Postovi: 1,711
Welcome screen
Molim vas za pomoć jel ću popi.... Naime kad palim komp,sve se brzo digne osim onog welcome screena,njega gledam jedno 10-ak sekundi,onda se cuje onaj zvuk,i onda jos cekam 2 sekunde i tek mi onda ude u win. Kako to rijesiti,probao sam format i radilo je super dok nisam instalirao ZA,otad me pocelo zahebavat. konfa je A643000+ s754 MSI K8Neo nforce3 1024MB RAM R9800Pro Maxtor 120GB Sata WinXP Pro probao sam i deinstalirati ZA nece,probao optimizirati sa bootvisom,nece,napominjem da su svi servisi koji usm i nepotrebni ugaseni jel cim on makne taj welcom screen odma mi je za sekundu spreman za rad help pliz ![]()
http://eu.prepsafe.com |
Postovi: 1,711
any idea nešto bump biloka?!
Spermich Termich
Lokacija: Zaprešić
Postovi: 885
Disabling the Welcome Screen On computers running Windows XP Professional that are not members of a domain, the default is for users to see a Welcome screen that includes the names of all users with accounts on the computer. The user’s password prompt is revealed when the user clicks his or her name. Because the names of all user accounts are made visible on this Welcome screen, this behavior is less secure than using the Ctrl+Alt+Del user interface. To disable the Welcome screen and require CTRL+ALT+DEL to be used for logons 1. In Control Panel, click User Accounts. 2. Click Change the way users log on or off. 3. Clear the Use the Welcome screen check box. This also disables the Use Fast User Switching option. Users will now log on using the Ctrl+Alt+Del user interface. više:http://www.microsoft.com/technet/pro...c16621675.mspx prošvrljaj malo tamo
