Postovi: 2
Playstation 2 emulator
Čuo sam da mnogi traže ispravan ps2 emulator.Ne znam dali je itko imao psx 1.8 , ali taj ne koristi nikakve pluginove.Pa sam mislio da se i za ps2 napravi bez njih.No pustite sad to.Ja sam probao sve moguče ps2 emulatore i uopče ih nije teško namjestiti da rade.Naravno sporo.No mislio sam kada bismo mi svi skupa pokušali napraviti jedan na Visual Studio 2003.U tome oni rade PCSX2.Ja sam več nešto pokušao,nije lako,ali za prvi put sam več uspio izmjeniti sliku u "pcsx2.exe" aplikaciji kada se pali.Isto tako u grafičkom pluginu "ZeroGS KOSMOS 0.95.2 sse2.dll".Također sam malo opcije u njemu ispremještao.Nazvao sam ga "VERTIX".Nije ništa drugačiji ali ipak se več u 2 dana nešto uspjelo.Evo nekih komanda za pcsx2 koje sam vidio u Visual Studiu 2003: ID:1 for "OK" (1 button control) ID:2 for "Cancel" (2 button control) ID:65535 for "Window Size" (655352 group-box control) ID:1026 for "640x480" (1026 radio-button control) ID:1027 for "800x600" (1027 radio-button control) ID:1028 for "1024x768" (1028 radio-button control) ID:1029 for "1280x960" (1029 radio-button control) ID:65535 for "Antialising for higher quality (F6)" (655351 group-box control) ID:1022 for "NONE" (1022 radio-button control) ID:1023 for "2X" (1023 radio-button control) ID:1024 for "4X" (1024 radio-button control) ID:1030 for "Wireframe Rendering (Shift+F6)" (1030 check-box control) ID:1020 for "FFX Hack (F9)\n For fixing geometry in ffx" (1020 check-box control) ID:1021 for "Save Snapshots as BMPs (default is JPG)" (1021 check-box control) ID:1017 for "Interlace Enable (toggle with F5)\n there are 4 modes + interlace off" (1017 check-box control) ID:1018 for "Capture Avi (zerogs.avi) (F7)" (1018 check-box control) ID:1025 for "Bilinear Filtering (Shift+F5)\n Best quality is on, turn off for speed" (1025 check-box control) ID:1019 for "Fullscreen (Alt+Enter)\n to get out press Alt+Enter again" (1019 check-box control) ID:65535 for "Show Frames Per Second (Shift+F7)" (655353 text control) ID:1056 for "Configure..." (1056 button control) ID:1057 for "Test..." (1057 button control) ID:1058 for "About..." (1058 button control) Čak su mnoge i radile!No naravno,u pluginu nije ništa promjenjeno,no sada mi barem ne blokirava u Resident Evil-u Code Veronici na nekom dijelu kao prije. ![]() Ako bi mi itko mogao pomoči da napravimo ps2 emulator ili usavršimo pcsx2 , neka me kontaktira na moj MSN: marin.j@hotmail.com |
Lokacija: Zabok
Postovi: 331
Postovi: 2
Pa to je isti onaj sa www.pcsx2.net Radi totalno isto.7 fps,ne može do kraja prikazati reklame i nema zvuka svuda.Sve sam to ja več odavno probao.Još je to jako loše. ![]() Zadnje izmijenjeno od: S.T.A.R.S.. 20.08.2006. u 22:02. |
Postovi: 97
Evo 2009 je i kompovi bez problema vrte ove emulatore, naravno svi osim mog. Budući da mnogi koriste Pcsx2 zamolio bih neku dobru dušu koja se kuži da mi pomogne. Pročitao sam brdo stranih foruma i ne znam što krivo radim. Skinuo sam ovaj novi Pcsx2 sa službene stranice stavio biose. Imam na kompu iso file final fantasy X, sve napravio kako piše ali kad pokrenem dođe samo do glavnog izbornika od playstationa gdje se mogu namjestat jezik, sat itd... |
#5 | |
Lokacija: Gospić
Postovi: 71
probaj biose mjenjati, usa, japan i eu verzija, jedan ce dici igru mozda upali, ako ne, moze ovisiti o puno drugih opcija :S |
Postovi: 115
Sve poslje Nintendo 64-a je vrlo nezahvalno emulirat |
Postovi: 7,504
Evo da dignem temu, neznam da li je vijest (!) ili nije. Uglavnom prije dva dana nisam se mogao čuda načudit, dečko na PCu vozi FF11. I uglavnom da skratim emulator radi odlično, a grafika sa svim filtrima na HD3850 izgleda 2x bolje nego na PS2ici. Ipak sada nisam probao druge igre (iako ne igram FF11, samo sam htio probat), izgleda da je došlo vrijeme za GT4 na PCu, isto tako i meni ne prežaljeni Manhunt 2 |
Postovi: 7,504
Rent-a-maniac
Postovi: 756
evo ja sam nakon 2 god uspio upogonit gt4 na pc-u. napatio sam se ko majmun ![]() ne izgleda bog zna sto a to dugujem crappy hw-u u mom kompu, ali to nije ni bitno jer ovo je ionako jedan vid satisfakcije jer mi je frend (koji ima plejku i kod kojeg sam slinio nad gt4) tvrdio da je to nemoguce i da nece ni biti moguće. e pa in your face ![]() evo i malo ss-ova ![]() http://img2.imageshack.us/gal.php?g=...9092919454.png i ne, ne znam zasto je tako mracno ![]()
