Staro 03.08.2006., 22:37   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Sapphire x1800gto2
Sapphire Radeon X1800 GTO2 comes with fully-fledged Radeon X1800 XL processor clocked at 500MHz with 16 pixel shader engines, 8 vertex shader engines as well as 16 texture units. The graphics board is equipped with 512MB of 1000MHz GDDR3 memory as well as video input/video output capability. The graphics card is currently sold in Japan, according to Akiba PC Hotline, however, there are reports that the products can also be acquired in Eastern Europe.
ATI Radeon X1800 GTO has 12 pixel shader processors and 8 vertex processors, while the Radeon X1800 XL features 16 pixel shader units and 8 vertex shader units. Both are equipped with 256MB of GDDR3 and are clocked at 500MHz/1000MHz core/memory. Considering the specs, it is clear that the Radeon X1800 GTO2 is more powerful than the X1800 GTO or X1800 XL models.
http://www.xbitlabs.com/news/video/d...802233109.html
iako kažu da ih ima samo u Japanu, Newegg ih također ima u ponudi
http://www.newegg.com/Product/Produc...82E16814102027
Mailman je offline   Reply With Quote
Staro 03.08.2006., 22:40   #2
Router
Hejter
Postovi: 6,520
cijena kod nas bu oko 2000kn
zvuci jako dobro , zato valjda i x1800xl nema po ducanima
Router je online   Reply With Quote
Staro 03.08.2006., 23:15   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor Router
Pa, ako će biti dva soma-za otprilike istu cijenu nabaviš novu 1800XT 256 MB.
Koliko je kod nas?
2100-2200?
Staro 03.08.2006., 23:20   #4
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
i 7900gt, koja iako ima 256meme, ipak bi mi bila bolji izor uz X1800XT ,od GT02
baterija je offline   Reply With Quote
Staro 03.08.2006., 23:44   #5
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
jel onda sad već x1800xl EOL?
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 03.08.2006., 23:50   #6
Matijac
Matijac's Avatar
Postovi: 839
E a koja je grafička bolja, GeForce 7900 GTX ili ati radeon X1900XT?
Staro 04.08.2006., 01:24   #7
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Matijac
GeForce3 Ti500
Staro 04.08.2006., 01:51   #8
Postovi: 7,568
Autor Matijac
Ako imaš cca. 3.500 kn i nije ti problem dati tolke pare za grafičku onda si kupi GTX-a. S druge strane X1900XT imaš već za cca. 2.900 kn po dućanima, a po pitanju performansi ne zaostaje baš tak jako naspram 7900GTX. Još ako si modderski nastrojen, pa te primi i flashaš (ako se da) XT-a u XTX-a, niko sretniji od tebe. S treće pak strane u "igru" ulazi cca. 2.700 kn procijenjena (od strane IT dućana, diljem Lijepe Naše) 7900GT Bliss 512MB i eto ti veselja. Dvije kartice performanasma dosta blizu 7900GTX-a, a cijenom puno prihvatljivije...
Ispričavam se na OT-u.: sweating
EDIT: Back On Topic...X1800GTO² vs. X1900GT i 7900GT
Zadnje izmijenjeno od: McG. 04.08.2006. u 16:40.
Staro 04.08.2006., 19:46   #9
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Eto, McG je sve rekao
Staro 04.08.2006., 20:17   #10
Router
Hejter
Postovi: 6,520
ja bi radije na x1900gt ili 7900gt jer manje se griju koliko ja kuzim , a i broj ovih
kineskih jedinica je nesto povoljniji , ali vidjet cemo kakva ce cijena biti , jer ako se ovi u atiju odreknu kojeg eura i priblize 7600gt po cijeni , onda nebude puno dvojbi
Staro 04.08.2006., 23:32   #11
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Kad bi taj GTO2 bio max. 1800kn, imao bi publiku...
7900GT ima vec za 2200kn a kartica se zbilja malo grije i malo trosi (oko 50W).
Staro 06.08.2006., 09:44   #12
Router
Hejter
Postovi: 6,520
50w ? pa koliko onda trosi 7600gt ?
Staro 06.08.2006., 11:17   #13
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor Router
Svega 35W!!! 6600GT trosi kao i 7900GT, 50W
Staro 06.08.2006., 11:52   #14
Router
Hejter
Postovi: 6,520
hvala , to nisam znao . dakle ak uzmem 7900gt napajanje koje mi je drzalo 6600gt bude i nju , sjuper .
to je zbog proizvodnog procesa , odnosno smanjenja istog , jer tako ?
