Staro 01.07.2006., 14:11   #211
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Autor Panzer
Ja sam imao VF700 Al-Cu na svojoj 6800LE, nisam imao jezice na memoriji, i nije prelazila 58° load... oko 50-52°C idle...
Razlika izmedu Cu i Al-Cu nije velika, nekolko °C mozda...
Ja si mozda sad piknem VF900, ali mi je Faceless rekao da dosta savine grafu... Kad san imao VF700 montiran, grafa uopce nije bila savinuta...
vf900cu - 185g
vf700alcu - 180g
vf700cu - 270g
@crash - odlično, meni je sad u idleu minimalno 47, a u loadu 80, grafa na default (club3d)
btw zna ko šta znači Core VID u Hardware Monitoringu Riva Tunera?
Staro 01.07.2006., 14:14   #212
Razer
Razer's Avatar
Postovi: 11,642
Autor Emissary
vf900cu - 185g
vf700alcu - 180g
vf700cu - 270g
Aj stavi screeenshot temp monitoringa iz rive...mislim da je to voltaža jezgre...MISLIM
Staro 01.07.2006., 14:26   #213
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Sumnjam
Staro 01.07.2006., 14:30   #214
Razer
Razer's Avatar
Postovi: 11,642
Autor Emissary
Sumnjam
LOL...mislim da i ja sumnjam...bilo bi veselo da je to voltaža jezgre
Staro 01.07.2006., 14:36   #215
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Ne znaš je li veselije kad je 0 ili kad je 4
A vidi šta documentation kaže:
Q: Why does RivaTuner monitor abnormally
low 1.0V core voltage on my GeForce 6800? Can you fix this bug?
A: You should look at "Core VID"
graph's X-axis dimension carefully. I bet that if you'll do it, you will not
find "Volts" there. Quite opposite, you'll see that the value displayed
on this graph is non-dimensional. The graph you are looking at is a raw untransformed
VID data. Refer to the questions discussed above to understand what is VID and
to find instructions on enabling RivaTuner's voltage interpretation function,
allowing you to see target voltages on the graph instead of raw VID data.
E sad, ajmo elektrotehničari
Staro 01.07.2006., 14:45   #216
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
A evo i jednostavnog pojašnjenja:
Q: There are a lot of rumors
about
GeForceFX software voldmods on the net. I've seen some online BIOS voltmodding
tutorials and even volmodded BIOSes available for download. Can you comment
it?
A: Yes, GPU core voltage is really software
controllable on GeForce FX graphics processors. Unfortunately, all online BIOS
voltmodding guides I've seen seem to be written using blind comparison of different
BIOS binaries without actual understanding of software voltage control internals.
So they contain some logical errors. The same applies to some voltmodded BIOSes
available for download on some websites.
To understand internals of software voltage control, let's start from the very
beginning. NVIDIA boards have some GPU controllable GPIO (General Purpose Input
Output) pins, which are used for different purposes. Up to three of these pins
can be used to control core voltage on GeForce FX based boards. The states of
this pins form binary word (up to three bits width), which uniquely identify
target core voltage. This word is called VID, or voltage identifier. So to program
desired core voltage driver simply sets each pin to the corresponding state
via the corresponding GPIO register. But VID interpretation entirely depends
on the PCB's core voltage generation logic, for example most of NV35/38 boards
control core voltage via ISL6569 IC, where its' VID0 and VID1 input pins are
hardwired to 0 / 1, and VID2 - VID4 pins are programmable by GPU. So core voltage
on these boards can be adjusted in 0.8 - 1.5V range with 0.1V granularity and
all three GPIO pins are used. Other boards may have (and do have) simpler voltage
control logic (e.g. simplest 1-bit VID selecting one of 2 predefined voltages).
As I've said before, VID interpretation may differ depending on the PCB design,
and driver knows nothing about it. To allow hardware vendors to alter voltage
control logic safely, NVIDIA introduced so called voltage tables in BIOS with
BMP structure version 5.25 and newer. For older BIOSes driver uses its' own
GPU-specific internal voltage table. Voltage table begins from the header, containing
total amount of voltage entries, size of each entry and valid VID bitmask. The
last field is the most important, because it 'tells' the driver which pins actually
control the voltage. For example, nobody prevents hardware vendor from using
2-bit VID defined by pin 0 and pin 2. In this case VID bitmask will contain
101b. Take a note, that the driver will never program masked pins. Array of
voltage table entries follows by the header. Each voltage table entry contains
target voltage identifier (target voltage (in Volts) * 100) and VID defining
this voltage. The first element of each entry (i.e. target voltage identifier)
is used just to allow the driver to pick the corresponding VID from the table
(because the driver knows nothing about VID, it knows just the target voltage
picked from the corresponding performance level entry in the performance table).
So when programming the voltage, the driver simply picks required voltage entry
from the table by scanning all voltage table entries, comparing target voltage
identifier with voltage identifier of each entry and selecting the closest entry.
When the entry is selected, the driver disassembles VID on separate bits, and
programs each non-masked bit via the corresponding GPIO register.
