#31 |
the luda ribetna
Postovi: 3,952
Ventex ti ga ima Kvark hg spot tak bar meni pokazuje...u ve milu mos jednu komponentu izvana dofurat |
#32 |
Postovi: 31
Moze neka slicna konfa na brzinu iz linksa buduci da mi dostave u utorak ako narucim danas ... |
#33 |
the luda ribetna
Postovi: 3,952
DVD±RW PIONEER DVR-111D, 16x, crni, Dual layer ± recording, bulk i Kućište COOLERMASTER Stacker rev 2.0, crno, STC-T01-UWK, BIG, ATX / BTX nadogradivo, bez PS Napajanje TAGAN 430W 2Force, Super Silent, TG430-U22, PCI-E, S-ATA, ATX2 v2.0 Floppy drive 3.5'', 1,44MB, crni DVD ROM BENQ 16x 50x, DVP-1650V, crni, bulk VGA PCI-E Point of View, GeForce PCX 7600GS, 256MB DDR3, DVI-I, TV-Out CPU INTEL Pentium D 805 2660 MHz BOX, socket 775, 2 Mb c., FSB 533MHz, 64 bit, DualCore Cooler Thermaltake BIG Typhon, socket A/754/939/478/775 RAM PC-4200, 2048MB, DDR2, OCZ Value, KIT, DDR 533 MHz, 2 x 1024MB HDD 250.0 GB SEAGATE, 7200.9, Serial ATA II, NCQ, 8MB cache, 7200 okr/min MBO DFI i975X/G INFINITY, Intel i975X, DDR2, zvuk, S-ATA, FW, G-LAN, PCI-E, s. 775 ukupno: 8.390,18 KN 7.854,63 KN ovaj konfa podrzava conroe... ![]() ![]() |
#34 |
Postovi: 31
Kompa meni u 8.500kn mora uc i monitor ... tesko da sa ovom konfom moze ![]() |
#35 |
Lokacija: ̣
Postovi: 1,019
Case-Centurion 5 blue Prza-SAMSUNG SH-W163A Ram-2x1gb kingmax ddr2 667 to napravi i kupi mon. mozes izbacit dvd rom manji hard (nemoj) ma dodaj malo i neces pozaliti jeftinija 7600gs mozda,jer ova ionako nema ddr3 |
#36 |
Postovi: 2,458
CPU: INTEL Pentium D 930 3000 MHz BOX, socket 775, 2 x 2 Mb c., FSB 800MHz, 64 bit, DualCore 1383 Kn MBO: ABIT NI8 SLI-GR, nForce4 SLI IE, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775 770 Kn RAM: PC-5300, 2x1024MB, DDR2, KINGMAX, DDR2 667 MHz 1098 Kn HDD: 160.0 GB SEAGATE, 7200.9, Serial ATA II, 8MB cache, 7200 okr/min 464 Kn DVD±RW: NEC ND-3550A, 16x, Dual layer ± recording, bulk 276 Kn DVD ROM: LG 16x 52x, GDR-8164B, srebrni, bulk 137 Kn Napajanje FORTRON 350W, BlueStorm, Super Silent, 12cm vent., ATX2 ver 2.0 375 Kn (Chiefteke trenutno nemaju ![]() VGA: PCI-E XFX, GeForce PCX 7600GS XT, 256MB DDR2, Dual DVI, TV-Out 1233 Kn Kućište: THERMALTAKE Swing VB6000BNS, MIDI, crno, bez PS 467 Kn Monitor: 17'' LCD Samsung SM 740B, srebrno crni, 8ms, DVI, 300cd/m2, 600:1, pivot 1899 Kn Tipkovnica: Logitech Deluxe, crna 61 Kn Miš: Logitech G1 194 Kn Uk:8375Kn |
#37 | |
Postovi: 31
Molim vas da me ispravite hitno tako da im mogu poslat neke ispravke ako treba, jer vec je narudzba poslana pred par sati ... |
#38 |
Postovi: 31
Uzeo sam shitex napajanje kuciste i jeftiniji monitor, tako da mogu uzet tu corone plocu i uzeo sam CPU i sve je stalo u cijenu ... Mis/Tipkovnica nemoraju ic u tu cijenu to lako nabavim ako zafali para |
#39 | |
Postovi: 2,458
#40 | |
Postovi: 31
Sta je takvo sranje monitor, onda cu njega zamijenit je mogu editirat narudzbu u linksu ili da ih zovem/saljem mail ? |
#41 | |
Postovi: 2,458
#42 |
Lokacija: ̣
Postovi: 1,019
mail.. slazem se sa ETem uzmi P5LD2-SE asus i 930D ![]() ili 805D i 7600gt i bolji mon |
#43 | |
Postovi: 2,458
#44 |
Postovi: 31
Mozda da ipak ostavim plocu, ipak mora bit kvalitetna kad kosta toliko ... Kupim si napajanje od druge place, i samo zamijenim monitor ? Zanima me je ta ploca kvalitetnija od ovih sto ne podrzavaju corone ili je cijena samo zbog podrske za corone ? |
#45 |
Postovi: 31
Evo uzeo sam tu plocu i samsung monitor, i sve sljaka ![]() Hvala svima na pomoci Btw. Je dosta 4.500 markova u 3D marku 05, za ovakvu konfu :confused: |
#46 |
music freak
Lokacija: Sibenik
Postovi: 3,315
...sto nema links u rijeci ?
#47 |
Postovi: 31
Rekli su mi da se uskoro otvara, a mozda se vec i otvorio ![]() |
#48 |
Postovi: 2,458
Da li si overclockirao 7600GS? To je kartica sa ddr3 memorijom dobar clocker, a na stocku su perfomanse takve kakve jesu u 3d marku...dakle nesto bolje od 6600GT... Tek kad ju ocas posteno moze se pribliziti 7600gt... |
#49 | |
Postovi: 31
#50 |
Postovi: 2,458
Pa mislio sam da si uzeo kao sto si rekao: -Point of View, GeForce PCX 7600GS, 256MB DDR3 No u svakom slucaju tko hebe 3D MArk to je samo sinteticki benchmark bitno je kakve su perfomanse u igrama... |
#51 | |
Postovi: 31
#52 | |
Postovi: 33,973
