Postovi: 177
3200+ za 3800+
Da li mi se isplati mijenjati 3200+ Venice za 3800+ Newcastle s nadoplatom?Ovaj 3800+ nema sse3,koliko on utječe na performanse i za šta on uopće služi? |
Lokacija: ̣
Postovi: 1,019
đizs,kaj si tolko zapeo za taj sse3.To ti je skup instrukcija koje A 3800+ ima MMX +,3DNOW +,SSE ,SSE2, x86-64 SSE3, also known by its Intel code name Prescott New Instructions (PNI), is the third iteration of the SSE instruction set for the IA-32 architecture. Intel introduced SSE3 in early 2004 with the Prescott revision of their Pentium 4 CPU. In April 2005, AMD introduced a subset of SSE3 in revision E (Venice and San Diego) of their Athlon 64 CPUs. The earlier SIMD instruction sets on the x86 platform, from oldest to newest, are MMX, 3DNow! (developed by AMD), SSE and SSE2. Contents Changes The most notable change is the capability to work horizontally in a register, as opposed to the more or less strictly vertical operation of all previous SSE instructions. More specifically, instructions to add and subtract the multiple values stored within a single register have been added. These instructions simplify the implementation of a number of DSP and 3D operations. There is also a new instruction to convert floating point values to integers without having to change the global rounding mode, thus avoiding costly pipeline stalls. Finally, the extension adds LDDQU, an alternative misaligned integer vector load that has better performance on NetBurst architectures for loads that cross cacheline boundaries. CPUs with SSE3 * AMD: o Athlon 64 (since Venice Stepping E3 and San Diego Stepping E4) o Athlon 64 X2 o Athlon 64 FX (since San Diego Stepping E4) o Opteron (since Stepping E4) o Sempron (since Palermo Stepping E3) o Turion 64 * Intel: o Celeron D o Pentium 4 (since Prescott) o Pentium D o Intel Core o Xeon (since Nocona) * VIA/Centaur: o C7 * Transmeta o Efficeon TM88xx (NOT Model Numbers TM86xx) New Instructions Common Instructions Arithmetic * ADDSUBPD - ( Add-Subtract-Packed-Double ) o Input - { A0, A1 }, { B0, B1 } o Output - { A0 - B0, A1 + B1 } * ADDSUBPS - ( Add-Subtract-Packed-Single ) o Input: { A0, A1, A2, A3 }, { B0, B1, B2, B3 } o Output: { A0 - B0, A1 + B1, A2 - B2, A3 + B3 } AOS ( Array Of Structures ) * HADDPD - ( Horizontal-Add-Packed-Double ) o Input: { A0, A1 }, { B0, B1 } o Output: { B0 + B1, A0 + A1 } * HADDPS ( Horizontal-Add-Packed-Single ) o Input: { A0, A1, A2, A3 }, { B0, B1, B2, B3 } o Output: { B0 + B1, B2 + B3, A0 + A1, A2 + A3 } * HSUBPD - ( Horizontal-Subtract-Packed-Double ) o Input: { A0, A1 }, { B0, B1 } o Output: { A0 - A1, B0 - B1 } * HSUBPS - ( Horizontal-Subtract-Packed-Single ) o Input: { A0, A1, A2, A3 }, { B0, B1, B2, B3 } o Output: { A0 - A1, A2 - A3, B0 - B1, B2 - B3 } * LDDQU - As stated above, this is an alternative misaligned integer vector load. It can be helpful for video compression tasks. * MOVDDUP, MOVSHDUP, MOVSLDUP - These are also used for complex numbers, and can be helpful for wave calculation like sound. * FISTTP - Like the older x87 FISTP instruction, but ignores the floating point control register's rounding mode settings and uses the "chop" (truncate) mode instead. Allows omission of the expensive loading and re-loading of the control register in languages such as C where float-to-int conversion requires truncate behaviour by standard. Intel Instructions * MONITOR, MWAIT - These optimize multi-threaded applications, giving processors with Hyper-Threading better performance. |
Postovi: 4,190
ja ne bi mjenjao...venicea lako kloknes za 400mhz i imas 3800+ ![]() |
Postovi: 177
Ma nisam zapeo,samo me zanima za šta služi i to @baterija:javim ti se onda još ![]() Čuo sam da aplikacije najviše profitiraju od sse3,zato pitam.Je li to istina ili ne? |
Postovi: 12,425
ja se nebi mjenjao samo zato kaj je NewCastle a to su najlošije s939 jezgre! A taj E3 Venice ide ziher i preko takta tog 3800+ @baterija dobar copy/paste ali ti mu još nisi zdravo seljački objasnio ćemu to služi ![]()
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
A kakva su vam misljenja o NewCastle jezgrama u s.754 procevima?
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#7 | |
Postovi: 4,190
The Dark Side of Moon
Postovi: 3,945
ne isplati se mjenjat
Postovi: 177
Ma odustao sam od toga |
zippo61_junior
Postovi: 1,296
Dobro si postupio |
