Staro 13.05.2006., 22:23   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Firefox 2.0 (Bon Echo) alpha2
There is a lot in Bon Echo Alpha 2 that we need you to play with and give us feedback on:
* Links default to opening in new tabs, not new windows
* Close buttons now appear on every tab, and the close behaviour is slightly different
* Inline spell checking in text boxes
* Automatic restoration of your browsing session if there is a crash
* Search suggestions now appear in the search box autocomplete for Google and Yahoo!
* New search plugin manager for removing and re-ordering search engines
* Improved support for previewing and subscribing to web feeds
* New microsummaries feature for bookmarks
* New Add-Ons manager improves the user interface for managing extensions and themes
* Updates to the extension system to provide enhanced security and to allow for easier localization of extensions
* New search service that supports Sherlock and OpenSearch engines
* Support for SVG text using svg:textPath
http://ftp.mozilla.org/pub/mozilla.o...onecho/alpha2/
Mailman je offline   Reply With Quote
Staro 16.05.2006., 08:41   #2
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Je li ko isprobao ? Kako se ponasa ? Kompatibilnost sa extenzijama i themama ?
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 16.05.2006., 14:39   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Staro 16.05.2006., 18:58   #4
mat
Postovi: 2,105
ne vidim nesto posebno interesantno tak da mi se opce neda isprobavat
mat je offline   Reply With Quote
Staro 17.05.2006., 10:09   #5
domy_os
domy_os's Avatar
Postovi: 18,829
Ovo je itekako korisno...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 17.05.2006., 10:30   #6
West
West's Avatar
Postovi: 268
Vrijedi probati...
West je offline   Reply With Quote
Staro 18.05.2006., 14:07   #7
mat
Postovi: 2,105
Autor domy_os
to imam sad sa "tab mix plus" ekstenzijom i nicem posebnom ne sluzi
stranice nikam nebuju pobjegle ak se meni srusi pc, a ak su mi tako jako trebale onda cu ih se i sjecat
uglavnom imam to i nije nis posebno potrebno
Staro 18.05.2006., 14:22   #8
domy_os
domy_os's Avatar
Postovi: 18,829
Vjeruj, kad ti se Firefox ili komp "sruši", a imaš 10-15 tabova otvoreno, jako dobro dođe, pogotovo kad čitam forum preko New Posts opcije jer tu čim otvorim neku temu, više je nema na popisu novih postova.
Staro 19.05.2006., 09:57   #9
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Cini se da ce biti dobar, ali kome se ne da isprobavat bolje da ceka finalnu verziju najavljenu za kolovoz 2006 :clap:
