Staro 19.09.2006., 14:31   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Tray Tools 1.2.6.930
Sa podrškom za X1xxx seriju
1.2.6.930
[+] Added configuration dialog for Overdrive 3. You can use it if you don't want to overclock your board on low level or
if you have a problem with low level overclocking. Remember this option will be active only if your video board support
Overdrive version 3 and ATI HotKey poller service is started.
[+] Added overclocking support for X1300/X1600/X1800/X1900. Memory overclocking for X1300 doesn't work in this release. Also
remember that you must disable ATI HotKey poller if your board can operate in 2D/3D mode or your clocks always will be
resets to ATI default clocks. Try do not overclock your board while any 3D games are active. Do it before launching game via
game profiles it is a safest way.[*] Updated color correction hotkeys, to support new color correction formula[*] Updated 3D renderer and benchmark module.
[F] Fixed situation when 3D renderer shows artefacts after using benchmark module.
[+] Added support for Avivo Colors correction. Hue/Saturation will only work on R5xx video boards. There
are no way to activate them for old video board, so do not ask me about it.[*] Updated auto FAN control functionality for R5xx boards.[*] Updated system information module. Added basic information about Overdrive support.
[F] Fixed broken OSD functionality for Direct3D8 games and applications.
[F] Fixed detection of current 3D profile with no GI option included[*] Now Shared memory information about FreeVideo and Texture memory will be updated only if 3D game
or application is active and OSD enabled.[*] Updated FlashOSD module. Added voltages information for X1xxx video boards and ASUS Video boards with FinTEK sensor
(like 9600XT/9800XT)
[F] Fixed rendering procedure in FlashOSD module for some of non-alpabetical characters.
[F] Fixed bug when "Scale image to panel size" option doesn't work in certain situations.
[+] Updated support for HDTV modes. Added a few new modes. Only supported modes can be adjusted.
Note some modes can be disabled in certaint situation, such as display rotation
[+] Added support for "Perserve Aspect Ratio" option in Display module. If supported by LCD or DFP display.
[F] Fixed bug with hotkey for decreasing contrast in color correction procedure.
[+] Added GPU and Memory Voltage control procedure for X1600/X1800/X19xx (if supported by hardware)[*] Monitoring Graphs window now will be automaticaly reopened after suspend mode if it was active before entering
into Suspend mode.
[+] Added option to Force TV Detection.If you are using an older TV or one that has non-standard inputs that
may not be automatically detected, use Force TV Detection.
[+] Added test support for X1300/X1600/X1800/X19xx Radeon video boards into TV Out/Display module.[*] Improved TV Out support for mobility chips. ATT has partial support for mobility chips, so do not
expect a lot[*] Updated Core names database. Added information about RV570/RV535 chips.
[+] Added option to automatically shutdown "ATI HotKey Poller" for R5xx board. If you want to use overclocking functions in
ATI Tray Tools for those video boards, you must always disable "ATI HotKey Poller" service to prevent from resetting
clocks and voltages to default state.
[F] Fixed FlashOSD functionality corrected wrongly shown GPU/Memory speed for R5xx video board in 3D mode.
[+] Added localization support. Big thanks to all who helped to translate ATI Tray Tools into other languages.
[+] Added new command line parameters:
/LDSD - Load "Default Single Display" profile
/EXD - Turn Extended Desktop On/Off
[+] Added an ability to skip overclocking at start up. Just press left CTRL
button while windows is loading.
http://www.radeon2.ru/atitray/attsetup.exe
Staro 19.09.2006., 16:50   #2
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Moram priznat da na prvi pogled djeluje dosta dobro i enhanced...
Jako puno truda i popravki je ulozeno u ovaj programcic..
Mislite li da bi dobro dosla inacica na HR jeziku?
G0RKI je offline   Reply With Quote
Staro 19.09.2006., 17:40   #3
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
stavio sam radi super...može se konačno klokat na x1800,čak mi i sad pokazuje koliki je frame rate u PES5 hehehe,stalnih 60
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 19.09.2006., 17:47   #4
atha
atha's Avatar
Postovi: 9,067
Thx, odmah cem da probam.
___________
Just atha
x
Staro 19.09.2006., 20:35   #5
domy_os
domy_os's Avatar
Postovi: 18,858
Yeah, to se čeka mjesecima!
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 19.09.2006., 21:33   #6
Jelc
Super Moderators
Postovi: 17,485
Autor G0RKI Pregled postova
Pa, tražio je prevoditelje
http://forums.guru3d.com/showthread.php?t=193205
Staro 19.09.2006., 21:42   #7
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Jelc da znam zato i pitam.