If you've read all this info carefully, you may already see logical errors and
potential problems in currently walking voltmodded BIOS yourself:
First, it's plain wrong to voltmod BIOS by copying 1.5V VID from NV38's voltage
table to all other BIOSes without seeing the PCB and its' voltage control logic
as it is advised in BIOS voltmod tutorials. VIDs do not have to be the same
on all boards.
Second, it's wrong to ignore VID bitmask and to edit voltage table entry's VID
only. As an example, let's take a board with the following 2-bit VID:
00 -> 1.1V, 01 -> 1.2V, 02 -> 1.3V and 03 -> 1.4V. Attempt to boost
voltage by increasing VID to 4 will actually lower voltage and result in setting
1.1V (4 & 3 = 0). Attempt to boost voltage by copying NV38's 1.5V VID (7)
will simply do nothing (7 & 3 = 3). The same attempt on the board with different
2-bit VID interpretation (e.g. 01 -> 1.4V, 02 -> 1.3V, 03 -> 1.2V)
will also lower voltage and set it to 1.2V. So if you can actually see the PCB
and are sure that there are more than 2 bits in VID - you've to change VID mask
too. Otherwise, you simply shouldn't touch it.
To help you to see if your voltmodded BIOS really affects VIDs, RivaTuner gives
you an ability to monitor state of voltage related GPIO pins in realtime, so
you may see which VID is currently programmed by the driver. Using RivaTuner's
VID interpretation feature you may also see both raw VID data and target voltage
corresponding to this VID (to select VID interpretation mode right-click VID
graph in the hardware monitoring window, select Setup from the context menu
and press More button). Furthermore, RivaTuner's diagnostic report module allows
you to see internals of voltage table stored in VGA BIOS and warns you if there
are some entries with invalid VIDs, which don't conform to VID bitmask.
Q: If it is possible to program VID
pins, will RivaTuner provide us an ability to adjust GPU core voltage on-the-fly
for GeForceFX display adapters?
A: No, sorry. I'll never add software
voltage adjustment to RivaTuner as well as I'll never provide info about the
GPU registers controlling GPIO VID pins to third party tools creators. I don't
want to be related to development of the tool responsible for burning someone's
system, and direct voltage control via Windows utility is one on the things
that can help beginners to fry their GPUs.
Staro 01.07.2006., 14:51   #217
Razer
Razer's Avatar
Postovi: 11,642
Jednostavnije pojašnjenje
Staro 01.07.2006., 19:44   #218
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,415
Ja nasao nesto zanimljivo pa da pitam kako vam se cini??
VGA Galaxy AGP nVidia GF6600 256MB Zalman cooler
Specifications:
FEATURE GEFORCE 6600 AGP
Graphic Core
256-bit
Fill Rate (billion texels/sec.) 2.4
Vertices/sec. (million) 225
Graphics Bus Technology AGP
Pixels Per Clock (peak) 8
Memory DDR
RAMDAC 400 MHz
755.99kn
BlackDwarf je online   Reply With Quote
Staro 06.07.2006., 11:21   #219
Techno
Techno's Avatar
Postovi: 50
imam jedan problem.imam grafu iz siga i u 3d mark 01 SE mi izbaci score od 10k.zasto?dok u 3d mark 06 dobijem oko 1400 sto je ok.
jel moze biti moguce da u marku01 mi baci tak mali score zato sto taj program nepodrzava vertex & pixel shrader 3, tj. radi na starim tehnologijama??????
CPU: P4 2.0 @ 2.6 GHz Northwood B0
MBO: Gigabyte 81G1000-G
Grafa: Gigabyte nVidia GF 6600 128MB 8x AGP
Mem: 2x Kingmax DDR 512Mb 400 MHz 3-3-3-6
HDD:
Seagate 320 GB
Techno je offline   Reply With Quote
Staro 06.07.2006., 17:31   #220
MAHER
Postovi: 1,583
ne brini meni 3dmark 01 izbaci 12k,a skoro stalno je fps 200,možda zato što i nekog razloga je 200 granica(nikada mi ne ide preko),uglavnom neki bug,ne brini
MAHER je offline   Reply With Quote
Staro 07.07.2006., 00:08   #221
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
Evo kupih na kraju VF900...što da kazem osim da sam ocaran: nuts : : goood :
Pala temperatura u idlanju sa 55 (stock) na 34-35 (VF900).
Montaža lagana, ma sve 5
Sad sam bio pokrenuo 3DMarka i nakon zavrsenog testa je temperatura bila 36 stupnjeva , budem jos pokrenuo par testova pa javim
Yaxyo je offline   Reply With Quote
Staro 07.07.2006., 00:14   #222
Razer
Razer's Avatar
Postovi: 11,642
Autor Yaxyo
Odličan izbor : goood : ...i još bolji rezultati (temperature)...vidim da uistinu odlično hladi taj vf900...jesi li probao clockati grafu dokle ide...pa da vidiš koliko su onda temp na full loadu?
