Staro 14.07.2006., 12:22   #1
RiSbO
RiSbO's Avatar
Postovi: 254
Računalo kofer
I kako vam se čini?
Nisam ja radio vec frend..
više na http://www.squid-technology.com/projects.html
RiSbO je offline   Reply With Quote
Staro 14.07.2006., 12:29   #2
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
daj pitaj frenda gdje je uzeo gumb za paljenje...***************eni je
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 14.07.2006., 12:30   #3
PClignja
Lokacija: zpš
Postovi: 70
frend se javlja,, inace uspio ugurat u nutra velku maticnu, 3 diska dvd rom
17 incha monitor bezcnu tastaturu i misa klasicno napajanje,, podosta ventilatora jedno 8 jer se radi skucenog prostora grije ,,, ,, jedina stvar koju zalim kaj nije stala radi blesavog adaptera za monitr koji sam previdio je kabel zanapajanje ,, mozda i njega uspijem ugurat u nekoj shrinkanoj varijanti
tezina prava sitnica 15 kg ..
PClignja je offline   Reply With Quote
Staro 14.07.2006., 12:30   #4
RiSbO
RiSbO's Avatar
Postovi: 254
Autor micek_kc
Čipoteka mislim
Staro 14.07.2006., 12:32   #5
RiSbO
RiSbO's Avatar
Postovi: 254
Autor PClignja
Taman da ga vicemo po krovovima za stumbat s njim : quake2 :
Staro 14.07.2006., 12:32   #6
PClignja
Lokacija: zpš
Postovi: 70
gumb za paljene je zet u cipoteci ali kao sto se vidi radio sam adapter od alumijija da mi stane u ovo kuciste za gumb koje se podize ,, inace ima u crvenoj zutoj i zelenoj boji,, naravno ledica je nutra i kul svjetli
Staro 14.07.2006., 12:37   #7
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
@pclignja: ti si sve ono radio sta je na onoj stracici? ovaj mod mi je zestok,ali mi se nekako najvise svidja tastatura. bas je odlicna.
kiki89 je offline   Reply With Quote
Staro 14.07.2006., 12:43   #8
PClignja
Lokacija: zpš
Postovi: 70
Autor kiki89
da ja sam sve radiio,, kaj je na webu ima jos jedno 10 20 gelrija ali si moram hosting rjesiti jer mi nema dost prostora da stavim ,,
tastatura je super i to
ali si ju nemoj kupiti zato jer je domet nje i misa onako 1 metar i za igranje nije i to meni ona samo sluzi kad nekam idem jer mi fino stane u kofer i sve mi je onak kulturnije za baratat kada sam negdi,,
Staro 14.07.2006., 12:44   #9
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
mislio sam na ovu tastaturu,pre odlicna je
http://www.squid-technology.com/keyboard.html
Staro 14.07.2006., 12:51   #10
PClignja
Lokacija: zpš
Postovi: 70
Autor kiki89
aaha
da to sam ja radio ,, revers inženjering sam napravio na jednoj drugoj obicnoj tipkovnici i lemio zice na elektroniku jedno 2 put po 8 h mi treba za to zalemiti,, imaju neke i backlite,,
koriste ju ljudi koji maju problema s kretanjem pa da ne stisnu 2 tipke odjednom ili koji ne vide bas mala slova i tak u svakom slucaju sljaka ali nemres bas brzo pisati,,,jer su tipke uvučene 1 mm unutar tastarure
Staro 14.07.2006., 12:53   #11
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
jel se to moze kupiti? meni se jako svidja.
Staro 14.07.2006., 12:58   #12
PClignja
Lokacija: zpš
Postovi: 70
Autor kiki89
moze se i jedno i drugo ,,
ali tipkovnica je skupa 2000 kn kosta ,
jer su tu onak glodanja na cncu printanja rezanja brušenja lemljenja itd,,
da ne velim dasamo swichevi kostaju 500 kn
a sto se tice kufera i on se moze kupiti napraviti novi i tak.. to se dogovaramo,, naravno jos gomilu toga mogu po mjeri napravitii,,, isprojektirat
,, vesli me
Staro 14.07.2006., 12:59   #13
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
Autor PClignja
vise mi se ne svidja: lol2 :
Staro 14.07.2006., 13:02   #14
atha
atha's Avatar
Postovi: 9,067
Pohvala za ideje, trud i izgled!
