Povratak   PC Ekspert Forum > PC Ekspert > Komentari i prijedlozi
Zaključane teme
Staro 14.08.2006., 18:37   #31
Mr. M
Postovi: 718
meni neke stvarcice nisu jasne...ovak, ja sam vidio na forumu jednom na kojem je reputacija i ovi "zeleni kartoni" kako ih vi zovete, i to ide ovako; ako se dobro sjecam, 1 rep++ je broj rep bodova+broj rep bodova/neka konstanta, a 1 rep-- je broj rep bodova-broj rep bodova/neka konstanta. Kartonceki sluze za vizualnu predodju reputacije i nema ovog broja koji mi imamo. znaci, 1 karton oznacava npr 10, i onda ako ti je rep 20 imas 2 kartona.
Tako da mi je ovo malo nejasno...ali ako vas veseli
Mr. M je offline
Staro 14.08.2006., 19:21   #32
mITZEK jr
R.I.P Mitzek
mITZEK jr's Avatar
Lokacija: Prigorje zelene..
Postovi: 354
nije jos ni krenulo a svi ste graknuli!ajde dajmo priliku novim idejama!
there's no replacement for cubic displacement...except turbocharger
mITZEK jr je offline
Staro 14.08.2006., 20:03   #33
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
vBulletin manual kaže:
This section contains many settings that dictate how users of your forum are able to affect each other's reputation score.
  • Enable User Reputation system
    This is the global switch for the reputation system. If you disable this, users will not be able to rate each other nor will their scores be visible.
  • Default Reputation
    This is the reputation score that new users will start out with.
  • Number of Reputation Levels to Display
    When a user enters their User CP, they will see a list of their most recent reputation ratings. This affects how many of the latest ratings to display.
  • Administrator's Reputation Power
    If you wish to have administrator's wield a certain reputation power independent of their calculated score, enter it here. Otherwise, set this to 0 and they will use the same calculations as everyone else.
  • Register Date Factor
    The number of reputation points that a user is able to give or take is dependant on several factors, with the length they have been registered as one of them. A user's power is first initialized at 1 and then this factor and the factors that follow are used to increase it. For example if you set this to 365, every 365 days that the user has been a member of your forum, they would gain one point. So if they have been a member for five years, they would gain 5 points of power for a total of 6.
  • Post Count Factor
    The amount of posts that a user has can also affect their reputation power. Set this to number of posts that you want to award one point for. For example, set this to 50 and for a user with 500 posts, they would gain 10 points of power.
  • Reputation Point Factor
    The users current reputation score can also affect their reputation power. Set this to 100 and a user with a reputation of 1000 would gain 10 points of reputation power. If you set any of the power factors to 0, that will effectively remove that factor from having an effect on the user's reputation power.
  • Minimum Post Count
    If the reputation system is enabled, anyone will be able to rate a post but only users with a post count above the level you set here will be able to actually give points or take points from another user.
  • Minimum Reputation Count
    As with the post count above, a user must have a reputation above this level to be able to give or take points from another user's score.
  • Daily Reputation Clicks Limit
    This sets how many unique members that a forum user will be able to rate in any 24 hour period. Administrators can rate as many people as they wish.
  • Reputation User Spread
    This setting dictates how many unique members that a user must rate before they are able to rate the same member twice. The goal of this setting is to stop a member from either artificially bumping or dropping a user by repeatedly rating their posts.
http://www.vbulletin.com/docs/html/m...ons_reputation
Dakle na administratorima je da se malo poigraju i nađu najbolje omjere pojedinih faktora... što neće ići preko noći.
Glede 0 za npr. mitzeka i Costu, koliko ja vidim svi moderatori (including ozren/Beren/nara) imaju reputaciju 0. Super moda Jelca i admine je nula nekako zaobišla, ali to je sve samo stvar individualnog podešenja za pojedini tip člana foruma.
Vedran je offline
Staro 14.08.2006., 20:40   #34
IceFisherman
Magister Mundi sum!