Staro 19.09.2006., 21:49   #8
Jelc
Super Moderators
Postovi: 17,485
Pa-ako ti se radi i imaš slobodnog vremena-navali
Staro 20.09.2006., 11:49   #9
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
meni ne radi mijenjanje voltaže memoriji? a vama.Sve drugo(i GPU voltage) normalno
Asus Z97-A-i5 4690K-xfx 470 -Kingston DDR3 1866 SDRAM 2x4GB -dvd ladice-asus 450W-sve to u chenbro gaming bomb, jedinici + Dell U2412HM
damir1 je offline   Reply With Quote
Staro 20.09.2006., 13:04   #10
Jelc
Super Moderators
Postovi: 17,485
Autor damir1 Pregled postova
Probaj iz profila igre.
Uključi hardware monitoring pa pogledaj poslje da li radi.
Staro 20.09.2006., 22:59   #11
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
pogledat ču -iako mi u biti ne treba ,držim ju na 500-600 i u 3D dovoljno mi je za sad .ali znaš kako je srce junačko neda mira treba istraživati
Staro 20.09.2006., 23:08   #12
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Autor Jelc Pregled postova
hm ,nisam skužio-šta iz profila igre.Overcloking mi radi-ne radi mi dizanje voltaže memoriji(nakon apply-ja vrati na 2.0861) dok mogu za gpu bez problema mijenjati
probao na 1.4500. U profilu igre ne vidim opciju za dizanje voltaže memi.
Staro 21.09.2006., 02:29   #13
Jelc
Super Moderators
Postovi: 17,485
Napraviš si jedan normalni profil "default" npr sa orginal taktovima i naponom.
Drugi sa povišenim naponom i taktovima i nazoveš ga npr oc1.
I kad ideš igrat ili hoćeš benchat izabereš oc1 profil.
To sve namještaš u overclock postavkama ATT-a.
Mislim da bi tako trebalo delati.
Staro 21.09.2006., 04:56   #14
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Napokon sam stavio da mi radi na 500/500 a ne 500/490 ko sto je prije bilo .
I radi da na kompu i TV mogu imat istu sliku.
Staro 21.09.2006., 09:41   #15
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Ma znam praviti profile itd. ne kužiš me voltažu memoriji nemogu podići
pokušaj na nekoj 19xx pa češ viditi o čemu pričam.Prije nije bilo niti ponuđeno (dosadašnje ver.ATT) sada to nudi i za GPU sa def 1,2000 bez problema digneš-ja sam probao na 1,4500 a nudi do 1,6000
međutim za memoriju imaš strelice lijevo i desno(kojima smanjuješ-povečavaš) vrijednost.Da bi to i postavilo treba još Apply-e za memoriju ga tada vrati na defaultnu(2,0861)vrijednost.Pokušao sam je i skinuti na manje,isto neda
Staro 21.09.2006., 11:43   #16
Jelc
Super Moderators
Postovi: 17,485
Je, pa nemogu znati dok nemam neku X1xxx u kompu
Danas sam se uspio poigrati sa jednom-sve radi fino.
Pretpostavljam da nisi obratio pažnju na proceduru pri instaliranju ATT-a.
"For owners of X1xxx cards. Do not select OLD I2C Method ininstallation procedure or you will not be able to apply memory voltage."
A lijepo piše kod instaliranja kaj je za kaj.
Ja sam maknuo kvačicu sa te opcije pri instalu i sve radi kak treba.
Isprobano na X19xx seriji.
Staro 21.09.2006., 13:15   #17
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
ček, ne mogu OC-ati mem na svojoj grafičkoj?
porke? glupo... u ati tool-u bez problema...
mislim, nisam probao att, pa pitam da ne instaliram bezveze...
a ovo sa dizanjem voltaže na gpu, je li to moguće na svakoj grafi? jer to bi mi taman dobro došlo da je natjeram na pro taktove...
Staro 21.09.2006., 13:36   #18
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
[QUOTE=Jelc;529000]
Sto posto si u pravu-misliš da sam išta čitao samo bub.Idem reinstalirati ali 99,99% je to.Hvala ,drugi puta i čitam malo ( : stoopid me )
Edit: da to je naravno- sad sve radi, Jelc
Staro 21.09.2006., 14:11   #19
mrtvi
mrtvi's Avatar
Postovi: 183
jel moram maknut ati tool dok koristim Ati tray tool
mrtvi je offline   Reply With Quote
Staro 21.09.2006., 15:13   #20
domy_os
domy_os's Avatar
Postovi: 18,858
Ne moraš.
Staro 21.09.2006., 15:16   #21
Jelc
Super Moderators
Postovi: 17,485
Autor mrtvi Pregled postova
Najbolje da.
Pogotovo zato da se ne pokolju razne postavke koje prog mjenja u registryu.
Ne toliko zbog clockanja nego zbog igri.
Ja sam znao imati i Rivu, AT i ATT supa bez problema, ovo je zbog sigurnosti da nemoraš razmišljati kaj zeza ako bude problema.
Autor damir1
To ti je tako kad se samo klika next/next/next...
Za koji dan bude izašla novija verzija koja će automatski pri instalaciji podesiti sve kako treba.
Za one koji ne čitaju manual
Staro 21.09.2006., 15:34   #22
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
quilty-priznam ubuduče ču čitati dok mi ne : flyingey