Staro 07.07.2006., 00:46   #223
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Mozda i ja puknem taj VF900 na svoju 7600GT kad je tako dobar
Staro 07.07.2006., 00:52   #224
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
NIsam nista jos clockao jer sam tek dosao doma bio u 23h...od 16h sam vani, isao prvo po Zalmana i onda van sa frendovima, cijeli dan ga nosim pa sam se ranije vratio da ga isprobam
Očekujte uskoro rezultate
Staro 07.07.2006., 14:12   #225
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Ajd super su temperature. Ja sam sebi naručio vf900 i mislio do sad da možda nisam treba, ali sad kad vidim kako ti ohladi nije mi žao. A tek kad odem po njega
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 07.07.2006., 17:42   #226
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
Evo, danas sam ju ocao i trenutno radi na 580/1150 (default je 500/110)...isla je i preko toga ali nisam siguran ni kako artefekti izgledaju pa sam je tu ostavio
Temperatura je u idlu 34 trenutno, nakon 3 puta 3D Marka je bila 37
Staro 07.07.2006., 19:10   #227
Techno
Techno's Avatar
Postovi: 50
Imam pitanje!!
dali VF700 & VF900 odgovaraju za sve grafulje iz serije 6600?????
tj. dali bi ih mogao uglaviti na moju grafulju iz siga???
HDD:
Seagate 320 GB
Staro 07.07.2006., 19:26   #228
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
idu bez problema, samo sto neces moci pasivce na memu stavit
Staro 07.07.2006., 19:34   #229
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
VF900 nece moći, barem ne prema Zalmanu. Piše da ne ide na AGP verzije.
Staro 07.07.2006., 19:37   #230
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
2001 dosta ovisi i o ostatku konfe, meni recimo daje nekih 16-ak tisuća.
Staro 07.07.2006., 19:39   #231
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Nemoguće da ti je load temperatura samo toliko veća od idle, upali Hardware Monitor u Riva Tuneru i tamo pogledaj nakon šta ti završi 3dmark.
Staro 07.07.2006., 20:13   #232
Yaxyo
Dok je nama nas :)
Yaxyo's Avatar
Postovi: 369
Evo bas skidam...btw, sad sam maknuo SkyStar 2 karticu jer mi vec dva tri mjeseca stoji tamo a ne koristim je zbog prekratkog kabla. Uglavnom, sve je bolje i bolje, u idleu je temperatura 32 stupnja
Fora je u tome sto se SkyStar jako grije za neupucene
Staro 07.07.2006., 20:14   #233
Razer
Razer's Avatar
Postovi: 11,642
Autor Emissary
I ja isto mislim...kad test završi grafa ...dok 3dmark izračuna rezultat i dok ti odeš vidjeti koliki je score...grafa se gotovo već ohladila...ap su zato i tvoje temperature tako male u loadu
EDIT: @Yaxyo - i ja sam imam skystar 2...i znam da se grije pogotovo ako se nešto skida s njom...treba na čip staviti pasivca i miran si
Zadnje izmijenjeno od: Razer. 07.07.2006. u 20:40.
Staro 07.07.2006., 20:47   #234
Razer
Razer's Avatar
Postovi: 11,642
Autor MAHER
Jesi li siguran - http://forum.pcekspert.com/attachmen...1&d=1152297968 - 996fpsa u Nature testu ...ništa nije nemoguće...nepitajte koji je proc i grafa
Zadnje izmijenjeno od: Razer. 04.09.2006. u 20:35.
Staro 07.07.2006., 21:48   #235
d0X
Kostolomac
d0X's Avatar
Postovi: 1,515
bi li mogla to jedna 7900gtx + a64 3700 napravit ili treba još nešto jače?
PSN Steam
d0X je online   Reply With Quote
Staro 07.07.2006., 21:54   #236
Zvijerko
Pečurka
Zvijerko's Avatar
Postovi: 1,294
Meni taj nature test ide dosta sporo
I5 3350P
XFX XTR 650W
Silencio 650
Staro 07.07.2006., 22:03   #237
Razer
Razer's Avatar
Postovi: 11,642
Autor d0X
To je bio athlon fx na mislim nekih 3ghz i sli od 7800gtx....
Staro 08.07.2006., 09:17   #238
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Autor Techno
3Dm01 ti izbaci tako niski score zato sto jako ovisi o ostatku konfe, a pogotovo o procesoru. A vidim da je tvoj p4 Northwood 2.0GHz clockan na 2,4GHz..i jos k tome ako se uzme da je malo starija instalacija windowsa...hm... nista neobicno da imas mali score. No opet, trebalo bi izbaciti ipak malo veci score... no nekako mi smrdi na staru instalaciju Windowsa.. najvjerojatnije
Staro 08.07.2006., 11:47   #239
MAHER
Postovi: 1,583
da 900fps,ali meni nikada ne ide preko 200,čak niti 201 ne želi potegnuti,a stoji na 200 neko vrijeme,mislim da mi je taj mark01 nekak zbagao
Staro 09.07.2006., 13:01   #240
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
Albatron 6600GT
da li ova grafa ima senzore za temp.? probao sam i sa coolbits i ništa se ne pojavljuje,ni u everestu...
SetH je offline   Reply With Quote
