Staro 04.09.2006., 05:21   #1
spawn
spawn's Avatar
Postovi: 8,368
Gigabyte 965p -ds3 i kingmax problem
Imam mali problemcic.
Baca greske u memtesu i prime-u kad ubodem:
-1 keks u zuti utor
-2 keksa u zuti utor
-2 keksa u narandzasti utor
Kad ubodem u narandzati utor jedan po jedan,memtest i prime prolazi.
Ploca u banani? Ima li ko takve probleme?
Ploca Gigaybte 965 ds3
Ram kingmax 2X 1gb 667
Staro 04.09.2006., 08:12   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pusti takt niže, jer vjerojatno sa 4 pločice ne radi dobro ko sa dvije.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 04.09.2006., 09:33   #3
nicko
Postovi: 4,190
-1 keks u zuti utor
Ispitaj svaki stick posebo je li radi, ali meni se cini da je tu problem nekompatibilnost...
nicko je offline   Reply With Quote
Staro 04.09.2006., 10:56   #4
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
ne vjerujem da je nekompatibilnost...moja konfa je delala full stabilno s kingmaxom na 933 mhz
..nisam testiral s memtestom...i da baca greske zaboli me, kad sve dobro radi...
Ph03n1x je offline   Reply With Quote
Staro 04.09.2006., 11:02   #5
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
možda imate drugačije biose bruno phoenix.
Staro 04.09.2006., 11:11   #6
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
ja kad sam imao kingmaxa imao sam F4 bios
Staro 04.09.2006., 13:25   #7
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
da da reko si da te nije briga dok sve radi,što tebi bruno ne radi osim što baca erore u dotičnim programima,sistem normalno podiže,igre i ostalo radi???,ja nisam nikad ta 2 testa odvrtio,ti imaš 2x512 on 2x 1gb,probaj neku drugu memoriju.
Staro 04.09.2006., 13:50   #8
spawn
spawn's Avatar
Postovi: 8,368
Pa izbacuje iz igre tijekom igranja.Smrzne se ako pokrenem vise stvari istovremeno. Imam f4 bios. Sada na jednom slotu nece uopce bootat. A sada u svakom slotu izbacuje error.
Napomena: imam 2 X 1gb ,gore sam samo naveo gdje sam ih i kako ubo u plocu.
Staro 04.09.2006., 13:59   #9
nicko
Postovi: 4,190
Jesi probao svaki stick posebno staviti, pa pogledati jel radi?
Staro 04.09.2006., 14:02   #10
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
nije iskljucena ni mogucnost da ploca zahebava...probaj neki drugi modul, pa ako ce se dogadat isto, nosi u servis
Staro 04.09.2006., 14:15   #11
spawn
spawn's Avatar
Postovi: 8,368
Autor nicko Pregled postova
Jesam. Prije su radili posebno na orange slotovima,sad ne rade nikako. Odnio sam ram kod frenda na DS4 pa cemo vidjeti.