IceFisherman's Avatar
Datum registracije: Jun 2003
Lokacija: Zagorje
Postovi: 2,335
Autor Vedran Pregled postova
e sad su mi napokon neke stvari jasnije
thnx
Sapphire radeon x1650PRO
2x512mb 433mhz Kingmax
AOC 17", LCD, LM760
Win XP PRO SP2 & SUSE 10.1
www.crazywarriors.com
IceFisherman je offline
Staro 29.08.2006., 11:59   #35
bego2
bego2's Avatar
Postovi: 2,724
Imam smo 10 bodova. šmrc
bego2 je offline
Staro 29.08.2006., 12:08   #36
atha
atha's Avatar
Postovi: 9,067
Jos si novi forumas, polako.
___________
Just atha
x
atha je offline
Staro 31.08.2006., 17:10   #37
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
I ja kao moderator imam 0 rep i 38 glasova, ko god glasovao...
Na šta točno moram stisnut da glasujem? na ove žuto/crvene kartone?
Nemam više lema!!!
LorD ClockaN je offline
Staro 31.08.2006., 17:18   #38
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Na ovu vagu(ikonica),desno od online statusa
Sam Fischer je offline
Staro 31.08.2006., 17:23   #39
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
Autor LorD ClockaN Pregled postova
.. mozes slobodno na crvenog ak nekoga ne volis .. : evil :
: cheers2
AOC 17", LCD, LM760
Staro 31.08.2006., 18:01   #40
atha
atha's Avatar
Postovi: 9,067
Lord - moderatori nemaju opciju glasanja.
Zuti i crveni su opcije koje pak samo mi imamo.
___________
Just atha
x
atha je offline
Staro 01.09.2006., 10:24   #41
LorD ClockaN
od LemilicE
Postovi: 4,712
Eto to sam tražio...
Nemam više lema!!!
Staro 01.09.2006., 10:29   #42
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
a ja nemam pojma odakle meni ovih 6
Crash009 je offline
Staro 24.09.2006., 15:34   #43
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
http://www.imput.net/preglednik.php?...e/gbD01168.jpg
Dali je ovo vezano tj. ima veze sa reputation ?
stuc je offline
Staro 02.10.2006., 21:15   #44
atha
atha's Avatar
Postovi: 9,067
Ima. Pise ti da si dobio, i ako je netko napisao koji je razlog za davanje reputacije.
Takodjer pise i link do posta radi kojega si dobio rep point.
___________
Just atha
x
atha je offline
Staro 02.10.2006., 23:59   #45
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
A ja hoću znat TKO mi je davao bodiće. Imam ih sto i nešto, i dva zelena kartona. Salate ko u priči
Ladybug je offline
Staro 03.10.2006., 00:08   #46
atha
atha's Avatar
Postovi: 9,067
Pisao je Horza, mislim da na ovoj temi ili popravci/debugiranje - samo Admin moze vidjeti tko je dijelio kome reputaciju.
___________
Just atha
x
atha je offline
Staro 03.10.2006., 00:20   #47
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
A jeste radoznali. SVe u svoje vrijeme...
tor je offline
Staro 03.10.2006., 00:27   #48
rabbit08
rabbit08's Avatar
Postovi: 103
a di se vide ti bodovi, ja ih nigdje ne vidim.... morat ću nabaviti cvike ili će mi netko pokazati (objasniti)....
rabbit08 je offline
Staro 03.10.2006., 00:31   #49
atha
atha's Avatar
Postovi: 9,067
Autor tor Pregled postova
Ovo je dobro, kao politicari.
___________
Just atha
x
atha je offline
Staro 03.10.2006., 00:32   #50
IceFisherman
Magister Mundi sum!
Lokacija: Zagorje
Postovi: 2,335
Autor rabbit08 Pregled postova
AOC 17", LCD, LM760
Staro 03.10.2006., 00:40   #51
atha
atha's Avatar
Postovi: 9,067
: lol2 :
No comment. Kazu da slika govori vise od 1000 rijeci,
ali ova govori i vise.
