Junior Member
Datum registracije: May 2003
Postovi: 3,205
NI jedan
__________________ |
pwner sa stilom
Lokacija: soba
Postovi: 200
koji odgovor... : suicide meni se osobno svida ovaj DVD±RW SAMSUNG SH-W163A, 16x, crni, Dual layer ± recording, S-ATA, bulk 283 kune u Links-u:clap: http://img211.imageshack.us/img211/3...2112083ci5.jpg
mind of a psychopath killer, blood spiller, mentality much iller |
You'll Never Walk Alone
Postovi: 1,287
LG uzmi ako bas biras izmedju te dvije,al na tvom mjestu bi razmilsio i o BENQ przi,i ova gore samsung nije losa...
Member of PCE 100+kg demolition squad Zadnje izmijenjeno od: undo. 07.08.2006. u 21:35. |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Onoga koji ima vise garancije imam pionira i opet bi ga uzeo da nadjem ga negdje sa 2god garancije ali nisam nasao i uzeo sam neca i zadovoljan sam. mrvicu je sporiji od pijonira ![]()
Junior Member
Postovi: 3,205
Da mi je znat u cemu je sporiji
#8 | |
Lokacija: Solin
Postovi: 1,753
![]() BTW nista od navedenog ne bi zemija! ![]() |
#10 | |
Junior Member
Postovi: 3,205
![]() jonyb.. Samo za tebe copy paste sa review-a cdrinfa u vezi čitanja.malo sam ti podebljao bitno. ![]() "As already mentioned, the drive has a great error correction mechanism, reading over all inserted artfificially defective media, at max speed. CD error correction could've been better, as the 4571 reported average results in comparison to other market drives. Especially the 726 test media reported totaly difference results from what one would expect of a latest release drive. Burning quality was a major issue for the review drive as while it did quite well with write once media and reported average results with the Re-Writable media, it did not achieve good results with the DL media. Overall the drive's writing performance is much dependent from the media inserted, indicating a somewhat limited media list. A firmware upgrade regarding the DL media issues would be most welcomed. What of the "features" that most drives offer, one would wonder... In this field, the 4571A is not strong enough. The 90/99mins Audio discs cannot be read by the drive and cannot perform overburn with either CD or DVD media. Bitsetting feature is present though for all three +R media formats. An extra feature for the users who enjoy media customization is the LabelFlash feature which enables the user to label his burned media using the drive itself than some printable labels.
__________________ Zadnje izmijenjeno od: BrunoZG. 09.08.2006. u 01:28. |
#11 | |
Datum registracije: Apr 2004
Postovi: 887
nažalost još nisam imal prilike isprobati 4571A, pa da ga usporedim sa pionirčekom 111D... tak da nisam kompetentan suditi o ovom modelu. ali sumnjam da ima nekog velikog odmaka u odnosu na prijašnje modele. |
#13 | |
Lokacija: Split Hrvatska
Postovi: 936
Postovi: 4,190
LG, ne trebas uopce dvojit... |
Lokacija: Republica Crikvenica
Postovi: 1,194
kupio sam tri 111D pionirka i sva tri su katostrofalni u čitanju DVD-a..svi imaju po tri "slapa" i nikako ne mogiu da drže konstantno preko 6× jednom rječju...rade , ali ne dobro Samsung neki novi ATA...katastrofalno čitanje, bolje reći da ni neče da čita..., nakon tjedan dana otišao u pola cjene samo da ga se rješim... uz LiteON-ovoga staroga danas došla još dva sa LS-om, čitanje kontinuirano do 12× bez padova !!!, i to na oba.... LG nisam odavno koristio kao pržu... moj predlog...LiteOn...cjena najniža , čitanje odlično...meni je to važno jer je jedini uređaj ! NEC...zbog prošlih vremena ne želim čuti o njima...izbjegavam računala s time ! (neki to zovu prža...bolje bi nazvao...krematorij za diskove) |
#16 | |
Junior Member
Postovi: 3,205
KOd BENQ-A 1650 I nec 4550/4570..cITANJE BEZ PADOVA 16X Citiraj:
#17 |
Postovi: 33,959
Kao što vidiš, imam 2 Pionira i sasvim sam zadovoljan njima. Ne mogu raditi overburn cd-a ni dvd-a, ali mi to ni ne treba previše. Sve pročitaju i sve sprže i to dobro, za razliku od nekih NEC-ovih prža čije spržene medije ne bi pročitao ni Bog Isus.
