Staro 12.05.2006., 17:27   #1
Gladius-
Gladius-'s Avatar
Postovi: 181
3gp ==> avi ili neki drugi...
Dal zna itko nekakav program za pretvaranje 3gp formata (iz mobitela) u ''normalan'' format... ? Nedaju mi se filmici sa moba gledat u onom Quicktime ''pobaca mi se svuda po windowsima'' playeru stalno
Gladius- je offline   Reply With Quote
Staro 12.05.2006., 17:49   #2
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Gladius-
ImTOO 3GP Video Converter
The 3GP video converter is a powerful 3GP converter which can convert AVI to 3GP, MPEG to 3GP. ImTOO 3GP Converter can also convert H.264, RM, MP4, MOV, WMV, MPEG, AVI to 3GP file or convert 3GP video clip to AVI and MPEG. You can use it to convert MPEG or AVI to 3GP video clip and play them in Motorola, Nokia mobile phone or other software 3GP player.
Ja sam ga koristio, ok je program...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 12.05.2006., 18:00   #3
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
quicktime alternative
http://www.google.com/search?q=3gp+to+avi
pa onda pitati tu
inace total video converter radi i vise neg odlicno
.i.
Razer Blade 15
Staro 12.05.2006., 20:17   #4
Gladius-
Gladius-'s Avatar
Postovi: 181
Autor Panzer
gg Panzer
Staro 13.05.2006., 01:20   #5
domy_os
domy_os's Avatar
Postovi: 18,928
Nokia Multimedia Converter ili My Video Converter.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 13.05.2006., 07:58   #6
Postovi: 34,046
3gpToRawAvi
Staro 13.05.2006., 09:38   #7
Gladius-
Gladius-'s Avatar
Postovi: 181
[QUOTE=domy_os]Nokia Multimedia Converter ...QUOTE]
taj koristim za pretvaranje u 3gp; nekako mi je -ImTOO 3GP Video Converter jednostavniji i bolji za obratni proces
Staro 15.05.2006., 12:49   #8
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
meni je total video converter super, po meni bolji od imtoo, a i bolje u .3gp pretvara.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 16.05.2006., 00:29   #9
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
jos jedan glas za doticnog
.i.
Razer Blade 15
Staro 16.05.2006., 11:38   #10
Gladius-
Gladius-'s Avatar
Postovi: 181
Autor Codiac-
Ajde de nismo u saboru :-)
Staro 16.05.2006., 13:55   #11
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Xilisoft 3GP Video Converter
ja ga koristim i meni je super