___________
Just atha
x
atha je offline
Staro 03.10.2006., 02:35   #52
trpi
Autor horza Pregled postova
samo admini mogu vidjeti tko je ostavio kakav reputation i koje je komentare tko ostavio
hm hm.... neznam dal je već neko posto ovak neš znam da je bila još jedna-dvije teme o ovom-nisam ih pratio, na ovu slučajno malo bacio oko dosadno mi: hello2 :
no da ne duljim ovdje govorite da samo admini mogu vidjeti komentare reputacija i useri se žale da žele vidjeti komentare.... kak ih ja mogu vidjeti: hello2 :
http://img473.imageshack.us/img473/1...board01va0.jpg
Staro 03.10.2006., 10:21   #53
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
ne komentare, nego tko ti je ostavio komentar, i od koga si dobio sve te bodiće.
Ladybug je offline
Staro 03.10.2006., 10:33   #54
Razer
Razer's Avatar
Postovi: 11,642
Za ovo mi ne treba moderator da bih znao tko je ovo napisao :
http://tinyurl.com/f555h
Razer je offline
Staro 03.10.2006., 18:01   #55
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
Autor atha Pregled postova
Ali gle sad fore.
Tu sam ja koliko sam shvatio dobio dva negativna boda u Links temi, jel tak ?
E sad, ne sjećam se da sam nekom spominjao majčicu ili ga poslao u rodni kraj te nešto slično... jednostavno se ne slažem u mišljenju sa nekim ljudima tamo i onda ispada da oni meni ili ja njima na osnovu toga što se ne slažemo u mišljenjima možemo djelit negativne bodove !?
Pa koja je onda svrha te reputacuje kad je podložna manipulaciji ?
Sad ću ja recimo sa još dva tri kompića ovdje uhvatit nekog na zub i djelit mu negativne bodove čim neš čovjek napiše.
Neznam... osobno mi stvarno ne smeta no nekako to nije baš najsretnije rješenje, to glasovanje bi možda trebalo prolatit neku vrst filtera ( moderatori ) ali ovako kako je sad, svašta je moguće u smislu zlorabe...
stuc je offline
Staro 03.10.2006., 18:15   #56
atha
atha's Avatar
Postovi: 9,067
Ja sam dobo negativne neki dan kada sam tipa upozorio zbog krsenja pravila na trznici. Bas sam gad.
___________
Just atha
x
atha je offline
Staro 03.10.2006., 18:36   #57
Postovi: 7,568
Ma pustite ih nek sam dijele negativne bodove. Nek se inate kolko god ih volja. Ako nemreju prihvatiti tuđe mišljenje, već odma udaraju po negativnoj reputaciji...nek se fino s nečim pokriju po glavi i nek budu stiha. Jer, za drugo ni nisu. Ko mala djeca u vrtiću...aha on/ona je meni tam (neovisno o temi) kenjal(a), sad bum ja njega/njegu i tak u začarani krug. Meni osobno ta reputacija, broj postova, mjesto prebivališta, datum registracije i sl....ne znači ama baš ništ. Pročitam postove od dotičnog forumaša i mam se vidi dal ima kaj pamtno za reći ili pak samo zayebava/provocira. Ko zna možda i meni sad neko za ovaj post da negativnu reputaciju...nek se vesele.
McG je offline
Staro 03.10.2006., 18:40   #58
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Autor Razer Pregled postova
loooooooool: lol2 :
rendula je offline
Staro 03.10.2006., 19:00   #59
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor trpi Pregled postova
Jedno je kada ti netko da lošu reputaciju, a drugo kada ti admin ili mod da žuti karton (ovo kaj ti je atha dao zbog spam advertising).
Žute i crvene kartone vidiš ko ti je dao. Reputaciju (dobru ili lošu) samo ako u komentaru ostavi svoj nick, u suprotnome, vidiš samo topic di si pobrao negativnu/pozitivnu reputaciju.
Vuco je offline
Staro 06.10.2006., 15:16   #60
atha
atha's Avatar
Postovi: 9,067
Evo cak sam i za ovaj post dobio negativne.
___________
Just atha
x
atha je offline
Zaključane teme
