Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Samsung to Launch Flash-Disk-Based Portable PCs
Samsung Electronics will launch two portable computers next month that use flash memory in place of a hard-disk drive for data storage, the company said Tuesday. Flash memory has long been eyed as a potential replacement for hard-disk drives because it works faster, is lighter and more shock-resistant, but it’s still more expensive. Despite the costs, flash memory chip prices are coming down to a range that some specialist users might be willing pay for the benefits. Samsung has built 32GB of NAND flash memory into a case the same size as a 1.8-inch hard-disk drive. The so-called "solid state disk" (SSD) has the same interface as a hard-disk drive, so it can be directly substituted with little extra work. http://www.cio.com/blog_view.html?CID=21352 |
Zule
Postovi: 1,993
Spremaju se opake brzine.. al još uvijek je to eskapada za većinu naših džepova ![]() |
#4 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,767
Postovi: 1,313
kolko je obicno znam da intelov 8 mb flash u linksysovom rotueru ima oko 10000 RW ciklusa, ovi u usb stickovima oko 1000000, taj disk moze imat oko 10-12 miljona?
Biti lud ima prednosti koje razumiju samo ludjaci ![]() FKT meber jednog dana high priest... |
