Postovi: 77
Ponuda
Na mom faksu su ponudili lenovo/ibm laptopa za koji tvrde da su 30% niže cijene nego u dućanu, a meni se ne čini baš tako jer mislim da se može bolje proći ako se kupi neki drugi laptop pa evo vam spec i cijene. Prokomentirajte jel se to isplati ili ne?? R60:Intel Celeron M Processor 410 (1.46GHz, ThinkPad 802.11 a/b/g), 512MB, 60GB, 15" XGA TFT (1024x768), Multi-Burner (DVD/RW CD/RW), Intel Graphics Media Accelerator 950 up to 128MB, Modem, Gigabit Ethernet, IEEE 1394, 3 USB, Ultranav, 6 cell battery, Rescue and Recovery, Client Security Solution with security chip, težina 2.9 kg, autonomija preko 2.5h, PC DOS 2000 licencija, 1 godišnje jamstvo 4.990 kn sa PDV-om R60:Intel Centrino Duo Mobile Technology (Intel Core Duo Processor T2300E, 1.66GHz, ThinkPad 802.11 a/b/g), 1024 MB, 60GB, 15" XGA TFT (1024x768), Multi-Burner (DVD/RW CD/RW),Intel Graphics Media Accelerator 900 up to 128MB, Modem, Gigabit Ethernet, IEEE 1394, Bluetooth, 3 USB, Ultranav, 6 cell battery, Rescue and Recovery, Client Security Solution with security chip, težina 2.9kg, autonomija preko 3.1h, PC DOS 2000 licencija, 1 godišnje jamstvo 6.990 kn sa PDV-om T60p:Intel Centrino Duo Mobile Technology (Intel Core Duo Processor T2500, 2,0GHz, Intel PRO / Wireless 3945ABG), 1024 MB, 100GB (7200), 15" XGA TFT (1600x1200), Flexview, Multi-Burner (DVD/RW CD/RW), ATI Mobility FireGL V5200 256+256 MB graphics, Modem, Gigabit Ethernet, Bluetooth, 3 USB, Fingerprint Reader, Rescue and Recovery, Client Security Solution with security chip, Active Protection System, težina 2.5kg, autonomija preko 4.3h, PC DOS 2000 licencija, 3 godišnje jamstvo 13.222 kn sa PDV-om |
Postovi: 4,190
Je, na FER-u ![]() Ovi slabiji modeli su jeftiniji otprilike 1k kn nego u ducanu, sto je ok... Imas www.nabava.net pa pogledaj sto te zanima... |
Postovi: 4,190
A cuj...ako nekome treba, mozemo se dogovoriti, ljudi smo ![]() |
Postovi: 27
joj kad vidim sve ove ponude...zaboli me glava...privlacna je ova ponuda za T60p...da je bar core 2 duo.... ....nc8430 i nw8440 su po cijeni i konfiguraciji tu negdje...ne znam koja je graficka bolja...ja ipak cekam core 2 duo pa onda krecem u akciju...do kad traje ta pogodnost za fer-ovce.....thx..... |
Postovi: 4,190
Da laptop dolazi instaliran sa DOS-om, ne windowsima.. |
Postovi: 77
Danas sam razgovarao sa budućim dekanom o tim laptopima. Pito sam ga jel se može uzeti neki drugi r60 sa npr. boljom grafičkom ili ako bog da sa core2 duo, a on mi reko da im pošaljem mail pa da se dogovorim s njima. Jedino ne znam gdje da pošaljem mail i sumljam da će išta biti od toga ali eto samo da znate da možda i postoji opcija žicanja ![]() |
Postovi: 4,190
Posalji firmi onoj koja prodaje te laptope...ne znam sad kak se zove, ali mislim da imas na FER webu.. |
Postovi: 77
evo dobio sam odgovor i čovjek mi je rekao da nisam prvi koji pita ![]() ![]() |
Lokacija: Zagreb DUBRAVA
Postovi: 31
Mozda se najvise isplati otici na ACT Plavecovu stranicu i uzeti Z60m za 9,27 kuna! ![]() http://www.plavec.hr/index.php?mod=p...ware&view=list |
Postovi: 53
frend je gledao da uzme neki od ovih laptopa iz FERove ponude, ali smo ga na kraju ipak nagovorili na hp9420 iz linksa za manje od 10k kn.... http://www.links.hr/index.php?option...kl=010.900.049 jos ce si metnut 1gb rama mjesto 512mb i mirna bosna : goood : po meni (i mom ocu) se ovaj ibm/lenovo za 13k kn ne isplati..... jer sa popustom dode puno, a za manje para dobis bolji notebook sa boljom grafickom (mislim na ovoh hp-a ![]() |
Postovi: 4,190
Ali IBM je IBM...taj je nepokvarljiv... |
Postovi: 27
hmmm...