___________
Just atha
x
Staro 14.07.2006., 13:38   #15
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
nemoj srat, da prostis na izrazu! imam istu tipkovnicu i misa doma, to su labtec marke i komplet dode oko 150kn, bar sam ja tolko platio. slikat cu ako neko inzistira.
Spoiler alert!
Staro 14.07.2006., 13:45   #16
RiSbO
RiSbO's Avatar
Postovi: 254
Autor De5tr0yer
on misli na ovo http://www.squid-technology.com/keyboard.html
mučni malo glavom prije....i čitaj sa razumjevanjem
Staro 14.07.2006., 13:49   #17
PClignja
Lokacija: zpš
Postovi: 70
Autor De5tr0yer
dakle evo ti link
pa stavi tu sliku
uz neku s linka pa usporedi ,, malo si pobrko loncice,, isto ko i ja,
: hitthewa,
kada mi je prvobitno pitanje postavljeno dakle nije se pricalo od labtek tastaturi nego o onoj s sajta,,
odnosno prvo sam komentirao labtek a posle onu s sajta . btw labteka sam platio 145 kn i bolje sam proso od tebe
Staro 14.07.2006., 14:01   #18
atha
atha's Avatar
Postovi: 9,067
Autor De5tr0yer
Malo lakse sa tim izrazima,
i ubuduce citaj sa razumijevanjem prije nego nesto ovakvo napises.
___________
Just atha
x
Staro 14.07.2006., 15:08   #19
amd-freak
amd-freak's Avatar
Postovi: 214
koliko košta taj power button?
amd-freak je offline   Reply With Quote
Staro 14.07.2006., 15:22   #20
PClignja
Lokacija: zpš
Postovi: 70
Autor amd-freak
mislim da je u chipoteci oko 10 kn a onaj poklopac kaj se dize 15 kn
Staro 14.07.2006., 20:42   #21
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,313
a pod kojom kategorijo +m je to na chipoteci...ima ih milion...ne mogu naći te kewl dugmiće
Staro 14.07.2006., 21:16   #22
Mar
Suit up!
Mar's Avatar
Postovi: 5,962
Svaka cast za mod , podsjeća me na jednu sliku koju je netko posla na Pc Play (ili slicno, nisam siguran) prije jedno 2-3 godine.
Mislim da je bilo mesopust.com ?
- Barney Stinson
Mar je online   Reply With Quote
Staro 14.07.2006., 21:16   #23
PClignja
Lokacija: zpš
Postovi: 70
Autor vex
hebali vas dugmici : Machineg
mislim pod tasteri ali nema slike
Staro 14.07.2006., 22:20   #24
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
Autor atha
isprika, moj bed
Spoiler alert!
Staro 14.07.2006., 22:45   #25
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Čovječe botun za paljenje kao za lansiranje raketa
iveumag je offline   Reply With Quote
Staro 22.07.2006., 21:25   #26
speedy-3
speedy-3's Avatar
Postovi: 458
strasni su ti modovi,,,,,,, ovaj kofer je bas full praktican za LAN party
evo ti linkic za hosting www.hrhosting.net trenutno traje zakon akcija platis 210MB dobijes 420 svaki paket koji narucis ide duplo MB
speedy-3 je offline   Reply With Quote
Staro 24.07.2006., 20:38   #27
PClignja
Lokacija: zpš
Postovi: 70
Autor speedy-3
heh da sada moram otici na neki lanparti ,,,
a sto se tice prostora bas mi treba jer imam onak jos podosta projekata koje bi htio staviti a nema prostora
Staro 24.07.2006., 20:39   #28
PClignja
Lokacija: zpš
Postovi: 70
btw ako neko hoce,, imam u planu novo nes raditi ,, pa neka plati djelove koliko sam utukel i nosi
Staro 24.07.2006., 20:49   #29
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
Autor atha
podpisujem
fakat lijepo...makar bi rade vidio par slika iznutra
blup
mc_fish je offline   Reply With Quote
Staro 24.07.2006., 21:39   #30
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Iako nisam neki aktivni igrač po pitanju modanja i sličnih zahvata ovo je jedna od_najboljih ideja i ostvarenja, po mom ukusu i mišljenju naravno.
Efektno, ukusno i nadasve praktično - spoj do jaja. Svaka čast, *ebo laptop, ovo se zove mod. Mrak...
Par pitanja...
Koje su točno komponente untra?
Kako si riješio držače za matičnu, diskove i optički pogon? Iskoristio nešto iz nekog kućišta, ili sam pilao?