ubija me ova recesija...jedem pljesnivi sir, pijem neka stara vina i vozim auto bez krova... |
#12 | |
White Rabbit
Postovi: 4,951
Rent-a-maniac
Postovi: 756
moram pogledat jer sam toliko razlicitih postavki prosao...javim kad stignem
#14 | |
Postovi: 7,504
![]() A je mi drago baš radi GT4, nisam se nikome rugao ali mi je trebala ta igra jer sam je na Plejci dosta igrao. |
#16 |
Postovi: 7,504
#17 |
Rent-a-maniac
Postovi: 756
dosad nisam imao neta. tu su neki radovi oko mene. meni je u 60 fps a trka u nekih 49-60fps. mislio sam da ce se vidjet na ss iz frapsa al sam kasnije skuzio da sam tu opciju iskljucio. slika nije extra jer sam morao iskljucit aa i sve te gluposti. inace na onom ss je m5 na nord ![]() idem sad za drugi komp pa cu stavit postavke. edit: evo ovo je brzinski sklepano dakle prvo trebate pcsx2-r1888 verziju emulatora igra bi trebala biti (za gt4 govorim) NTSC, ne znam zasto ali eto pal nikako nije htio krenuti a i ako netko ima pal verziju neka proba 1. nakon istalacije prog treba podesiti ovako http://img225.imageshack.us/i/postavke.png/ jaci komp q proc ili neka jača grafa bi mogli izvuci sigurno bolje ali eto radim s onim sto imam ![]() 2. dalje je vazno ovo i ovo podesit kao da ss-ovima (razlog bas tim postavkama- nepoznat ![]() i to bi trebalo biti to u postavkama plugins i bios directory trebate postavit rucno. ako nemate biose odmah nakon instalacije treba ih skinut a mozete googlat po nazivu iz prvog koraka ili udarit tu u kratkim crtama to je to. ne mogu ici u sirinu jer kao sto sam rekao dosta je hirovit emulator i svakako se ponasa od konfe do konfe. eto nadam se da sam nekom bar malo pomogao a sad secer na kraju ![]() ![]() ![]() ![]() ![]() ![]() ![]()
ubija me ova recesija...jedem pljesnivi sir, pijem neka stara vina i vozim auto bez krova... Zadnje izmijenjeno od: Keyser Söze. 01.10.2009. u 00:10. Razlog: dodatak |
#18 | |
Lokacija: Vz - Zg
Postovi: 2,930
natrag na temu, dakle napokon (vec 2-3g ak na x2 240 radi tj, al nisam znao) je hw dovoljno jak za ps2 emulator, cool, ajde neki tutorial keyser stavi pa da i mi gotovani isprobamo kak to radi ![]()
#19 |
Registered Abuser
Lokacija: Velika Gorica \ ZG
Postovi: 747
tu je najbolji guide, tak sam ja osposobio http://forums.pcsx2.net/thread-5999.html igram normalno Smackdown VS Raw 2010 i Fight Night Round 3 ali na 1080p i sve max... treba jaka mađina za te emulatorčiče |
#21 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
#22 |
Lokacija: Kž\Vž
Postovi: 458
Prije mjesec dana nabavio emulator za PSX1, i stavio GT2 da se malo prisjetim starih dana kad sam visio na plejki, isss, koji filing, bio frend kod mene, pa smo igrali time trial naizmjence. Grafika losa naspram danasnjih igara, al zabava i gameplay odlicni, osmijeh od uha do uha kod obojice ![]() Nakon toga, nabavio sam PSX2 emulator, kako bi odigrao jos jednu igru iz serijala koji mi je jako drag a tog nastavka nema za PC: Metal Gear Solid 3. Igra radi ali samo do cca 22 FPS-a max, a u prosjeku nekih 13-15, pokrenuta na ovoj konfi: Athlon 64 X2 5000+ Black Edition (bez clockanja) GA-MA78G-DS3H Gigabyte 1GB DDR2 @533 ![]() ATI Radeon HD3200 (integrirana) ![]() ![]() OS:W7 Sad sam nadogradio ram (4GB DDR2 @ Testiranje: konfa sve isto ko i prije samo sada vise RAM-a: Tu i tamo skoci do 25FPS-a ali i u prosjeku nekih 15-17 FPS-a Planiram nabaviti u skoro vrijeme 4850 ili GTS 260 pa se nadam da ce se poboljsat performanse tj. nadam se da ne ovisi samo o procesoru brzina izvodenja. |
#23 |
Registered Abuser
Postovi: 747
#24 |
Lokacija: Sveta Nedelja
Postovi: 2,938
Guglam i nikako da zguglam - postoji li nekakva verzija Super Maria za PS2? I poželjno da na njoj radi Save opcija. Pregledao Algoritam, CroVortex itd - ne nalazim. Zanimaju me samo originali. Možda netko od vas ima za prodati?
#25 |
Mario je Nintendo ekskluziva! |
#27 |
Ima! Guglaj za emulatore i nađi. |
#29 |
Lokacija: Beertopia
Postovi: 2,013
Ovo ću definitivno probat u kombinaciji sa FF XII ![]()
54' / 74' / 90' / 2014
I'm only here to see how the story unfolds. Any self-respecting leading man would do the same. |
#30 |
Datum registracije: Mar 2012
Postovi: 151
Da ne otvaram novu temu, našao sam hrpu starijih i novijih igrica za plejku 2, a već sam koristio emulator za plej 1 na staroj konfi. Jel mi komp može pokrenut taj PCSX2? ![]() |