mislim da je ova ponuda za t60p mrak.....kako vec rekoste ibm je nekvarljiv i kako sam ja skuzio graficka mu nije slaba jer je to u biti modificirani x1600....dalo bi se razmislit... |
Postovi: 4,190
Ma X1600 je super graficka na laptopu!! I ponuda uopce nije losa... |
#16 |
Lokacija: Varazdin
Postovi: 288
IBM je zvjer i ja sam pocel razmišljat o ovoj ponudi, mada sad sljedeci mjesec dolazi T61 model, pa neznam dal se isplati cekat
Msi neo2/wini 3200+/OCZ TCCD/6600gt |
#17 |
Postovi: 77
ma taj t60p je super za 13k kuna ali ipak još bih volio da je core2duo pa se sad razmišljam jel imam limit od 10k kuna a ovaj je 3k više jel mi se isplati. |
#18 |
Postovi: 27
i ja djelim tvoje sumnje marvine.....ja cu ipak pricekat dolazak core 2 duo procesora pa cemo vidit.....ponuda vrijedi do kraja kalendarske godine....ima vremena.... |
#19 |
Lokacija: Varazdin
Postovi: 288
Kolko sam cital T61 bude bil sa core 2 duo procesorma odnosno Merom, ovaj Intel T7200 Merom 2.0GHz 4MB L2 cache mi se jako sviđa Dal zna neko još koje informacije o t61 modelima, gvore da bude podrska za HDTV modeli sa 4:3 omjerom i 16:9 ekrana
#20 |
Lokacija: Varazdin
Postovi: 288
A po drugoj strani neznam dal se isplati cekat jer to nije tak velika razlika u performansama. Cekali bute Merom pa onda DX10 pa nekaj sljedece i nikad docekali. Jedino me zanima dal moze taj T60p vrtit bez problema Vistu?
#21 |
Postovi: 33,922
Koliko se sjećam uvjeta (imaš link negdje na forumu), T60p će sigurno moći vrtiti Vistu.
#22 |
Postovi: 77
Evo još jedno pitanje ![]() Sad kad sam skužio da mi je t60p i sa 30% popusta još uvijek skup zanima me jel bi mu ovo mogla biti dostojna zamjena?? http://www.arhiteh.hr/shop/index.php...oducts_id=1666 Jeftiniji je za 2k kuna, ali mozda ima malo losije spec, trebalo bi i ovo vrtiti vistu samo neznam kakvo je kućište nx9420 seriji itd... vaše preporuke pošto još nema recenzija za ove nove modele |
#23 |
Postovi: 4,190
Moras shvatit da je T60p IBM i placa se ime i kvaliteta i konstrukcija....kad gledas maloprodajne cijene u ostalim trgovinama, ovaj T60p je jako jeftin!!! To je odlican laptop i trajat ce dok se ne razbije ![]() Naravno, ne kazem ja da je HP los, dapace, ovaj model gore je odlican po specifikacijama (Vistu ce sigurno vrtit). |
#24 |
Lokacija: Varazdin
Postovi: 288
Ovaj Hp ima cak novi core 2 duo procesor samo kaj u specifikacijama krivo piše T5600 je core 2 duo.
#25 |
Postovi: 399
ima još koji hp kod nas sa core 2 duo? |
#26 |
...(=_o)...
Lokacija: Osijek/Đakovo
Postovi: 401
na www.arhiteh.hr imaš oko 8 komada sa Core 2 Duo, vidio sam jedan i u mikronisu.... |
#27 | |
Postovi: 399
kaj se tiče ibm-a uzmi ga ako ga misliš koristiti dok se ne raspadne. ![]() |
#28 |
Lokacija: Dubrovnik
Postovi: 9
#29 |
Postovi: 4,190
#30 |
Postovi: 27
uskoro dolazi hp nc8430 sa core2 duo procesorom (RH471EA), po meni dosta bolja opcija od t60p....mislim da ce cijena biti tu negdje kao i t60p u Fer akciji ako ne i manja....laptop je po svim recenzijama koje sam ja citao koma....kvalitetan dizajn, dobra konfiguracija i performanse, dobar ekran i rezolucija itd....sve sto treba.....: nuts : |
