Staro 14.05.2006., 19:41   #1
MetallicA
MetallicA's Avatar
Lokacija: my zimmer
Postovi: 521
help
mislio sam si kupit novi komp ali sad gledam u hgspotu
20284 VGA AGP GAINWARD, BLISS 7800GS 512 GS DDT Silent, Geforce 7800 GS, 512 MB, tv-out, Dual DVI
dal da kupujem novi komp koji podrzhava pcie ili da si kupim tu grafu i josh gigu rama (sad iam gigu) i tak nek mi ostane
ovak bi mi jeftinije doshlo iam nforce2 plochu
"...thrashing allaround,acting like a maniac..." what is it ? Call oF DuTy ....pwning
MetallicA je offline   Reply With Quote
Staro 15.05.2006., 08:57   #2
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
kupi pce grafu, plochu i proc.
Staro 15.05.2006., 17:41   #3
MetallicA
MetallicA's Avatar
Lokacija: my zimmer
Postovi: 521
ali mislim da mi dođe jeftinije ako oavk uzimam a da su performanse slichne ako ne i iste iskljuchujuchu proc
Staro 15.05.2006., 18:18   #4
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Kupi si rade novi proc, plocu sa pcie, i neku grafu za pcie...
Preskupo je tih 3000kn za grafu, a i kasnije kad ces htjet nadogradivat na jace vjerovatno neces ima kaj jer sumnjam da ce se radit grafe za AGP...
S tim kaj su pcie kartice jeftinijo od ostih za AGP...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 15.05.2006., 19:01   #5
MetallicA
MetallicA's Avatar
Lokacija: my zimmer
Postovi: 521
a kaj nebi ova gore malo dulje trajala
Staro 15.05.2006., 21:14   #6
Facelessone
Facelessone's Avatar
Postovi: 4,204
ma nemoj to kupofat...kak kaze panzer rađe skupljaj jos pare pa pređi na pcie. kartice su jeftinije i jos znas da nece tak brzo izac iz "mode"
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
