ploča do 1.000 kn. Mada se i s takvim pločama da postignut čist fini overclock. Ostatak uloži u nekaj drugo. OSim ako baš treba/hoće ploče takvog kalibra, tj. za tolke pare.
DFI LanParty Ultra-D/SLi/SLi-DR su vodeće ploče, kad su takve stvari u pitanju, pa se/su se bez obzira na to kupuju/kupovale...i nikom ništ.
Staro 30.09.2006., 18:50   #16
nicko
Postovi: 4,190
Autor McG Pregled postova
D9 nema sanse da stavis na njih, a inace su jako izbirljive...cini mi se da Kingamxi 800 rade dobro na njima...
Da, ali za njih ima rijesenja. (Pod tim mislim na razno-razne biose, sto modane, sto tvornicke i problemi se rijese, a Gigabyte nije napravio jos posteni bios)
Stvarno steta, jer ploce imaju potencijala...
Staro 30.09.2006., 19:05   #17
Postovi: 7,568
Reko, vredu.
Možda izbace koji pošten BIOS, a da se u međuvremenu ne treba posezati za raznim moddanjima i sl.. Vrag ih zel s pločama za masu para, a problem do problema (neovisno o proizvođaču). Još se u to sve ubaci ljudski peh i (ne)sreća...i ima da polude svi poprek. Uglavnom, ako čoveku stvarno ne treba ploča za +1.500 kn, nek si fino zbere neku kolko-tolko jeftniju, a da opravdava omjer uloženog i dobivenog i niko sretniji od njega.
Staro 30.09.2006., 20:19   #18
xPsycho
xPsycho's Avatar
Postovi: 957
naravno da mislim clockati .........ako ne preporučate Gigabyte što ona od te dvije
a rekao sam jos davno zbogom ASUSU .....ali ipak mozda opet idem na njega...
Staro 30.09.2006., 23:13   #19
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
daj ne dramatiziraj.
d9 uredno radi, ali se slabo clocka.
corsair c4 memorije, kingmax 667/800 uredno rade i clockaju se sa 965p serijom ploca (isprobano kod mene, na ds3, vjerujem da i ds4 i dq6 rade isto tako).
Ph03n1x je offline   Reply With Quote
Staro 30.09.2006., 23:42   #20
nicko
Postovi: 4,190
Za E6600 ti je svejedno, jer oba dvije idu preko 400 fsb-a, a tada ce te proc pocet kociti, pa uzmi onu koja ti se vise svidja ili koja je jeftinija...
Autor Ph03n1x Pregled postova
Ti imas srece s tim Ali, ajde mi nabroji par ljudi koji su kupili Gigabyte pa da nisu imali problema? NHF, ali u ovom trenu Asus je bolji sto se tice svega...
Staro 01.10.2006., 10:54   #21
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
heh. zalosno ali tak je. pa i ja bi mu preporucio p5b radje....
...gle 965p-ds3(4) se moze uz puno volje dovesti u red. mnogo puta je kod ljudi koji zestoko pljuju po tim plocama najbitniji faktor njihova glupost, ne sama ploca... (nhf ikome ko je doista imao gadnih problema s tim plocama, ali vidio sam ovakvih gore navedenih slucajeva)
Staro 01.10.2006., 12:49   #22
xPsycho
xPsycho's Avatar
Postovi: 957
evo mali update
Matična : ASUS P5B Deluxe
Monitor : Monitor Samsung SM 205BW, 20" LCD, 6 ms, DVI, srebrno-crni (Pivot)
Grafička: SAPPHIRE ATI RADEON X1900XT
a što mislite o ovoj matični
http://www.links.hr/index.php?option...kl=050.306.160
Staro 01.10.2006., 12:59   #23
nicko
Postovi: 4,190
Nikako....nvidija, pa jos na intelu...nope...previse se grije taj chipset i jednostavno nije on za intela...
Staro 01.10.2006., 13:01   #24
xPsycho
xPsycho's Avatar
Postovi: 957
nisam znao pa sam zato pitao....... ali ono izgleda dobro.......a za chipset neznam dali se grije ili ne ........ onda ide P5B Deluxe
