Staro 08.05.2006., 11:07   #1
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 501
ŠTo se dogodilo?
Windows has detected that one or more protected core system files (kernel) on your computer have been modified. The Service Pack contains updated versions of those files, which work to provide a stable environment for your programs. Due to this modification, the Service Pack will not be installed. For more information, see Knowledge Base article Q327516 at http://support.microsoft.com
zlatko je offline   Reply With Quote
Staro 08.05.2006., 11:30   #2
mat
Postovi: 2,105
pa dogodilo se tocno to sto pise
ili ti je neki program nes sprtljo ili si ti, moj savjet reinstall i to je to...
mat je offline   Reply With Quote
Staro 08.05.2006., 11:43   #3
Perki
Lokacija: VG
Postovi: 775
A što si radio?
Da nisi možda probao radit upgrade s xp home na pro?
Ak jesi, oba moraju imati isti service pack.
Perki je online   Reply With Quote
Staro 08.05.2006., 13:11   #4
mirkoB
mirkoB's Avatar
Datum registracije: Feb 2003
Postovi: 783
Pokušaj instaliranja SP-a na nLite-ane windowse ?
| AVG Free 7 | SPF 5.6 | SS&D 1.4 | MBSA 2.0 |
| Firefox & Thunderbird 1.5 | MozBackup 1.4.4 | POPFile 0.22.2 |
| 7-Zip 4.32 | VMWare Player | nLite 1.0RC7 | Qemu 0.7.2 |
| PDFCreator 0.8.0 | Open Office 2.0 | Readiris Pro 8 |
| UltraVNC 1.0.1 | Media JukeBox 8.0 | Burn4Free 2.3 |
| Pentium D 805 | ThermalTake BigTyp 120 |
| Gigabyte G945P-S3 | 1024/667 Kingmax DDR2 | 160 GB Hitachi SATA2 |
| Enlight 430W | Antec Solution SLK3700AMB | OKI OL400w |
| XP Home SP2 zakrpan do jaja + Windows 98SE Virtual Machine |
| 178/81 |
| Cipele br. 42 |
| 35 godina |
mirkoB je offline   Reply With Quote
Staro 08.05.2006., 22:34   #5
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 501
Imam 2 stroja. Na jednom sve prođe u redu-reinstal wina. a na drugom mi izbacuje upozorenje i neće dalje . Riječ je o istom win-una oba stroja.
Staro 08.05.2006., 23:54   #6
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
mozda ti cd/dvd rom sere ?
Ja sam imao tako problema sa tri dvd roma nemres vjerovati
.i.
Razer Blade 15
Staro 09.05.2006., 02:26   #7
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
pokušaj ponovo. Ja sma vidio svakave obavijesti.
evo par:
windows can not determine the type of computer you have choose from the list
windows has detected hard disks, but the selected disk does not contain a Windows XP comptible partition ( HDD prije tga formatiran u NTFS)
i još par kojih se sad nemrem sjetit.
velim pokušaj ponovo ili odi cd reklamirat u M$ od nosno mjesto kupovine.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 09.05.2006., 08:42   #8
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 501
wini su instalirani na dva stroja istog dana sa istog cd-a prije 8 mjeseci. Radio sam reinstal bez formatiranja. Na jednom je prošlo u redeu , a na drugom neće.
cd-dvd pogon je u redu. šta da napravim , a da ne formatiram. Nova instalacija ide.probao kod kolege. Znači i cd uredu.
Zadnje izmijenjeno od: zlatko. 09.05.2006. u 08:53.
Staro 09.05.2006., 17:24   #9
immortal
Kernel panic
Postovi: 522
Reinstal bez formatiranja ? Zašto ?
Keyboard error or no keyboard present
Press F1 to continue, DEL to enter SETUP
immortal je offline   Reply With Quote
Staro 10.05.2006., 14:45   #10
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 501
Autor immoRt4L
zašto ne?
Staro 10.05.2006., 14:47   #11
immortal
Kernel panic
Postovi: 522
Pa ne vidim svrhu... Prebaciš podatke na drugu particiju ili DVD/CD i formatiraš disk, staviš gore windowse i sve ok. Nema gore nekih sranja, virusa i ostalog.
Staro 10.05.2006., 16:55   #12
mat
Postovi: 2,105
baš. pa reinstall vindouza se i radi da bude sve čisto i friško jel?
Staro 10.05.2006., 17:32   #13
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
reinstal windoza preko starih windoza je samoubojstvo
ili upgrade s win 98 na xp pro..nemojte..užas..
Staro 10.05.2006., 18:51   #14
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 501
nemam tako loših iskustava ni sa reinstal , ni sa upgrade. Jednostavno nema sranja, virusa ni ostalog , samo repair wina.
