Staro 27.06.2003., 14:58   #1
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Nvidia konačno poboljšava odnos prema kupcima...
...nema više svakakvih netestiranih itd drivera...
"Alot has been going on behind the scenes recently guys with Nvidia regarding Omegas drivers and it looks like Omega might be forced to stop making them. This is due to Nvidia hard handed tactics and not wanting anyone to alter or touch their driver code in any way. Omega has even had to remove Nvidia logos from his site or legal action will be taken. This could possibly if taken further close these sites, so we really have no option.
Im sorry for the bad news, but unfortunately it looks like Nvidia Omega drivers will no longer be developed.
Staro 27.06.2003., 18:34   #2
miato
(°_°)
miato's Avatar
Postovi: 3,249
Ajoooooj. Ne vidim zasto nebi dali nekom trecem, neovisnom "partneru" (omega) da on proba napraviti kvalitetnije drivere... Ili se neceg boje :confused:
A sto je s Omega driverima za ATI, jesu li bolji od Catalysta 3.5 (ili-kojji-vec)
Netko testiro?
Staro 27.06.2003., 22:00   #3
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
omega driveri nisu s promjenjenim codom ali je zapravo rijec o drugacijim inf fileovima....a tip ih nudi kao drivere i cak i tamo gdje pise da nije mjenjao kod neobjasnjava bas stvari....mala greska u recenici ali velike korporacije to nedopustaju tek tako, narocito koristenje njihovog logoa
Staro 28.06.2003., 00:47   #4
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
a koja je razlika između DETONATORA i tih OMEGA drivera???
ili je to isti qrac a drugo pakovanje....?????
koji su bolji...kvalitetniji???
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 28.06.2003., 11:34   #5
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
ma rijec je o istim driverima jedino sto ti omega daje da vec pri instalaciji odredis oce li bi nastimani na brzinu ili kvalitet....rijec je o istim postavkama koje mozes sam rucno promijeniti u driverima (i nekim do koji se moze doci samo s tweakerima)
Staro 29.06.2003., 00:28   #6
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
znači ,zapravo, niš posebno...ionak koristim RivaTuner za poštelavanje...
Staro 29.06.2003., 11:24   #7
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
pa zapravo da, nista posebno....ja ionako nevolim ta univerzalna rijesenja jer u recimo rivatuneru nije svaka postavka koja znaci boost i kod mene tog djelovanja vec zna biti i malo u nazad ili pogorsa sliku a nedaje dovoljno znacajan rezultat u brzini....
zato sam odjebao omegu i skidam samo normalne detonatore
