Staro 04.04.2006., 13:49   #1
perich
I hate mondays..........
perich's Avatar
Datum registracije: Nov 2002
Lokacija: Zagreb - Zaprešić
Postovi: 1,534
MMS za MDA Compact na VIPnet-u...
Evo, ako neko ima kompakta, jel uspio osposobit mms? i druga stvar, ja sam nesto brljao po postavkama pa ak neko moze poslat na 0915073365 kakav mms pa ako mi dodje, budem postao settingse...
tenks
perich je offline   Reply With Quote
Staro 12.04.2006., 20:31   #2
Rospaya
Rospaya's Avatar
Postovi: 77
Najbolje da nazoves 091 7700 i trazis da ti posalju postavke...
Rospaya je offline   Reply With Quote
Staro 13.04.2006., 13:18   #3
perich
perich's Avatar
Postovi: 1,534
nazalost ne moze jer je to T-Mobileov uredjaj pa VIP ne pruza tehnicku podrsku za njega...
Staro 20.06.2006., 15:54   #4
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Evo, ja sam ikonfigurirao za VIP..
na ovom forumu ti sve pise...ali evo ukratko..
mjenjaj postavke, od svog operatera:
This are the setting that you need:
Make or edit a connection under My isp
APN: internet
Password: web
Username: web
Make or edit a connection under My Work Network this is needed for MMS
APN: wap.vodafone.co.uk
Username: user@vodafone.net
Password: user
Go to your messanger and configure the MMS Configuration under server make or edit the server:
Gateway: 212.183.137.12
Port Number: 9201
Server Address: http://mms.vodafone.co.uk/servlets/mms
forum ti je: http://forum.xda-developers.com/
Bez potpisa.