#18 |
Junior Member
Postovi: 3,205
przeno sa NEC 2510, citano sa BENQ 1650 ![]() Nero CD-DVD Speed: Disc Info Basic Information Disc type: : DVD-R Book Type : DVD-R Manufacturer: : Verbatim MID : MCC 02RG20 Write speeds: : 2.4 X - 4 X - 8 X Blank Capacity : 4.38 GB : 4489 MB : 4707319808 bytes Extended Information Layers : 1 Usage : General Copyright protection : n/a Recorder information : recorded with _NEC DVD_RW ND-2510A Disc Status : Closed Raw Data Pre-recorded Information in Lead-in (0Eh) 0000 - 01 40 C1 FD 9E D8 52 00 02 85 0D 10 88 9A 80 00 - .@....R......... 0010 - 03 4D 43 43 20 30 32 00 04 52 47 32 30 20 20 00 - .MCC.02..RG20... 0020 - 05 88 80 00 00 00 02 00 D4 75 05 00 79 86 41 77 - .........u..y.Aw 0030 - 04 00 00 00 CC 75 05 00 73 C7 D4 77 00 80 00 00 - .....u..s..w.... 0040 - 2B E9 D4 77 99 37 41 77 00 80 00 00 56 04 01 00 - +..w.7Aw....V... 0050 - FC FF FF FF 00 00 00 00 18 76 05 00 00 00 15 00 - .........v...... 0060 - 32 07 91 7C 0B 00 00 00 98 08 15 00 00 00 15 00 - 2..|............
__________________ Zadnje izmijenjeno od: BrunoZG. 10.08.2006. u 18:13. |
#20 |
Postovi: 1,194
kaj ne govorimo o novim uređajima, a taj NEC je malo u godinama...(uz to to je odvojeni ROM i prža kaj ne?) imao sam 106D pioneerka koji je čitao i pisao bez ikakvih padova i nije zaj.ebao 10 medija u četiri godine,...ali to nije više uređaj za 2006 godinu... vrjeme je novac... nitko nije rekao da neće očitati, ali ako DVDRW čita medije kao 111D onda se prebacivanje podataka nekada jakooooo otegne što mene i moj način razmišljanja jakooooooo nervira i kao takav uređaj brzo završava karijeru...i kada se to ponovi tri puta zaredom u mjesec dana , za mene je definitivno...KRAJ za toga proizvođača...znači da delaju gluposti ! |
#21 |
Junior Member
Postovi: 3,205
Nije nec 2510 odvojen0 nista , to je stara przilica i citac u jednom. Namjerno stavio medij koji je sprzen sa NEC-om a koji "ni bog ne bi procito "koji je citan maksimalno bez padova sa 16x brzinom s novom BENQ przilicom. Naravno da isto tako izgleda i isprzeno sa BENQ DW 1650 i citano isto sa njim.
__________________ Zadnje izmijenjeno od: BrunoZG. 11.08.2006. u 13:29. |
#22 |
Lost soul still wondering
Lokacija: Aiur
Postovi: 474
Evo samo da podjelim svoje iskustvo. Vlasnik sam Lg 4167B modela. Onak snimač nije bio loš ali mi je nekad znal nasnimati podatke na dvd da ih pola više nisam mogel skopirati, većinom se to događalo na rw-ima. Nedavno sam stavil najnoviju verziju firmwarea i sve radi kao podmazano. Svi problemi su nestali ![]()
Da nije nas bile za grabu bi spal ![]() |
#23 |
Postovi: 130
ja imam pržu LG GSA-H20L LightScribe i nema kaj nema...sve radi...preporučam |
#24 |
Lokacija: ns
Postovi: 35
sutra kupujem novi dvd writer.... u ponudi su iskljucivo nec 4571 , Pioneer 111 i lg ( noviji model mislim)- najjeftiniji od svih sta da uzmem? nec i Pioneer su 38 evra |
#25 |
Postovi: 1,287
sve tri su ok prze,sta god uzmes - dobro si uzeo,usput podigao si temu skoro 2 mjeseca staru... ![]()
Member of PCE 100+kg demolition squad |
#29 |
Datum registracije: Sep 2004
Postovi: 832
![]() Ja bi na tvom mistu uzea Lg. Ja imam Lg h20lrbb + LightScribe i odlican je. Na njemu sam jedno 30-ak komada dvd-a raznih proizvodjaca sprzia i ama bas svaki je 100% ispravan, tj. dobro sprzen. Moj ti je savjet Lg! :clap: |
